Old 08-02-2007, 07:27 AM   #1
saintluciascooby
Member#: 109527
1997 GC8 [email protected]
blue
Default Ram air Turbo intake
I have designed a ram air intake for my turbo setup with a metal screen cartridge. this intake goes from where one of the headlights used to be to the turbo.
I am concerned if this is not such good idea since at high speed you will be creating a posative pressure (maybe) on the inlet side of the turbo.
The benefit is a nice cold air charge to the turbo which here in St lucia is very desirable.
Since the picture below was taken I have smoothed out the intake pipe before the turbo.
Has anyone done this before and can give some input?
saintluciascooby is offline   Reply With Quote
Old 08-02-2007, 10:56 AM   #2
White out
Member#: 46277
** LP640
Viper GTS
minus bugs, rocks, and debrit, I don't see any issues with that.
Nick
White out is offline   Reply With Quote
Old 08-02-2007, 11:26 AM   #3
boostdog
Member#: 149752
2017 wrx
ICE ICE BABY SILVER!
i personally would create some sort of a screen on it to keep the turbo from eating anything it should not but it looks nice! You could use ( the tech word is escaping me now) a bell shaped piece which would help with the positive pressure issue.
boostdog is offline   Reply With Quote
Old 08-02-2007, 01:50 PM   #4
cdigerlando
Member#: 6070
2015 STi
Dark Gray Metallic
Default Your Racecar
I saw a setup similar to this on a 1000HP Supra not too long ago. They used a screen to keep out major debris. I think it is a great idea. Your boost controller should negate any fluctuations due to positive pressure on the suction side of the turbo. Obviously I don't think this is a good setup for a street car. I might consider having two headlights and a filter for a street car.
cdigerlando is offline   Reply With Quote
Old 08-02-2007, 03:33 PM   #5
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
12 Legacy GT 13 Armada
Velocity stack maybe or anti surge turbo housing.
I seem to remember a friend doing an experiment a long time ago using the stock GC8 scoop to see if he could make boost using a ram air setup. I don't remember exactly what happened but it didn't even equalize pressure to 0 much less make positive pressure.
If this is an all out drag car which will only be used on the track (looks like it is) the screen should do. If you plan on driving it to car shows or on the street frequently you should definitely find a way to stick a filter in there.
MY99 2.5GT is offline   Reply With Quote
Old 08-02-2007, 03:39 PM   #6
AWDPirate
Member#: 131427
yeah def. put a screen or a clear filter or something in there. if it rains your probably f*cked, other than that any gains?
AWDPirate is offline   Reply With Quote
Old 08-03-2007, 12:24 PM   #7
boostdog
Member#: 149752
2017 wrx
yes velocity stack that's what i was referring to. thanks!
Old 08-03-2007, 12:32 PM   #8
saintluciascooby
Member#: 109527
blue
There is a cartridge with two metal sceens in the intake and as its used for a drag car only and in the west indies, if theres rain then no racing
Old 08-03-2007, 03:50 PM   #9
hotrod
Member#: 14141
2002 Impreza WRX
Yes, at speed you will be creating a small positive pressure at the compressor inlet.
Why would you think that that would be a bad thing?
Since pressure recovery for ram boost is never perfect you might get 60%-70% of theoretical ram boost.
At 100 mph 100% recovery would be about 0.17 psi ram, so you will see about 0.12 psi ram as you trap.
This is compared to the -0.5 psi to -1 psi you would see on a conventional intake with air filter. On a drag only car it is a good mod.
Larry
hotrod is offline   Reply With Quote
Old 08-06-2007, 09:26 PM   #10
AugustusMaximus
Member#: 63060
0005 RS, 92X
silver, red
Tell us something about your intake manifold, it looks interesting!
AugustusMaximus is offline   Reply With Quote
Old 08-06-2007, 10:24 PM   #11
saintluciascooby
Member#: 109527
blue
I dont have a current pic since the car in a container on another Island waiting for a drag event.
But it is fabricated from 4" pipe with a tubular cartridge containing 3 metal screens. course, med and fine. the screens are backed by several cross braces to eliminate a colapse into the turbo in case of a large foreign object injestion (sp?).
Since that picture the intake pipe to the turbo has been smoothed considerably.
intake temps have dropped between 10-20 deg F from before so I think it is worthwhile . It required a fairly substantial increase in fueling to maintain A/F at top end from the old airfiter intake so there should be some extra horses there now.
I was just worried I might damage the turbo long term.
Turbo XS / Prodrive short ram air intake F/S 19-Kilo Engine/Power/Exhaust 5 12-24-2007 05:58 PM
hack CAI to make ram air style intake? SLowery Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 02-13-2003 09:28 AM
ram air intake vs cold air intake Shaji Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 62 07-21-2002 09:05 PM
Beer + Boredom = true ram air NA intake Daveish Normally Aspirated Powertrain 30 05-05-2002 04:37 PM
Cold-air/Ram-air intake from hood vent (not scoop)? Fred Fredburger Normally Aspirated Powertrain 31 03-21-2001 11:13 AM
