Welcome to the North American Subaru Impreza Owners Club Wednesday September 2, 2015
Old 12-06-2012, 12:23 AM   #3101
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
Mine has several recalls on it and I refuse to take it in for any of them. Too many opportunities for them to screw stuff up. I just drive with gas spraying all over the place a few times a year.
Superorb is offline   Reply With Quote
Old 12-09-2012, 07:31 PM   #3102
beauhawk
Member#: 71019
Just moved to Denver from the southeast. Car hasn't seen cold in years. Now under the driver's side intake manifold I have a puddle of gas.
beauhawk is offline   Reply With Quote
Old 12-10-2012, 12:16 PM   #3103
OBP WRX
Member#: 330185
2005 WRX - strong gas odor on cold days...enough to cause nausea. I live in Omaha, NE so I can expect this for several months out of the year!
OBP WRX is offline   Reply With Quote
Old 12-10-2012, 12:47 PM   #3104
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
Welcome to Colorado We moved to Denver from the SE too (FL and then NC). My 02 leaks fuel and my wife's 03 leaks as well, but it's easily fixed every year with a turn of an easily accessed screw.
Old 12-11-2012, 01:09 AM   #3105
Ammata
Member#: 155819
2004 Impreza WRX
Just double up on the clamps on your fuel lines that go to the fuel rail.....I had the same problem, fuel would actually drip from one or two on the lines. Just check and see where it's dripping from
Ammata is offline   Reply With Quote
Old 12-11-2012, 01:48 PM   #3106
rotian28
Member#: 259164
2003 WRX Wagon
i get about the same on my 2002 with 170xxx miles. it happens mostly when cold but sometimes when its 50-60 degrees out. i happen to enjoy the smell. my passengers do not
rotian28 is offline   Reply With Quote
Old 12-11-2012, 10:41 PM   #3107
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
Except that for many the intake manifold needs to be removed to get to the problem hoses. On my wife's 03 Forester I was able to easily tighten the loose screws. Can't get to them on my car, and gas literally sprays when it's cold and I live in Denver where it gets COLD.
Old 12-13-2012, 12:39 PM   #3108
SkiWrex
Member#: 142559
02 PSM
Wagon VF39'd
Originally Posted by XRW URABUS View Post
Keep us updated on this. The dealer should pay for parts they break. They usually do. It shouldn't cost you a dime.
I think the dealer is trying to pass the broken parts under warranty so as not to eat the cost.
One thing that irked me was after they put the WRX back together again, there were hoses not installed correctly, fasteners not plugged back in, lucky I spotted it.
It's like fighting the mob....I have a good friend who used to work for this particular dealer and he basically said it sucks, but fighting it will get you nowhere, and on the plus side, the fuel rail warranty covered all the labor on those other parts, which would have been around $1000.
The dealer gave me a box containing all the old parts and a lot of them weren't actually broken, but completely worn out and needed to be replaced anyway, and the dealer doesn't really want to leave them to break and have a customer come back claiming it was their fault. So I can kind of understand where they're coming from, but dam it still sucks shelling out $300 right before Christmas lol.
SkiWrex is offline   Reply With Quote
Old 12-13-2012, 07:19 PM   #3109
blackfang
Member#: 131347
2007 Legacy 2.5i SE
98 Z/28, VN 900 custom
This.
Too many people who feel entitled to something are quick to blame someone when it is just an unfortunate circumstance that neither party caused. Sadly this causes establishments to go above and beyond to protect themselves even if it means making a customer unhappy, but such as life.
blackfang is offline   Reply With Quote
Old 12-13-2012, 10:28 PM   #3110
N-Bomb
Member#: 309465
1999 GC + ver 9 swap
Silverish
Hey all, I wonder if someone can help me out.
I've had a fuel smell issue for a while now. Basically it appears whenever the HVAC is on vent and stationary or moving at a slow speed. Not so bad at highway, but still evident.
Not evident at all when HVAC is on recirc. Is there any method to pin point where this is coming from? I'd assume somewhere near the cowl where the HVAC intakes from, but... I'm still a nub w/ the fuel system. Definitely NOT the tank or exhaust.
Car is tuned to run a bit rich, also is hard to start sometimes, but not sure if these are related.
Thanks!
N-Bomb is offline   Reply With Quote
Old 12-13-2012, 11:35 PM   #3111
XRW URABUS
Member#: 21974
Thanks!
It's coming from the fuel rail lines in the engine compartment and always rears it's ugly head in the winter when the rubber fuel lines start to shrink and seep from the cold weather.
If I remember correctly, the recall has a special repair kit that pretty much replaces the rubber fuel line with a longer one to prevent the winter shrinkage and seepage.
It's time to have that repaired.
XRW URABUS is offline   Reply With Quote
Old 12-14-2012, 01:36 PM   #3112
N-Bomb
Member#: 309465
Silverish
Aha, I should've mentioned that this was a summer problem, and hasn't just reared its head recently.
Old 12-16-2012, 09:46 PM   #3113
AOS
Member#: 328477
2005 Impreza WRX STI
fixed my problem
searched everything but youtube..... (facepalm)
AOS is offline   Reply With Quote
Old 12-17-2012, 10:05 PM   #3114
ToyWRX
Member#: 340784
2003 WRX Wagon
Default Fuel leak - 2003 WRX
About a week ago I noticed the raw gas smell in my 2003 WRX wagon on cold starts. Under the hood it seemed to be coming from the passenger side under the intake area. I'm glad I found this thread - I stopped by the local Subaru dealer today and they ran my VIN and they're pulling the intake and replacing the fuel lines for free under the extended Subaru warranty/recall.
