Old 08-02-2007, 05:41 PM   #1
sgmongoose
Member#: 123731
01 2.5rs/ 03 TL-S
white/silver
Default need help! can't read ecu thru ECUFlash
help!
im trying to read my ECU through ECUFlash and it keeps giving me an error...i have the green connectors connected, the fans cycle on and off and the check engine light flashes. any idea what is wrong? i should mention this is a 04 engine and ecu in a 01 coupe. here is what it says in the logs
[03:08:57.109] Version 1.30.1095
[03:08:57.109] 8 memory models read.
[03:08:58.234] 145 ROM metadata models read.
[03:08:58.234] checksum module "subarudbw" loaded.
[03:08:58.234] flashing tool "wrx02" loaded.
[03:08:58.234] flashing tool "wrx04" loaded.
[03:08:58.234] flashing tool "sti04" loaded.
[03:08:58.234] flashing tool "sti05" loaded.
[03:08:58.234] flashing tool "mitsukernel" loaded.
[03:08:58.234] flashing tool "mitsukernelocp" loaded.
[03:08:58.234] flashing tool "mitsubootloader" loaded.
[03:09:19.109] SSM2 init
[03:09:19.281] [FF] A2 10 0F 1B 14 40 03 05 73 FA EB A2 2B C1 02 AA
00 10 00 60 CE 54 F8 B0 E4 00 00 E0 00 00 00 00
00 DC 00 00 45 10 00 00 02 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00
[03:09:19.296] SSM2 ECU ID is 1B 14 40 03 05
[03:09:19.296] SSM2 cmd_0x81
[03:09:33.171] SSM2 init
[03:09:33.359] [FF] A2 10 0F 1B 14 40 03 05 73 FA EB A2 2B C1 02 AA
[03:09:33.375] SSM2 ECU ID is 1B 14 40 03 05
[03:09:33.375] SSM2 cmd_0x81
any ideas?
sgmongoose is offline   Reply With Quote
Old 08-02-2007, 06:27 PM   #2
WeldingHank
Member#: 98645
2002 WRX Wagon
do you have the blue flash block connected?
WeldingHank is offline   Reply With Quote
Old 08-02-2007, 07:08 PM   #3
sgmongoose
Member#: 123731
01 2.5rs/ 03 TL-S
white/silver
i tried with and without the flash block, both had the same results. altho i was under the impression that the flash block was only needed when flashing not reading
Old 08-02-2007, 07:19 PM   #4
Tea cups
Member#: 103136
The ecu id that it is returning shows that to be an 02 ecu (with an early rom revision). Since you say that it is an 04 motor, you were probably choosing the incorrect read method. Try the read method for the 02 wrx. If that doesn't work then 99% of the time those with motor swaps don't have the obdii port wired correctly.
Tea cups is offline   Reply With Quote
Old 08-02-2007, 07:33 PM   #5
t4nk
Member#: 129905
2005 WRB WRX
2003 F-350SD, 7.3PSD
+10000
t4nk is offline   Reply With Quote
Old 08-02-2007, 07:34 PM   #6
sgmongoose
Member#: 123731
01 2.5rs/ 03 TL-S
white/silver
interesting, the flash block for the 04-05 ecu is whats there tho, i guess i'll try again with it as an 02 wrx, thanks
Old 08-02-2007, 07:34 PM   #7
sgmongoose
Member#: 123731
01 2.5rs/ 03 TL-S
white/silver
and wiring was done by ECS so i would hope that its done correctly
Old 08-02-2007, 07:39 PM   #8
sgmongoose
Member#: 123731
01 2.5rs/ 03 TL-S
white/silver
you guys are my hero's!
i worked! i was getting worried that the wiring was f'd up, then i would be sitting on all my stage 4 parts and have no way to tune it!
Old 08-06-2007, 05:55 PM   #9
PumpsGOTAWD
Member#: 33175
1998 Impreza 2.5RS
98 Unicorn EVO Killer
Never doubt ECS!!
PumpsGOTAWD is offline   Reply With Quote
Old 08-08-2007, 11:58 AM   #10
sgmongoose
Member#: 123731
01 2.5rs/ 03 TL-S
white/silver
it was only for a split second
EcuFlash error message/can't read ecu. bluert Open Source Reflashes 7 08-12-2009 06:40 PM
Can't read ECU jarencibia Open Source Reflashes 2 10-17-2008 11:48 AM
Problem reading ECU with ECUFLASH Subyroo2.5 Open Source Reflashes 3 02-10-2008 10:02 AM
Need Help....Can't Get into 5th Gear!?! ScreaminFast Newbies & FAQs 3 01-24-2003 12:40 AM
Up pipe stud broke need help can't find anywhere fatray Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 10-15-2002 02:32 AM
