Old 08-02-2007, 08:40 PM   #1
BallzToTheWallz
Member#: 128949
2004 VF22 WRX hybrid
JBP 306 whp 366wtq
Default NEED HELP!! .Doing a USDM EJ257 shortblock in my 04 WRX.
Hi guys i recently threw a rod in my 04 WRX and plan on doing a ej257 shortblock with the EJ20 heads with a helix cam and valve train package, a vf22 turbo with 565cc injectors and fuel pump,. What else am i going to need? cam sprockets? a ECU? Wiring harness? Do i buy an STI clutch or a WRX clutch?
BallzToTheWallz is offline   Reply With Quote
Old 08-02-2007, 10:01 PM   #2
Damon
Member#: 2902
this should help some. someone was kind enough to point me towards this when i asked a similar question.
http://elementtuning.com/technical/ej25_install.htm
Damon is offline   Reply With Quote
Old 08-02-2007, 11:09 PM   #3
robbieshonda
Member#: 122306
2002 Sti PTE 6262
Interlagos Blue 551/441
use your stock cam sprockets(everything is the same size) you can use your stock wrx ecu with a tune, and harness, and a clutch for the tranny that you will be running,, 5speed or 6 speed.
robbieshonda is offline   Reply With Quote
Old 08-03-2007, 07:40 AM   #4
BallzToTheWallz
Member#: 128949
JBP 306 whp 366wtq
Okay thats all useful. At the bottom of that webpage it says that you need to have your ECU tuned. should i have that done before i finish my build or after. Im pretty sure i can do it after because im going to need to break in the new shortblock for around 3000 miles. Is it even possible to have my ECU tuned without having it plugged into the car. Sorry if these questions are all newbish. Its my first time doing this stuff.
Thanks for alll your help
John
Old 08-04-2007, 12:32 PM   #5
jinsing7
Member#: 92431
2011 Lexus CT200h
Talk to your tuner and have them put a break in tune on it after it is built. The car will start with the stock ecu. Don't drive around giving it any boost until you get it tuned... or until it's broken in for that matter Drive on that for about 1k miles then get dyno tuned.
jinsing7 is offline   Reply With Quote
Old 08-31-2007, 07:02 AM   #6
kelsey
Member#: 157592
02 Impreza
blk
Default Help also
I know this has nothing to do with YOUR build,but I live around the WV,KY,Ohio area and I am new to Subaru's. Do you have a shop or person you all would recommend to do rebuilds,(stock) on these cars? Thanks Sorry jsut wondering. No one answered my other thread. thansk..Mike
kelsey is offline   Reply With Quote
Old 08-31-2007, 11:11 AM   #7
Acostafan
Member#: 67398
2002 Now with 100%
RDA of 2.5l Goodness!!!
The stock ECU will run the car just fine for around town driving. I wouldn't romp on it too much though. I've got on it a few times with no problems, but you can tell it needs a tune. Got 1,000 miles on mine so far with no issues. I'm going to go back to the valet map just to be safe until I can get a tune.
Acostafan is offline   Reply With Quote
to do a 2.5 hybird on my 04 wrx wrxdrivr04 Built Motor Discussion 8 02-11-2009 08:22 PM
05 sti hvac in my 04 wrx help!! please sdkenny Electrical & Lighting 3 12-27-2008 12:23 PM
Come help me install an Avic-F90BT in an 04 WRX in NJ? 04 WRX (NJ) Tri-State Area Forum 4 11-05-2008 05:10 PM
Using 05 USDM STI Suspension in 02-04 WRX kahtep Brakes, Steering & Suspension 15 01-02-2006 10:57 PM
need help on location of pcv valve on my 04 subaru awdguy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 19 11-10-2005 03:46 PM
