Mid Atlantic Impreza Club
Old 08-03-2007, 02:20 PM   #1
Wrx_Fan_0717
Member#: 152080
6266 Precision'd Big
Cam'd 2.55l 6spd Bugeye
Default Anyone local know UTEC pretty well? GM BCS help needed PLEASE!! lol
Well, i installed the GM BCS today. All was fine. Set my gain to 30 and have my closed loop attributes around 149 then stepping down.
I took it for a test ride i noted i was getting 10-11 psi of boost.
So i go back to my garage and for ****s and giggles hit the launch control one time. It was hitting 16-17 psi? How is this possible? Am i missing something?
I thought if the BCS was only allowing me to get 11 psi why is it allowing 16-18 during the 2 step?
Any ideas? My first setting in range of 100 then stepping down. The boost went from 8-9psi to 10-11. So that tells me its working right?
Also, the first two columns i kept it "ECU" should i change those also? Im am boosting 2psi at 1800rpm in second? How low to to low?
Any help is greatly appreciated
Anthony
Wrx_Fan_0717 is offline   Reply With Quote
Old 08-03-2007, 03:29 PM   #2
TurbojonLS
Member#: 38772
2 Cars, No Bling
I've never used the Launch Control, so I don't know much about it.
And I can't find any other questions in your post - what else do you need to know? What other mods do you have? What boost mode are you using? (Open, closed, or PID?) If you're running closed loop, which I think you are based on your boost table values, try this:
Take the gain to 0
Cut your boost map values by 1/2 and make them all the lowest number in the map.
Start your logger and do a few runs. See what your boost is, and increase as needed.
BE CAREFUL: The gain set at zero means really fast spool, but also if you go too high you can really overshoot your boost target. There's nothing wrong with ECU as a target in the 10 & 20 columns - its more of a drivability thing at that point anyway.
TurbojonLS is offline   Reply With Quote
Old 08-03-2007, 05:46 PM   #3
Wrx_Fan_0717
Member#: 152080
Take the gain to 0
Cool man thanks. Its running closed loop. I figured it out. The LC makes the BCS run on full cycle. My full boost was around 11-12 but with LC it was 16.5 or higher. That first LC on the new BCS freaked me out. I was like hold up i am not tuning **** else until i figure this out.
Again its running closed loop
But, i set my gain to 28. The boost properties at 266 at 100% then step down ect ect.
Sits pretty at 16.5 minimal spikes. But, i have 2psi of leeway for spikes anyway.
Thinking im just going to get greedy and boost 21psi until the turbo goes. I getting a 18g anyway.
PaulRex put it in stupid terms so i could understand.
Thanks for the help.
Anthony
Old 08-03-2007, 06:18 PM   #4
TurbojonLS
Member#: 38772
2 Cars, No Bling
20psi on the stocker is really nice - I highly recommend it.
But give the 0 gain thing a try - the spool difference is crazy!
Old 08-03-2007, 06:50 PM   #5
rice wrx
Member#: 89698
ahh, just put an ewg on it and run about 24 psi
rice wrx is offline   Reply With Quote
Old 08-03-2007, 06:52 PM   #6
Jard
In the silly seat
Member#: 34935
SPB- 2013 Dadcore
Soon.
Jard is offline   Reply With Quote
Old 08-03-2007, 07:00 PM   #7
Wrx_Fan_0717
Member#: 152080
What about spikes? I'll put it on 10. LOL
What all would i need to change?
Just the boost properties (BCS cycle)? Basically, all i would need to change is the boost map? No fuel mapping?
Im using the UTEC STG 2 map. Would i be able to run 20psi on that map?
I thought they were only tuned to 19psi or something?
Hey if i can i'll do it right now.
Turn that sucker up until it spews oil in the engine bay.
Old 08-03-2007, 07:36 PM   #8
TurbojonLS
Member#: 38772
2 Cars, No Bling
You really just need to do 2 things:
1- Set the gain to 0
2- Cut the numbers in your boost map by at least 1/2
I think the highest boost value I was running was 166 on my 20 psi map. You won't spike, but that's because the target values are so low.
I wouldn't try 20psi without a wideband, and not on the stock map.
Shouldn't you be rebuilding a transmission right now?
Does anyone know what happened to my car? Help needed (Pic) Padge Mid Atlantic Impreza Club -- MAIC 10 03-12-2009 11:14 PM
Who knows UTEC pretty well? GM BCS help needed PLEASE!! lol Wrx_Fan_0717 UTEC 4 08-03-2007 05:41 PM
GM BCS help MikeCee Newbies & FAQs 7 07-26-2007 12:24 AM
gm bcs help in south florida Fljason Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 06-26-2007 11:15 PM
UTEC help needed, please... stink Engine Management & Tuning 10 08-31-2004 12:16 PM
