Welcome to the North American Subaru Impreza Owners Club Saturday February 6, 2016
Old 01-02-2008, 06:13 PM   #26
Big-E
Member#: 123843
2006 WRX Sedan SGM
Let LED's light your way!
L to R: Snap-On® Torx® T-70 bit with ½” drive socket; GreatNeck® Torx® T-70 bit with 3/8” drive socket.
Old 01-03-2008, 11:23 AM   #27
Asinine
Sufficient for Sharky
Member#: 55173
with paddles.
I just put a clean latex glove around the outside and went to town with a large monkey wrench. The skin on my knuckles grew back within a month.
I think I will be using a nice, new T70 this time, though
Asinine is offline   Reply With Quote
Old 01-03-2008, 11:43 AM   #28
ULTIMATETOOLCO
Member#: 165370
2007 WRX
www.ultimatetoolco.com
Ouch!
Well, when you're in the market for a T70 Torx socket, please give me the opportunity to help you with that.
ULTIMATETOOLCO is offline   Reply With Quote
Old 01-07-2008, 09:23 AM   #29
Pallendo
Member#: 65831
91 Miata. Hey you
can f* short girls in one
Originally Posted by AFY2600 View Post
when i said and allen (hex key) would fit i didnt mean use an allen as a wrench on the torx bit i meant that a big hex head will fit in the torx bolt with out damaging/rounding the inside of the head if that made sense to anyone
That makes no sense at all. Just buy the T-70
Pallendo is offline   Reply With Quote
Old 01-07-2008, 11:12 AM   #30
Asinine
Member#: 55173
with paddles.
I'd like to know why you can find T-60 and smaller bits all over the place, but Subaru chose to go with the seldom seen T-70. I'd also like to know where I can find a cheap T-70 socket, since it will likely only ever seen use 5 times in its life... no offense TOOL
Old 01-07-2008, 01:06 PM   #31
ULTIMATETOOLCO
Member#: 165370
2007 WRX
I cannot speak on Subaru's behalf, but typically a manufacturer considers a number of things to determine a certain fastener size to use (regardless of what bit size is commonly found in the marketplace): necessary torque holding requirements, vibration, surrounding materials, temperature range, etc. You can bet Subaru did the same for us.
No offense taken at all. But looking for a cheap alternative to something because of its infrequent use may be considered fine in other areas of life, however that logic is frightening IMO when used in terms of automotive maintenance.
Old 01-12-2008, 03:32 AM   #32
IronMonkeyL255
Member#: 38120
1991 Rio Red
Legacy Turbo
This is exactly why I replaced the T70 plug with the standard plug........
IronMonkeyL255 is offline   Reply With Quote
Old 01-13-2008, 06:39 PM   #33
pdippel
Member#: 20611
2003 WRX
World Rally Blue
Just got a GreatNeck 3/8 T70 at Autozone for 3.99. S2 steel (whatever that is) and heat treated.
pdippel is offline   Reply With Quote
Old 06-06-2008, 11:33 AM   #34
Tahoe SC
Member#: 131996
2006 CGM WRX Wagon
Yimi Tuned 296AWP/322TQ
did it explode on you or did the autozone one work out ok? i had to use a reducer (1/2" to 3/8") once on a tire and had exploded the reducer...then another time also 3/8" i exploded the socket...
Tahoe SC is offline   Reply With Quote
Old 06-06-2008, 12:41 PM   #35
ULTIMATETOOLCO
Member#: 165370
2007 WRX
When subject to that much stress, it is common that a 3/8" drive T70 and/or its counterparts will fail that way. Even though a 3/8" drive T70 may work, we strongly recommend 1/2" drive T70 sockets if being used on Subaru transmission drain plugs (especially if its the very first time being removed). The 3/8" drive T70 is better suited for the Chevrolet truck brake application (though we would still suggest using a 1/2" drive for that too).
Old 06-06-2008, 07:39 PM   #36
Tahoe SC
Member#: 131996
2006 CGM WRX Wagon
i'm about to hit you guys up ultimatetool!
i'm a decent wrencher...but better at breaking things...LOL...
T
Old 09-29-2008, 02:31 AM   #37
LoLoHax
Member#: 151648
2005 WRX Wagon
I actually found a T70 at Autozone, it was the last one, but the gentleman at the store said they can special order them.
LoLoHax is offline   Reply With Quote
Old 10-18-2008, 11:38 PM   #38
2:43AM
Member#: 190273
05 WRX evoIII-16G
Yes, Autozone has them. Approx. $4 and instant gratification.
