Old 07-30-2007, 12:44 AM   #1
rseisenman
Member#: 141440
2002 Bugeye DOM 3'd
tu-tone Silver/black
Default Enginuity 16g and supporting mods map??
I'm looking for a 16g base map for an 02 bugeye. Here is the list of mods
(installed)
Hyperflow top mount
Perrin Short Ram
HKS Header and up-pipe
MRT Catted Down-pipe
Test-pipe
HKS Carbon Ti Catt-back
Fresh set of 1-4 PPG syncro-mesh straight-cuts from andrewtech
Exedy stage 1 clutch
(waiting to go on)
STi pinks
Perrin Fuel Rails
Walbaro 255
Mitsu 16g from Bullseye
Gaskets and such
Defi tri gauge pod (boost/egt/fuel pressure)
Innovate Wideband and controller
Right now I'm looking for a base map just to get everything up and running. I live 2hrs north of Pittsburgh and there are no local tuners. So basically I just need something that I will be able to safely drive until I can get a pro-tune.
Right now money is a little tight since I just dropped the money on the PPG's so anything would be great guys Thanks.
rseisenman is offline   Reply With Quote
Old 07-30-2007, 01:28 AM   #2
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
(installed)
Hyperflow top mount
Perrin Short Ram
Test-pipe
(waiting to go on)
STi pinks
Perrin Fuel Rails
Walbaro 255
Gaskets and such
One of the VF39/34 maps on osecuroms should get you close. You've got the wideband, if you are looking to do a open source tune why not learn to tune it yourself?
Old 07-30-2007, 10:45 PM   #3
rseisenman
Member#: 141440
2002 Bugeye DOM 3'd
Default I'm more than willing to learn
I'm more than willing to learn. I just wanted something to get me started. I've been reading up on tuning, but I'm just a little scared about the whole thing. With a point in the right direction I'm ready to give it a shot.
Old 07-31-2007, 12:25 AM   #4
06rexwagon
Member#: 114730
2006 WRX Limited Wag
[email protected]
Just take any of the vf series maps and zero out the boost and wgdc tables and you should be fine to drive it to the tuner. Let me know if you need help and I can fix it up for you.
06rexwagon is offline   Reply With Quote
Old 08-01-2007, 10:36 PM   #5
rseisenman
Member#: 141440
2002 Bugeye DOM 3'd
Default Thank you 06rexwagon
If I used a VF series base map how hard would it be to tune myself? What values would I be looking for in logs? The closest tuner is in Indiana PA and they are the guys at slowboy. I would prefer to learn how to do this myself. Are there any books I can buy to learn more?
I've been helping my friend work on his boosted IS300 running a haltech standalone system. He just bought the car from a guy in Alabama. It was tuned at PFS in Maryland, but it keeps junking plugs and stalling at idle. So pretty much we are getting a crash course in learning how to tune.
Old 08-01-2007, 11:20 PM   #6
WeldingHank
Member#: 98645
2002 WRX Wagon
its easy to tune a 16g right out of a stage 2 map. just scale the injectors, and latency to zero out your trims. then start at wastegate pressure and tune up from there to your desired boost level. rescale appropriately on the way. I'm in the process of doing it right now.
WeldingHank is offline   Reply With Quote
Old 08-03-2007, 12:16 AM   #7
06rexwagon
Member#: 114730
[email protected]
read cobbs tuning guide.
Old 08-03-2007, 12:54 AM   #8
sgmongoose
Member#: 123731
01 2.5rs/ 03 TL-S
white/silver
where can i find this tuning guide?
sgmongoose is offline   Reply With Quote
Old 08-03-2007, 10:31 PM   #9
cellobro
RIP 3/18/1965 to 1/10/2008
Member#: 91500
hmmm sr-30+640cc=?
I has teh Endless BBK.
Originally Posted by brettm View Post
Here ya go, check this document out:
http://www.cobbforums.com/forums/showthread.php?t=31091
mwsoc sends it's regards...
cellobro is offline   Reply With Quote
Old 08-04-2007, 12:51 AM   #10
06rexwagon
Member#: 114730
[email protected]
There you go. Thanks cellobro.
Old 08-05-2007, 10:51 PM   #11
rseisenman
Member#: 141440
2002 Bugeye DOM 3'd
before I do my install do you guys think I should up the injector size, or will the pinks be big enough?
Also what would be a good target boost range to shoot for? I've pulled a couple of logs and I'm peaking at 15.7 and tapering off to around 13.4 on a solid 3rd gear pull. Now the problem is when I bought the car most of the mods were already done so I don't know how or if it was tuned before.
Old 08-06-2007, 12:36 PM   #12
Zumble
Member#: 34860
2005 Forester CGM
Pinks will def be enough.
If you want safe I would say ~17psi would be really safe but you can def do more. It really depends on where the peak boost is.
Zumble is offline   Reply With Quote
Old 08-06-2007, 08:30 PM   #13
WeldingHank
Member#: 98645
2002 WRX Wagon
the 16g really works well into the 20+ PSI range. to take full advantage of the 16g you need atleast 650's and about 22-24psi of boost
Old 08-07-2007, 09:15 AM   #14
blkscooby
Member#: 44422
2009 G8 GT
Cammed, sprayed, stalled
Hank, what boost are you holding to redline? I haven't looked at the compressor map for the 16g.
blkscooby is offline   Reply With Quote
Old 08-07-2007, 07:21 PM   #15
WeldingHank
Member#: 98645
2002 WRX Wagon
i'm getting it to hold 20psi right now. I don't know if it'll hold much more.
Old 08-08-2007, 10:35 AM   #16
rseisenman
Member#: 141440
2002 Bugeye DOM 3'd
Hank, running at 20psi what is your AFR at and what size/kind of injectors are you running? Also if you don't mind me asking have you been dyno'd, what type of whp are you making?
F/S PA: Evo3 16g/EWG/Supporting mods kornykidd0 Engine/Power/Exhaust 16 06-02-2010 03:51 PM
VF39 and supporting mods install help needed. killawhiterex Mid Atlantic Impreza Club -- MAIC 0 11-22-2005 12:20 AM
Looking for : Ported Polished VF34 and supporting mods 02scooby Private 'Wanted' Classifieds 0 07-24-2005 12:24 AM
VF30 and supporting mods on Cobb stage 2 map... help WRXVII Engine Management & Tuning 4 07-08-2004 09:16 PM
