Old 08-01-2007, 02:07 PM   #1
oneoverWRX
Member#: 74793
02 WRX
BLAZE YELLOW
Default Axis Stg5 perrin 3082r
Car was tuned at p and l by jorge. 93 pump and c16 maps
Mods
Axis stg 5 8.8:1cr
wrx heads w/ stg 1 axis package
kelford cams 278/272
No porting
Perrin 3082r kit
ultimate racing fmic
dual walbros
1000cc injectors
aem ems
Car made 349 on pump and 20-21 psi and 462 on c16 at 30 psi.
Peek torque is at about 5500 rpm.
Inside the dyno room the temp was 99.x deg.
I will try to post the graph a little later.
Has anyone else had any issues with this turbo being so laggy? what did you do to make it better? change exhaust housings?
Thanks
oneoverWRX is offline   Reply With Quote
Old 08-01-2007, 02:10 PM   #2
shemoves
Member#: 80663
2005 STi
Could the lack of AVCS be a bottleneck? or perhaps an issue with how the pre/post FMIC piping is run? Also, ambient temps were high. While I know that can affect overall output, I dunno if it tends to 'shift' dyno plots to the right.
shemoves is offline   Reply With Quote
Old 08-01-2007, 02:14 PM   #3
SloRice
Member#: 44351
2004 Mitsubishi Evo
701whp [email protected]
define laggy. When do you reach full boost? At what RPM do you have peak torque?
SloRice is offline   Reply With Quote
Old 08-01-2007, 02:18 PM   #4
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
wtf is a 3082R? Did you mean 3076R with .82 A/R Exhaust?
Old 08-01-2007, 02:54 PM   #5
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
this ought to be a potent combo on the road especially on race gas. Any chance of some in car footage of this thing in action?
jigga is offline   Reply With Quote
Old 08-01-2007, 02:58 PM   #6
aps2fast4u
Member#: 57871
2004 WRX
13.4 @ 102
waiting for chart...that does seem pretty laggy though for a built motor hopefully you can find the cause...
EDIT: I did notice that you had the .82 hotside though, which makes since.
aps2fast4u is offline   Reply With Quote
Old 08-01-2007, 03:04 PM   #7
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
could even be the EBC the OP is using.. i don't think he commented as to what is controlling boost for his car.
Old 08-01-2007, 03:04 PM   #8
rjrutzky
Member#: 30367
2005 Legacy GT
NASA SE PTB Champ
It's a big ol' turbo on a 2 liter with honkin' cams. It's gonna be laggy.
You could:
go to a .63 hotside
go back to stock cams
swap in AVCS heads
All at a cost of peak HP though.
Those race gas numbers are sick, but I dunno how anyone affords C16 nowadays.
rjrutzky is offline   Reply With Quote
Old 08-01-2007, 03:07 PM   #9
aps2fast4u
Member#: 57871
2004 WRX
13.4 @ 102
Oh, I thought it was a 2.5L, that makes a lot more since.
Old 08-01-2007, 03:11 PM   #10
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
Originally Posted by rjrutzky View Post
.... I dunno how anyone affords C16 nowadays.
you should ask that question to the boys on the Supra forums
Old 08-01-2007, 03:19 PM   #11
rjrutzky
Member#: 30367
2005 Legacy GT
NASA SE PTB Champ
Nah, I'm too busy asking them how they can spend 60k on 10-15 year old cars I'll stick with my junky subie on cheapo 110 gas.
Old 08-01-2007, 03:20 PM   #12
dan avoN7
Top Scoob 002
Member#: 32771
03 Black WRX
04 White M3
a 3082R is a GT3040R.
I ran this turbo on a stock jdm 2.0 motor and had the same results as you. On 91 octane I was around 350whp at 21psi and on 104 octane at 28psi I made around 450whp (dynojet numbers). The turbo is meant for small displacement motors, not built 2.5's that can flow lots of air. Ditch the turbo and go with a 35R.
dan avoN7 is offline   Reply With Quote
Old 08-01-2007, 03:31 PM   #13
rjrutzky
Member#: 30367
2005 Legacy GT
NASA SE PTB Champ
axis stg5 is a 2.5L. I had my axis stages mixed up. I'll just go away now
Old 08-01-2007, 05:46 PM   #14
oneoverWRX
Member#: 74793
02 WRX
BLAZE YELLOW
yes it is a 2.5
It is a 3082r which is basically the same thing as a 3065 or a 3040. I got a 3082r from perrin....they sent me the compressor and chra i put an .82a/r off or a 3076r? I was wondering if i could use a 82 ar exhaust housing from a 35r to help. Othewise i will just sell this setup and buy a 35r.
