Old 07-30-2007, 11:14 AM   #1
nicholam
Member#: 133936
2005 WRX Wagon
Stage 4 Silver
Default Installing V8 Jdm Lateral links on my wagon. Do I need Camber Bolts?
I'm in the process of replacing my lateral links with V8 Jdm links. The links look identical to the factory ones but word on the street is they're longer. Will I need camber bolts to correct the alignment?
nicholam is offline   Reply With Quote
Old 07-30-2007, 12:39 PM   #2
nicholam
Member#: 133936
2005 WRX Wagon
Stage 4 Silver
Bump for experianced advice?
Old 07-30-2007, 01:13 PM   #3
nicholam
Member#: 133936
2005 WRX Wagon
Stage 4 Silver
I forgot to mention that these are STi lateral links but they have the right mounts for wrx style endlinks. I'll be running perrin endlinks with these. Word on the street is they're 8mm longer then my stock lateral links so I'm wondering about fitment, alignment etc.
Old 07-30-2007, 02:31 PM   #4
mrpedal
Member#: 71361
2000 Impreza 2.5RS
Might think this though more. Read this:
http://forums.nasioc.com/forums/show....php?t=1291027
not sure what the pop-out distance is, but similar thing could happen. Also, not sure what stage-4 means in your profile, but if that's hp-mods, I'd want all the axle in the differential
hope that helps
mrpedal is offline   Reply With Quote
Old 07-30-2007, 02:42 PM   #5
ralliharri
Member#: 85035
2011 WRX 5-door
KTM 690 Duke
Hmmm, now I'm a little worried, have "STi" adjustable lat. links but had them for over 6 months now with a couple of track days, no ill effects, running -1.6 rear camber and links at shortest length. Gotta go and measure my rear track with.
ralliharri is offline   Reply With Quote
Old 07-30-2007, 03:05 PM   #6
nicholam
Member#: 133936
2005 WRX Wagon
Stage 4 Silver
According to that post the popout distance was 15mm. So basically I should be fine. Stage 4 means I've got the basic stage 4 setup but with an APS S/R30. I make around 280-290 whp. I don't track the car and I was going to go for -1.6 camber on the front and rear with 0 toe. Right now my lateral links are bent and I got this set for only $140 shipped! These are not adjustable lat links, just stock V8 Jdm STi replacements. I didin't know that the jdm v8 sti had wrx style mounts.
GDA Lateral Links on a GC to Cure Pos Camber issues in the rear? JeffrWRX Brakes, Steering & Suspension 11 10-23-2008 11:00 AM
sti lateral links on a wagon? natoli4 Brakes, Steering & Suspension 2 03-21-2006 11:27 PM
Help me source aluminum lateral links for my wagon BIGSKYWRX Brakes, Steering & Suspension 74 01-16-2005 08:56 PM
do i need camber bolts for h-techs springs on a 04 wrx sedan? Supaboom Mid Atlantic Impreza Club -- MAIC 10 09-19-2004 09:14 PM
04 STi lateral links, strut tops, sway bar, and Z1 camber bolts StiDreams Private 'For Sale' Classifieds 10 03-15-2004 09:50 AM