2:43AM is offline   Reply With Quote
Old 11-22-2008, 11:04 PM   #39
XmikeX
Member#: 184768
05 WRX
toasted white
Originally Posted by Unabomber View Post
weewaywoo = n00b of the week award, this needs stickied for awhile as this really is a great deal.
<------early 04 owner with old style bolt unlike you later 04+ poor bastards with the T70.
i have a 05 that has the torx bit... wierd
XmikeX is online now   Reply With Quote
Old 11-22-2008, 11:51 PM   #40
Honest Bob
Member#: 94698
2005 30R Wagon
CGM
Yep late 04's and 05's have the torx bit. I dont know about 06+ but I would assume so.
Honest Bob is offline   Reply With Quote
Old 01-26-2009, 07:32 PM   #41
john_matrix
Member#: 54787
2005 Saab 9-2x
Satin Gray Metallic
Yeah, I got the same thing a few weeks ago.
Used it to change my fluid this weekend for the first time.
It did fine. I could feel the wrench flex, the actual bit was fine though.
I was afraid I would have to order this seldom used bit.
Autozone FTW.
john_matrix is offline   Reply With Quote
Old 01-31-2009, 02:39 PM   #42
REACT
Member#: 103587
Originally Posted by Pallendo View Post
Buy a T-70. It's cheaper than a replacement bolt or the labor it will take to get your stripped bolt out.
FYI, the replacement tranny drain plug part # = 32103AA080 and the corresponding brass gasket = 803926070
https://www.subarugenuineparts.com/oe_parts_cat.html
This is good information for those that use a T60 and it doesn't work so well.
REACT is offline   Reply With Quote
Old 02-08-2009, 10:23 AM   #43
pt_customs
Member#: 199331
2005 WRX STI
According to Ultimatetools website, the '04 - '06 STI don't need the T70 tool? So what does the STI use, the T60??
pt_customs is offline   Reply With Quote
Old 03-29-2009, 10:05 AM   #44
coopspeed
Member#: 204186
Maintenance manual says it's torqued to 51.6 ft-lb. You shouldnt need a breaker bar.
coopspeed is offline   Reply With Quote
Old 05-26-2009, 06:35 AM   #45
tangmonkey
Member#: 114234
Randomly saw a T70 chillen at AutoZone...picked 'er up for $4
tangmonkey is offline   Reply With Quote
Old 08-10-2009, 05:36 PM   #46
mellow
Member#: 183181
2005 Forester XT
Until it shatters on you haha. I bought one at autozone to drain my tranny fluid the other day and the god damn thing blew up on me when i tried loosening up the drain plug. Must not have been heat treated properly. Gonna borrow one from the Snap-On guy now, because I know that one won't break on me.
mellow is offline   Reply With Quote
Old 08-29-2009, 02:08 AM   #47
Asinine
Member#: 55173
with paddles.
Stupid question: is the brass gasket reusable or should it be replaced every time? I've reused it in the past.
Old 09-24-2009, 07:27 PM   #48
Crazystars
Member#: 224680
Craz
Crazystars
Default Found a cheap source for a Torx bit set with a T 70 bit
The link wouldnt work for me so I checked the USO website and there it said that the DOD has suspended all "any serviceman" mail. Is this still going to work? Please leave details.
Crazystars is offline   Reply With Quote
Old 06-15-2010, 09:42 AM   #49
Punk In Drublic
Member#: 232673
2015 wrx
dgm
Autozone has them for $3.99 - part number 24285
http://www.autozone.com/autozone/cat...ame=Driver+Bit
Punk In Drublic is offline   Reply With Quote
Old 07-10-2010, 04:37 PM   #50
SFO GTO
Member#: 233400
05 92-x/Sti
When you're in a pinch you can use a big pipe wrench. I wasn't reusing my 5-speed so I wasn't concerned with retightening the plug, but I dont see whey you couldn't, just be careful.
SFO GTO is offline   Reply With Quote
Found a good source for Motul in SoCal JamesWilson Motorsports 1 09-08-2006 05:33 PM
Local/Cheap source for RBF600? jmolaver New England Impreza Club Forum -- NESIC 5 02-12-2005 11:13 PM
Cheap source for a pair of new 04 WRX headlights. trail*of*dead Electrical & Lighting 3 01-10-2005 06:36 PM
OT: Cheap source for Cisco Router matt h New England Impreza Club Forum -- NESIC 2 04-30-2003 10:50 AM
Very Very Cheap source for auto tranny coolers! GregBolby General Forum Archive 0 02-14-2001 08:51 PM
