Old 08-04-2007, 11:08 AM   #1
javastiwagon24
Member#: 144372
0407 STIwag & 01 STI
Rotated!Widebodied!RaLLY
Default Saturday Morning Freak OUT! HELP PLEASE AM I SCREWED!!!!!!
Got up this morning to assemble the newly bored and honed short block "ej257" for my hybrid set up and was installing the bearings when i noticed this, i believe it is a coolant passage, its on the passenger side of the block on the upper part, there is a chunk that looks like it going to flake off, i bought the block from somebody on here and really must have missed this if it came like this to me, so either the machine shop did this or i bought it like this, what do you guys think i should do about this, is it really bad or do i have some options, I would imagine that if this flakes off i will be pooling coolant right into the crankcase and thats not good, check out these pics and let me know what you guys think, Thanks for any help.
By the way the other side of the block where this mates up to looks like it was sealing, and there is no coolant residue and doesn't show any sign of this crack, it looks like the seal was perfect and can not see anything wrong!
http://s195.photobucket.com/albums/z...zdad22/nasioc/
http://i195.photobucket.com/albums/z...c/HPIM0582.jpg
http://i195.photobucket.com/albums/z...c/HPIM0581.jpg
http://i195.photobucket.com/albums/z...c/HPIM0580.jpg
javastiwagon24 is offline   Reply With Quote
Old 08-04-2007, 12:07 PM   #2
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
Yeah, that doesnt look good, but I bet JB weld, a little filing, and Subibond will easily make it good. Good luck.
Old 08-04-2007, 12:25 PM   #3
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Well, that seals with an o-ring, so the edge doesn't matter a whole lot. I'd just worry about the o-ring squeezing out the side under pressure. Some JB Weld and a little patience sanding it perfectly flat should do the trick, I think.
Old 08-04-2007, 12:44 PM   #4
Starkiller
Member#: 82741
2007 350Z Silver
Agrees with fix
Starkiller is offline   Reply With Quote
Old 08-04-2007, 12:46 PM   #5
javastiwagon24
Member#: 144372
Thanks guys for the quick answers, Dam This problem has my blood pressure at HYPERTENSION, Do u guys think that there is a better quality type "JB weld" or is JB weld the ticket, should I bother getting it welded by the machine shop!
Old 08-04-2007, 01:06 PM   #6
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
If you have the ability to get it welded and maybe know someone to plane it flat, and you don't mind waiting, that is definitely the ideal solution. Remember, that block is cast aluminum, so not everyone can weld it (read: no muffler shops).
Old 08-04-2007, 01:12 PM   #7
javastiwagon24
Member#: 144372
Car has been under the kNife for 2 months WAITING if you guys think jb weld will hold up i would be happy with your advise, and would like to get this thing together relatively quick, What do you guys think the cause of this may be. I took it to the Machine Shop wrapped in bubble and took it home from the shop wrapped in bubble wrap, the side that is cracked is probebly the side that faced down on the Bore/hone machine. Any IDEAS!!
Old 08-04-2007, 02:28 PM   #8
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Well, you can try to get them to fix it, but it's all in the approach. Good luck if you decide to go that route.
The JB Weld... while I think it would hold, if serious pressure built up behind it, there is always a possibility that the JB Weld didn't have enough cohesion to stay stuck where you put it. Basically, if it was me, I would do it on my block, but I wouldn't do it on anyone else's block.
Old 08-04-2007, 09:36 PM   #9
sense of nature
Member#: 112759
2018 STi Mikey Tuned
SexyRP
Hey
Dude ,the only thing I would be concerned w/ is how deep internally does it go ?
It's a main oil passage , looks like in front , right underneath the oil sending unit .. ? I would not risk welding it for fear of warping the case.jb weld is probably the only safe option, @ least its facing inwards
regards
sense of nature is offline   Reply With Quote
Old 08-04-2007, 10:39 PM   #10
javastiwagon24
Member#: 144372
it only goes about 1/16-1/8 " into the block down towards the oil pan, it should take only a minute or two to file out, thanks for the info
Old 08-04-2007, 10:42 PM   #11
robbieshonda
Member#: 122306
2002 Sti PTE 6262
Interlagos Blue 551/441
jb weld works...But dont do it.. Its not a very good fix..take it to the machine shop that did your work they'll cut you a deal and it wont take long to tig it.
robbieshonda is offline   Reply With Quote
Old 08-05-2007, 11:04 AM   #12
dexterous
Member#: 23553
2005 STI - Insanity!
2014 WRX - Daily
+1
That sucks man. I know how it feels to have a long term project suddenly hit a roadblock like that. Good luck.
dexterous is offline   Reply With Quote
Old 08-07-2007, 12:38 AM   #13
stu
Member#: 25768
35R bugeye
Slowbaru
just take the time to do it right. if it has been out for two months what is acouple more days for all your hard work.
stu is offline   Reply With Quote
Old 08-07-2007, 08:01 PM   #14
javastiwagon24
Member#: 144372
So i went to the shop locally and told them about the crack he very kindly said it may have been dropped or rocked on the table and i agree sh))t does happen, he took the block halve from me and said it would be fixed, i left the shop and headed to work, about an hour later he called me up and told me it was fixed and was no charge, Thanks alot DONNY @ engine rebuilders "53186" everything looks great and got it done in no time, picked it up today and went home to start putting it back together, Do you guys think that a .002 oil clearance is good for the connecting rod bearings i got the plastiagauge used it /worked great , also kinda hit a bump_ one of the rods does not have the clearance like the others, feels like 3 out of the 4 have about .020 play side to side, nothing up and down, but the one has "feels like" .005 play any worries or concerns i should have with this!??
Old 08-07-2007, 08:04 PM   #15
javastiwagon24
Member#: 144372
by the way none of the rods have up and down play!!, now i just have to wait for the gasket set in the mail to put her together < thanks a lot for everybody's input.
Old 08-07-2007, 08:04 PM   #16
javastiwagon24
Member#: 144372
i will post pics of the repaired results tonite,!
Old 08-07-2007, 09:12 PM   #17
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
sounds good man good luck!
mxpunk is offline   Reply With Quote
Hit a pothole, freaking out, HELP! UnFocuzed General Community 25 10-27-2007 01:10 PM
Passenger side HID flickers and temporarily goes out -- Help please. prototypeWRX Electrical & Lighting 6 02-08-2006 03:28 PM
Engine cutting out, help please? Thunder Lungs Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 12-11-2005 05:33 AM
Sudden crap out, help please InfiniteMotorsports Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 10-07-2005 12:06 PM
Please Help. I am so screwed! WHITE '01RS General Forum Archive 9 12-08-2000 05:53 PM
