Old 08-02-2007, 09:06 PM   #1
AXA
Member#: 35566
2002 STI WRX GT30R
WRC Blue
Default OpenECU GM map Calibration numbers Help..
I need a 3 bar GM map Calibration number for WRX 02 so I can take out my stock map and replace it with this one.....
I will be using a tetrixcable with flashecu software to make the change........
If somebody can give some pointer to how to do this, I will appreciated very much ...
No very familiar with ECUflash software....
Thanks in advance
Jose
AXA is offline   Reply With Quote
Old 08-03-2007, 08:35 AM   #2
akira02rex
Member#: 82612
2015 WRX STI
Ice Silver Metallic
I've never seen anyone do that before...
You can be the guinea pig.
akira02rex is offline   Reply With Quote
Old 08-03-2007, 09:05 AM   #3
ERIKBROCKHOFF
Member#: 142599
Are you speaking of a gm BCS?
ERIKBROCKHOFF is offline   Reply With Quote
Old 08-03-2007, 10:25 AM   #4
rewt
Member#: 60794
2007 Solstice GXP
No, he's talking about a GM 3-bar MAP sensor.
To the OP:
I looked around for a solution for a while, and I believe some of the developers have found the place(s) in the ROM that need to be modified to run a higher resolution MAP sensor.
Beyond that, i.e. actually modifying the code, I wasn't able to find many answers. Good luck.
rewt is offline   Reply With Quote
Old 08-03-2007, 12:18 PM   #5
Tea cups
Member#: 103136
The latest Enginuity ecu definitions allow you to modify MAP sensor scaling for both 16bit and 32bit ecus.
Tea cups is offline   Reply With Quote
Old 08-03-2007, 12:37 PM   #6
AXA
Member#: 35566
2002 STI WRX GT30R
WRC Blue
To the OP:
Thanks any way....
Let see if I can find it.... if not I will have to cut my harness and do it the old way using my UTEC...
Jose
Old 08-03-2007, 01:37 PM   #7
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
I have rescaled the MAP sensor in the ECU but for a TurboXS 4BAR sensor.
here is a bit of information
http://www.enginuity.org/viewtopic.php?t=1392&start=15
Pretty much you are going to have to test the voltage output of the sensor at vacuum and boost to get the psi-->voltage multiplier and offset to get it to read correctly.
Old 08-03-2007, 04:16 PM   #8
AXA
Member#: 35566
2002 STI WRX GT30R
WRC Blue
Thanks....
I will check out the link with the info....
Old 08-29-2007, 09:26 PM   #9
jays05
Member#: 78165
05 STI 35r + e85
Bump, does anybody have a calibration for the gm 3 bar map sensor? I searched everywhere... I have mine dialed in sorta ok, but if somebody has a working calibration, it'll save me a lot of time.
jays05 is offline   Reply With Quote
Old 08-30-2007, 05:20 PM   #10
crazymikie
Member#: 56321
2006 Honda El Camino
Green
I've been told that the consistency from unit to unit on the GM 3 bar MAP sensors isn't great, so the calibration that works for one unit, may not work for another unit.
What I would do is install the unit in parallel with the stock MAP sensor and run the 5v output to the fuel level input in the ECU (should be 5v ADC). Log MAP and voltage on fuel level and you should be able to calibrate the sensor accurately since you can use the boost readings from the stock map sensor and the voltage readings from the GM.
I have two at home. If I find some time, I'll try to hook them up and get some data to post up.
Mike
crazymikie is offline   Reply With Quote
Anyone know the stock map sensor calibration numbers for UTEC? texas05sti Texas Impreza Club Forum -- TXIC 6 11-17-2007 11:33 AM
GM 3 bar MAP sensor install help DemiSlayer UTEC 0 10-17-2007 10:47 PM
Enguinty or OPENECU Map for Hybrid - HELP? Fongers Built Motor Discussion 13 08-11-2007 06:09 PM
05STI DTEC wiring map and calibration tips HELP PLEASE mitzo Engine Management & Tuning 10 06-02-2007 10:26 AM
MAP calibration in a UTEC? big_adventure Engine Management & Tuning 4 08-20-2003 11:16 AM
