Welcome to the North American Subaru Impreza Owners Club Sunday March 29, 2015
Old 08-03-2007, 12:54 PM   #1
LiquidForce
Member#: 12811
2002 2.5l Wrx
517whp/516wtq (Stage pi)
Default Mission Impossible (v5 sti ra cam specs)
I have google'd all the combinations I can think of but cannot find the specs for the v5 sti cams.
I finally have some heads to replace the stock ones on my hybrid. They are version 6 and have been ported and have +1mm oversized valves. The heads also have v5 sti cams. Before I go through the trouble of setting the valve lash I want to know if these cams are better than the current usdm sti ones.
I made a similar post a while back but nobody could provide the actual specs. I really want to make the right choice and avoid having to pull the motor again.
LiquidForce is offline   Reply With Quote
Old 08-04-2007, 11:28 PM   #2
WJM
Guest
Member#:
a JDM FSM would be nice.
But the heads and cams are lashed! Check your PMs on WRXATL.
Old 08-05-2007, 11:04 AM   #3
LiquidForce
Member#: 12811
2002 2.5l Wrx
thank you sir.
V5 STI RA gearset 4.44 Final drive tranny w/ rear end. perrin247 Drivetrain 40 06-20-2009 01:19 PM
Ver. 6 STI-RA Cams, '06 WRX TMIC, Emanage Blue gt_drifter Engine/Power/Exhaust 18 10-13-2008 12:32 AM
wrx ej20g heads + v5 sti RA block = ???? xtian Pre-2002 Factory Turbo Powertrain 5 09-28-2006 01:48 AM
Full V5 STI RA tranny, matching 4.44 rear end, new Cusco flywheel & Spec Stg 2 clutch JSiwek Private 'For Sale' Classifieds 13 01-09-2005 12:15 AM
