Welcome to the North American Subaru Impreza Owners Club Saturday February 6, 2016
Old 12-25-2007, 03:18 PM   #1
kheff46
Member#: 66739
2002 WRX wagon
Talking 2.5 DOHC compatible intake manifolds/fuel rails
can someone provide a small list of intake manifolds/ rails that will bolt up to a set of 2.5 DOHC NA heads?
i need something semi cheap but still worthy. i hate buying junkyard engines for parts. so i'd like to look here for the newest compatible manifolds and rails sets.
i can try and start things off,
-EJ20G
-V4 STi/WRX
-02 WRX? anyone? too new?
kheff46 is offline   Reply With Quote
Old 12-25-2007, 03:58 PM   #2
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
The NEWEST would be from the '99 Legacy Outbacks as they still run the 2.5L DOHC heads. I'm not sure if this is the same for the '99 Legacy 2.5GT.
96-99 Legacy 2.5GT
97-99 Legacy Outback
97-98 Forester
98 Impreza 2.5RS
FuJi K is online now   Reply With Quote
Old 12-26-2007, 10:50 AM   #3
kheff46
Member#: 66739
2002 WRX wagon
"STORM"-
any pre 01 DOHC with inline(not opposed) bolt/mount holes should work fine.
so that excludes my thoughts on 02 WRX.
--keith
Old 12-26-2007, 12:33 PM   #4
RS22b
Member#: 5413
#15 2-Subaru
Rally Cars !!! Fiesta!
99 GT is the same Fuji.
RS22b is offline   Reply With Quote
Old 12-26-2007, 03:46 PM   #5
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
And ANY 89-96 EJ20G, 97-98 EJ20k and any of the EJ20h or Ej20r twin turbos from 94-98. As was mentioned, it's about the inline bolt holes. The spacing was the same on every single variant with inline bolt holes...
Old 12-26-2007, 08:43 PM   #6
kheff46
Member#: 66739
2002 WRX wagon
so with that in mind.....
and kind of related...
will that manifold match the heads on the newer 205/207/257 variants? i would like to replace the EJ255 at some point with the newest baddest subaru offering(257 in case you wondered).
--keith
Old 12-26-2007, 09:55 PM   #7
Matt Monson
Member#: 832
99 2.5RS, '85 911
Wink
Nope. Basically none of the "numbered" engines' heads will mate to that inline manifold. The ej251, ej205, ej257,eje07, etc. Starting in '99 most engines went to an offset bolt pattern. However,as I hinted in my pm to you earlier the dohc ej25d heads have excellent flow and there's really very little reason to "upgrade" your heads later just for the sake of upgrading. Do a little digging and you will find the Cobb benchflow numbers I have posted that show the ej25d heads outflowing the ej205 heads by 10 percent or so...
Old 12-27-2007, 10:52 AM   #8
kheff46
Member#: 66739
2002 WRX wagon
matt- sorry, i had a brain fart at work.
i meant will those heads match up to all the newer EJ variants. not the mani. i already confirmed thru you that matches the heads fine. i meant will the heads fit the 257(which you already confirmed also).
work caused this brain fart. maybe i should not go in anymore? again, sorry bout the retardedness displayed earlier in posting
--keith
Old 12-27-2007, 12:04 PM   #9
Matt Monson
Member#: 832
99 2.5RS, '85 911
Those heads will match up to any of the Ej22 or Ej25 variants. I wouldn't put them against and Ej20 because of the bore differential, but some others around here disagree with me. BTW, another good cheap turbo build is to use the Ej25 heads against an Ej22 NA block. Depending on which exact heads and which phase of block, you end up somewhere in the mid 8's for compression. If I ever get around to building an engine to use with my supercharger it's going to be an Ej22E bottom end with my ported SOHC Ej25 heads. Right now, I am just shopping for a car again. That reminds me, I need to update my signature...
Old 12-27-2007, 03:13 PM   #10
kheff46
Member#: 66739
2002 WRX wagon
yeah me too. mine still says OBS-T(T is for turd right now. not turbo!)
i heard that idea before. bigger head area via 2.5 with the 2.2 bore is like 2.3~ and 8's for CR is great for mild turbo.
forgot about that idea til you mentioned it again.
--keith
Old 12-28-2007, 04:39 AM   #11
Rikshaman
Member#: 90817
Hey kheff, i got a 20k manifold sitting in my closet. Its complete, you interested?
Rikshaman is offline   Reply With Quote
Old 12-28-2007, 10:05 AM   #12
Matt Monson
Member#: 832
99 2.5RS, '85 911
What do you want for it? I won't snatch it out from under Keith, but if he passes I might be interested as long as the price is right. That guy on 25rs.com com asking $300 for one is on crack.
Old 12-28-2007, 10:40 AM   #13
kheff46
Member#: 66739
2002 WRX wagon
MATT! don't touch it......
i would like to take that off your hands if the price is reasonable as matt stated. what would you like to get 4 it shipped to 44275(spencer ohio)? thanks!
--keith
Old 12-28-2007, 11:26 AM   #14
Storm
Member#: 5218
96L Most Over-
Developed Beater
Lemme know if you get that manifold Keith....I'll make up an EGR blockoff plate for it.
Jay Storm
Old 12-28-2007, 04:49 PM   #15
kheff46
Member#: 66739
2002 WRX wagon
will do! i have yet to recieve a reply from my PM that was sent this A.M.
--keith
Old 12-29-2007, 03:22 PM   #16
kheff46
Member#: 66739
2002 WRX wagon
still no reply. anothe PM has been sent. still searching....
--keith
Old 12-29-2007, 03:48 PM   #17
Storm
Member#: 5218
96L Most Over-
Developed Beater
Take a look on RS25.com when it comes back up. Or even some of the Legacy forums and ultimatesubaru.org......
Someone's gotta have something for you.
Jay
Old 12-29-2007, 04:24 PM   #18
Spilner
Member#: 63977
2005 STi
I'm assuming modded wrx injectors would work in dohc fuel rails
Spilner is offline   Reply With Quote
Old 01-02-2008, 06:06 PM   #19
kheff46
Member#: 66739
2002 WRX wagon
found one on rs25.com, but need verification on it!
what are the differences between the DOHC intake manifolds from LGT's/RS's/forester's? evap and coil packs? what are swappable between themselves or totally NOT interchangeable. please advise!
im having STORM build me a DOHC engine(since he's holding and im in need), and trying to make sure i don't buy the incorrect intake manifold for it. im pretty sure the engine/heads are from a 98 RS. not 100% but i can ask jay if i need to. he's just not on right now!
please list the differences, and any mods done to other mani's to make them work, etc.
THANKS!
--keith
JDM (EJ20H) Intake Manifold, Fuel Rails, Injectors + IAC - COMPLETE BoostAddictPL Engine/Power/Exhaust 1 10-04-2011 11:52 PM
FS:(CO) Wrinkle Red TGV delets, Intake manifold, Fuel Rails, BPV hose, & more cleatis Engine/Power/Exhaust 6 10-28-2009 02:52 AM
Sti vf-39, intake manifold, fuel rails, and injectors cbrdragbike Engine/Power/Exhaust 5 07-07-2008 06:23 PM
04 STI Intake manifold/fuel rails/wiring snowcrzy Engine/Power/Exhaust 2 06-12-2008 12:49 PM
Stock TD-04, TMIC, intake Manifold, Fuel Rails TheWRXKid Engine/Power/Exhaust 0 05-27-2008 11:01 PM