Thanks to everyone who contributed to this thread - much appreciated!
ToyWRX is offline   Reply With Quote
Old 12-18-2012, 07:19 PM   #3115
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
Let us know how it goes once you have your car back.
Old 12-29-2012, 01:56 AM   #3116
black_subie730
Member#: 193074
2002 WRX SW
my 02 wagon just started doing the same thing, it seem to be coming from under the intake manifold...my question is if it has never been taken in for a recall would they still do it eventhough its an old recall?
black_subie730 is offline   Reply With Quote
Old 12-29-2012, 02:04 AM   #3117
sajohnson
Member#: 6140
2002 WRX 5MT Sedan
WR Blue. Cobb Stage 2
See post #3114 above yours. It should be covered.
There is a time limit on recalls -- I think it may be 10 years, so get it done ASAP.
Good luck.
sajohnson is offline   Reply With Quote
Old 12-29-2012, 02:08 AM   #3118
black_subie730
Member#: 193074
2002 WRX SW
^ thanks!
Old 12-29-2012, 02:09 AM   #3119
black_subie730
Member#: 193074
2002 WRX SW
thanks!
Old 01-02-2013, 05:02 PM   #3120
HonduhPowa
Member#: 269076
2005 Wrx Premium
Just started noticing this as it got colder here in Michigan. I ONLY notice it when i start my car in the morning and let it warm up before i leave for work. As soon as i drive away, the smell goes away.
Vehicle: 2004 Subaru Wrx
Mods: Sti block w/wrx heads, gt30r turbo, 850cc injectors, etc.
Idk if my year falls into the recall, i could only find it for 02-03 Wrx but even if I am in the recall, idk if they will honor it with my modifications done to the car.
HonduhPowa is offline   Reply With Quote
Old 01-02-2013, 05:40 PM   #3121
Karnage03Rex
Member#: 213695
2005 WRX
Wondering if the raw fuel smell will have the dealer blame my downpipe or if the 05 wrx is even covered. Anyone hit these aftermarket issues?
Karnage03Rex is offline   Reply With Quote
Old 01-03-2013, 04:45 AM   #3122
Benhart21
Member#: 149617
They only acknowledge it being a problem for '02/'03s. I don't believe they even cover all '03s. They sure as hell don't acknowledge that other models, like my Baja turbo and Forester XTs and such. I'll be picking up one of the fix kits soon because the smell on mine is becoming unbearable.
Benhart21 is online now   Reply With Quote
Old 01-03-2013, 05:40 AM   #3123
black_subie730
Member#: 193074
2002 WRX SW
any of u guys know what the kit is called or part numbers for the kit? thanks
Old 01-03-2013, 12:29 PM   #3124
Cocoa Beach Bum
Member#: 17355
It's described in this bulletin related to the WVK-21 recall:
http://www-odi.nhtsa.dot.gov/acms/cs...9V468-1307.pdf
Description: WVK21 Repair Kit
Part Number: 10130AA000
Note that the bulletin above indicates that SOA will apply the WVK-21 fuel leak fix for free on any 2002-3 WRX with no questions asked (i.e. dealer doesn't need to duplicate the problem). However, that deal only lasts while the car has been "in-service" for less than 12 years. Deliveries of the 2002 WRX began on Mar 15, 2001, so time will run out on Mar 15, 2013 for some of the first-delivered 2002 WRX cars.
If you have a 2002-3 WRX, see your dealer NOW.
SUBARU IMPREZA WRX ENGINE FUEL LINE EXTENDED WARRANTY
PROGRAM
Subaru has initiated an Extended Warranty Program for certain 2002 – 2003 model year
Impreza WRX models. Extended warranty coverage has a 12 year/unlimited mileage duration
and is limited to replacement of the engine fuel delivery line/hose to correct the fuel seepage
condition previously described. Warranty coverage begins on the date the vehicle was delivered
to the first retail purchaser. If the vehicle was used as a demonstrator or company vehicle
before being sold at retail, warranty coverage begins on the date the vehicle was first placed in
such service. All other warranty terms and conditions, including exclusions, will continue to
apply.
Note: Dealers do not have to duplicate this condition to have the repair covered by this warranty.
An owner complaint of fuel smell from the engine compartment unrelated to any other
problem is sufficient for coverage.
Cocoa Beach Bum is offline   Reply With Quote
Old 01-03-2013, 05:54 PM   #3125
he_is_legend
Member#: 125796
03 Built BugI SOLD
AW
Spoke to SOA 10 min ago. Getting warranty extension to replace fuel line with absolutely NO CHARGE. Warranty extension is until 2015 on 2003MY. Was given a Case# to go up against the dealer(s) if any problems should occur. I would reccommend any/all 02-03 owners to contact SOA & do the same process.
Whole call only took 12 minutes.
he_is_legend is offline   Reply With Quote
Raw Fuel Smell Inside Cabin - WRX Kenneth2000 Warranty Issues & SOA Problems 13 12-21-2012 10:28 PM
Raw Fuel Smell/Leaking Fuel Line on WRX pumpkyn Rocky Mountains Impreza Club Forum -- RMIC 39 02-09-2009 11:50 PM
Raw Fuel Smell.... Rebellion South East Region Forum 7 01-25-2005 09:48 AM
Raw Fuel Smell Giljorak Rocky Mountains Impreza Club Forum -- RMIC 10 03-08-2002 07:03 AM
