Old 08-03-2007, 01:22 PM   #1
jinsing7
Member#: 92431
2011 Lexus CT200h
Default 322AWHP/300AWTQ with EJ25 Hybrid and 18g
From what I'm told this specific Mustang Dyno tends to read low. Should be a little closer to 350-370 but it's a really smooth tune for a DD and the weekend track day every now and again. Tuned by Jake at Dieman Motorsports.
Mods are:
06 STI EJ257 Short Block with 2.0l WRX Heads and cams
FP 18g oil and water cooled
Dieman Enginuity tune - 92oct @ 17PSI
Billy Boat TBE with high flow cat
Autospeed FMIC and Intake
Autospeed Lightened Crank Pulley
Autospeed Up-Pipe
NGK One step colder Iridiums
Perrin fuel lines and rails
Samco Inlet hose
PE 650cc injectors
Koyo 3 row radiator
Walboro 255 fuel pump
TurboXS Type-H BOV
jinsing7 is offline   Reply With Quote
Old 08-03-2007, 01:32 PM   #2
treystoys
Member#: 97436
03 toyota tundra
gray..missing my WRX's :(
Very nice man thats some solid numbers on any dyno, not to mention a low reading one. I'm kinda surprised that with the 2.5, your peak torque insn't higher than peak hp like many other 2.5s. In any case, very nice, looks like a great DD.
Trey
treystoys is online now   Reply With Quote
Old 08-03-2007, 01:41 PM   #3
bren wrx
Member#: 59454
'10 E92 M3 M-DCT
brentuning.com/blog
can you run any more boost then 17? i know the hybrids hate lots of timing, but i think you could a little more boost on 92 with the fmic
bren wrx is offline   Reply With Quote
Old 08-03-2007, 01:46 PM   #4
wrxfactor
Member#: 49978
2002 WRX w/ JDM STi
6spd, EJ255, VF39 & EWG
Trey
I asked BV about this and they essentially told me that peak torque will be less than peak hp until you begin to push the limits of the turbo's capabilities.
wrxfactor is offline   Reply With Quote
Old 08-03-2007, 01:57 PM   #5
neo277
Member#: 131432
2004 WRX on Ignite E
Gtx3076 - 07 6mt
did you retain your stock cams?
neo277 is online now   Reply With Quote
Old 08-03-2007, 02:33 PM   #6
jinsing7
Member#: 92431
2011 Lexus CT200h
He tried a little more boost but temps started getting a little high, so he stayed at 17.
Yes I kept the stock cams. I could probably get a little more out of it with a set of aftermarket cams or sti heads but don't have the cash right now. That is part of the reason of the lower torque number on a 2.5l. That's fine with me right now since I'm running stock gears .
Old 11-01-2007, 10:06 AM   #7
jonhybrid
Member#: 126519
18g 2.5l hybrid
Mods are:
Autospeed Up-Pipe
Samco Inlet hose
PE 650cc injectors
Koyo 3 row radiator
TurboXS Type-H BOV
What head gaskets are you using?
jonhybrid is offline   Reply With Quote
Old 11-01-2007, 10:16 AM   #8
WRX4eva
Member#: 103343
2004 2.5 Hybrid 6spd
Rotated Manifold/35R
Looks like the power comes in smooth and powerfull, Grats on the numbers.
WRX4eva is offline   Reply With Quote
Old 11-01-2007, 10:36 AM   #9
wrxhard
Member#: 108091
peak torque at 5100?????? That sounds like 35r territory to me. When does this car hit full boost?
wrxhard is offline   Reply With Quote
Old 11-01-2007, 10:45 AM   #10
aps2fast4u
Member#: 57871
2004 WRX
13.4 @ 102
^ +12345, with the 257 block and an 18g, I would think full TQ would be no later than 4k
aps2fast4u is offline   Reply With Quote
Old 11-01-2007, 10:55 AM   #11
9vapors
Member#: 92582
What did you have to do to the heads to make them work with the 2.5?
9vapors is offline   Reply With Quote
Old 11-01-2007, 02:01 PM   #12
Tenacious Bee
Member#: 96452
So, what to play
with next ?
Bolt them on. Not being a smarta$$. That is all you have to do though. I am installing my hybrid next week. The 2.0L heads bolt right up. Sti heads need to have a few minor things done to work with a non STi ECU but the 2.0L heads are a direct fit.
Nice numbers. I am hoping for a bit more out of my 20G hybrid. Hope I don't get boost creep with my td05h wheel and 7cm hotside.
Tenacious Bee is offline   Reply With Quote
Old 11-01-2007, 02:32 PM   #13
sluflyer06
Member#: 111641
2014 BRZ Ltd - DGM
E30 318is
not to sound like a killjoy but it seems more like the dyno reads pretty high.
Those #'s seem very atypical for a 18G especially only @17psi.