Old 08-01-2007, 05:49 PM   #15
remowgn
Member#: 41149
09 FXT
SSM
Non-AVCS cams that big are definitely not going to help in the spool department.
remowgn is offline   Reply With Quote
Old 08-01-2007, 06:15 PM   #16
JF824
Member#: 71460
2007 WRX/STi
HTA Green 11.89 @ 119
I would say either port and change cams or just swap in AVCS heads
JF824 is offline   Reply With Quote
Old 08-01-2007, 06:45 PM   #17
DJIMPREZA
Member#: 1199
1994 Supra+1K, 22b
alike, 07STI
I have full boost from my gt3582r of my 2.5 crawford block and wrx heads with crower 272 cams and 3 inches intercooler piping etc.. at 3800-4000 rpms on 3th gear an above.. its a 10 second and coudl be driven in the street with no big deals with lag..
There must be something wrong there....
A gt30 on
DJIMPREZA is offline   Reply With Quote
Old 08-02-2007, 08:21 AM   #18
dug-e-fresh
Member#: 4568
10.7 @ 136, '02 WRX
13.4 @ 103, '09 spec.B
Yea, I am sure thats what he means.
def
dug-e-fresh is offline   Reply With Quote
Old 08-02-2007, 08:23 AM   #19
dug-e-fresh
Member#: 4568
10.7 @ 136, '02 WRX
He'll get 15 psi by 3800 or so. 20-22 psi (more than likely full pump gas boost) probably by 4200 or so.
def
Old 08-02-2007, 11:12 AM   #20
Master2192
Member#: 83254
98 2.5 RS
04 WRX
def
nah I looked it up after someone mentioned 3040R. Its pretty much a hybrid turbo, 40R compressor with a 30R exhaust. Its not an official garrett designation which is what threw me off.
Old 08-02-2007, 11:28 AM   #21
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
who tuned it?
Got a graph?
the lack of port work would probably help with spool being you have the big cams on there because it helps to keep velocity up.
Old 08-02-2007, 12:48 PM   #22
modaddict
Member#: 95840
sold to a good bud
awaiting next car
I considered the 3040 at one time, but all i found were negatives on it. the turbo hits boost threashold late, then you combine that with your lack of avcs, stock ported heads, and larger cams.....you just shifted everything right.
IMO, i don't think there is a problem......the problem is the "whole package".
I'd bet if you bought a true 35r, while you still will have later boost than most (not much) you'd be better off.
what header are you running?
edit: well, you have increased CR....so that SHOULD help out. huh?
modaddict is offline   Reply With Quote
Old 08-02-2007, 01:35 PM   #23
salt
Member#: 105055
2004 STi [email protected]
GT30R E85 22psi
Mods
Axis stg 5 8.8:1cr
No porting
Perrin 3082r kit
dual walbros
1000cc injectors
aem ems
Thanks
Did you remember to install the Valve seal on the tial wastegage ? it the silver ring in the far right? I know because I did this and my dyno looked like this:
http://forums.nasioc.com/forums/show....php?t=1233797
salt is offline   Reply With Quote
Old 08-02-2007, 02:43 PM   #24
flycaster
Member#: 60142
2011 WRX
Grey
So you had a pre-turbo exhaust leak. It must have had some sort of squeal - could you just not hear it over the engine/exhaust noise?
flycaster is offline   Reply With Quote
Old 08-02-2007, 02:45 PM   #25
oneoverWRX
Member#: 74793
02 WRX
BLAZE YELLOW
yes i am pretty sure that i did install that.
Would lean spool help? How lean can you go to make it spool faster?
Big Partout! - Axis Racing Head Package, Perrin 35R Turbo Kit, etc, etc SloRice MWSOC Private Classifieds 87 03-19-2008 04:15 PM
Big Partout! - Axis Racing Head Package, Perrin 35R Turbo Kit, etc, etc SloRice Engine/Power/Exhaust 84 01-18-2008 11:58 PM
Turbos Kits, Injectors, Perrin, HKS, Greddy, PE, Axis, Koyo & More Instock MauroMotorsports Engine/Power/Exhaust 18 12-24-2005 07:31 AM
HUGE Part Out-STI 6-Speed,Green,Perrin,FMIC,Header,TXS,APS,Axis motor+ More BLUETURBOWRX Mid West Subaru Owners Club Forum -- MWSOC 23 02-14-2005 09:29 PM
tmic & green vs untimate racing stg5 t-kid Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 03-06-2004 08:45 PM
