Old 08-02-2007, 01:57 AM   #1
railguy
Member#: 53756
Default How do you unflood a motor?
I just recently finished up my diesel turbo motor, and I have 1000cc injectors being controlled by utec, welll I had to get oil to the turbo so I disconnected the crank and cam sensor and cranked motor over. Well, ofcourse I flooded the motor, how do you unflood it? OR should I just go with new plugs. And dont worry once the car is up and running I will be having pics and everything else.
railguy is offline   Reply With Quote
Old 08-02-2007, 02:01 AM   #2
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
The quick way...
Doesnt leave much though....
Usually when a motor is flooded, you simply floor it with no electronics/whatever hooked up to give more fuel (floored to allow maximum air flow) and turn it over for a few minutes giving it time to rest....
Then try it normal...
Good luck.
Old 08-02-2007, 07:43 AM   #3
Legacy_H6TT
Member#: 137502
1990 Legacy GT-t
Blue over silver
You sure its a diesel?
Legacy_H6TT is offline   Reply With Quote
Old 08-02-2007, 10:25 AM   #4
railguy
Member#: 53756
the turbo is......................yea, i tried flooring it and if i push pedal in and out it would stutter but not fully connect and start up, i will let it sit for 1 day and try it, if not i will be putting in new spark plugs.........
Old 08-02-2007, 10:53 AM   #5
White out
Member#: 46277
** LP640
Viper GTS
Pull the plugs and manually crank over the motor. Or disconnect the fuel pump's power, pull the plugs and crank. Afterwards, when you start the car, just put a video camera 10ft behind the car and post up the results.
Nick
White out is offline   Reply With Quote
Old 08-02-2007, 01:45 PM   #6
Member#: 106514
Next time pull the ECU and then crank.. this will allow the car to crank with all sensors plugged in, and not inject fuel or spark.
Simply pulling the plugs and crank the engine over by hand, once most of the fuel is out you can crank the engine over with the starter (the way I mentioned above) will de-flood your engine.
You want to get the fuel out and not let it sit inside the cylinders and seep into your oil.
- J.
Jeremy@Cobb is offline   Reply With Quote
Old 08-02-2007, 07:39 PM   #7
noisycricket
Member#: 148043
Maybe I'm missing something, but if you disconnect the crank and cam sensors, the computer wouldn't be injecting any fuel either.
i have *never* had a problem with flooding when I'd crank with the crank position sensor disconnected on any car, Subaru or not.
noisycricket is offline   Reply With Quote
Old 08-02-2007, 08:46 PM   #8
jays05
Member#: 78165
05 STI 35r + e85
You can simply pop out the ignition fuse.
jays05 is offline   Reply With Quote
Old 08-02-2007, 10:35 PM   #9
Brydon
Member#: 107569
1998 Forester S
SRP
Or hold the pedal wide open. This shuts the injectors off at crank but leaves the ignition going. Should clear up the fuel.
Brydon is offline   Reply With Quote
How messed up do you think this motor is? (big pics) Crashsector Pre-2002 Factory Turbo Powertrain 10 10-13-2007 07:19 PM
How do you think this guy blow his motor? Sti 04 chrisfromalbany General Community 13 07-20-2006 12:14 AM
how do you find timing on a ej 257 05 sti motor? caser Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 02-26-2006 06:15 PM
Guys: how do you trim 'down there' and ladies: how do you prefer it? rex n effect Off-Topic 84 04-09-2004 08:21 AM
How do you build up a motor to handle high G turns & lots of HARD driving? thebusiness999 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 03-05-2003 11:44 AM