Is the late torque and low boost have to do with running the 2L heads? The 18G shouldnt be much laggier than a VF39 and my peak torque is [email protected]?333? I know u've got a FMIC but still.
Unless maybe thats a 8cm Td06H 18G with some port work or similar. any clipping?
sluflyer06 is offline   Reply With Quote
Old 11-01-2007, 02:56 PM   #14
the_colombian
Member#: 84912
2003 2.5L bugeye now
with 6 spd 20g!
^ my td06-20g that is ported on a 2.5 hybrid hits full boost at 3800. something is up.
the_colombian is offline   Reply With Quote
Old 11-01-2007, 03:01 PM   #15
Freon
Member#: 88322
2009 BMW 135i
I don't think any of the EJ257 hybrids match the full EJ257+AVCS head as far as spool. I'd guess AVCS is worth just as much as the extra 1/2 L. Maybe more... we don't see too many 2.0L AVCS engines to compare, and if we did the heads would likely still not be directly comparable to our US AVCS heads.
It also looks like that graph has a lot of smoothing applied, which makes the peak hit alittle higher than where torque actually starts to level out. It might actually be more like 4500rpm.
I wonder if it wouldn't be a good idea to get cam gears on that and advance the cam a bit to move the power band down.
Freon is offline   Reply With Quote
Old 11-01-2007, 06:35 PM   #16
verc
Member#: 41754
03 wrx
gt35r, 2.5L, meth
Yeah.... I think a lot of us guys who did shortblock swaps when the STI shortblock became available to buy through dealership didn't realize AVCS made such a difference with medium sized turbos like the 20g and Green.
shucks
verc is offline   Reply With Quote
Old 11-01-2007, 09:13 PM   #17
Twiztidunreal
Member#: 63249
2004 2.5 STI Wagon
05 FXT Black
my hybrid loves timing my tuner said, i am running upwards of 30+ in some rpm's
Twiztidunreal is offline   Reply With Quote
Old 11-01-2007, 09:14 PM   #18
Twiztidunreal
Member#: 63249
2004 2.5 STI Wagon
05 FXT Black
i got creep on my 7cm td05 afer 3rd gear, i would go from 17 psi to 20psi, and the BC couldnt do anything about it.. went ewg...
Old 11-02-2007, 02:04 AM   #19
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
shucks
Actually a lot of the benefits of AVCS can be made up for with tuning on the hybrid blocks. I generally see very similar spoolup and torque
Equilibrium Tuning is offline   Reply With Quote
Old 11-02-2007, 09:43 AM   #20
sluflyer06
Member#: 111641
2014 BRZ Ltd - DGM
E30 318is
kind of an odd statement, because any tuning that can be done on a hybrid is also present on a AVCS motor +AVCS tuning. So basically all else is equal except for the AVCS.
All down to the tune, technically the same tuner on similar modded vehicles the AVCS should outspool. The hybrid may just require more fine tuning to get it close.
Old 11-02-2007, 12:45 PM   #21
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
I'm just saying that AVCS isn't really all that. It just provides a slightly different approach to get similar results. Most of the advantages I've found from AVCS are in the form of drivability and fuel economy. It can also help with torque when running relatively low boost levels.
Thanks
-- Ed
Old 11-02-2007, 12:56 PM   #22
sluflyer06
Member#: 111641
2014 BRZ Ltd - DGM
E30 318is
Thanks
-- Ed
i'll trust you, I really don't know that much about it, I'm not trying to say AVCS is super awesome or anything like that.
Old 11-02-2007, 03:31 PM   #23
stentorian
Member#: 12959
2008 Scion xB
Nice numbers!!! I'd like a ride ha!!
-Joe
stentorian is offline   Reply With Quote
Old 11-03-2007, 01:50 AM   #24
dkan
Member#: 123373
2005 wrb 05 wrx 18g
very nice graph
dkan is offline   Reply With Quote
Old 11-06-2007, 11:01 PM   #25
Sko
Member#: 90396
2005 Legacy 2.5i
Brilliant Silver Metallic
What headgaskets were you using again? STi headgaskets? Cometic's?
Sko is offline   Reply With Quote
Feeler: KS - 02' PSM WRX - 18g EJ25 Hybrid jinsing7 Private Vehicle 'For Sale' Classifieds 6 03-06-2008 02:00 AM
Feeler: KS - 02' PSM WRX 18g EJ25 Hybrid jinsing7 MWSOC Private Classifieds 9 03-01-2008 05:29 PM
EWG 44mm and 18g, 2.5L Hybrid - what EWG spring should I run? MarylandEcstasy Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 09-10-2007 02:39 AM
Hybrid EJ22 with EJ25 dohc crank and rods? 2.5rsDOHC Built Motor Discussion 10 02-09-2007 05:25 AM
1/4 time Question with 257 with wrx heads and 18g njpreppy Proven Power Bragging 10 07-19-2004 01:19 PM
