Old 08-04-2007, 01:56 PM   #1
railguy
Member#: 53756
Default How does a car idle without a fuel pump?
I just created a thread about unflooding a motor, so I did what jeremy from cobb told me to do, I cranked the motor over by hand, then I replaced the spark plugs. I tried to start it no go......So I disconnect the fuel pump and she will idle????? My question is how does a car idle with the fuel pump relay disconnnected?????? What should I do to keep it running with the fuel pump working? someone let me know. Is it safe to run with the fuel pump disconnecting jsut to idle. Also, is it ok to plug the fuel pump in while the car is idling????
Thanx
Eric
railguy is offline   Reply With Quote
Old 08-04-2007, 04:29 PM   #2
railguy
Member#: 53756
Ok ,well i plugged the fuel pump in when the car is running and it just dies.....I have an aftermarket dual walboro fuel. What is going on????I am thinking a draw.....but at what point does the utec kick in and control fuel? Could a bad injection cause this?
Old 08-04-2007, 05:19 PM   #3
Starkiller
Member#: 82741
2007 350Z Silver
Just a guess, but it probably has something to do with your wiring of the fuel pumps. Maybe its causing the ECU think that theres fuel pump trouble and it kills the engine to prevent damage. IIRC, UTEC doesn't kick in until a certain RPM/Throttle position is reached, ie the OEM fuel/timing map controls idle.\
Although if I'm wrong, someone will chime in and say otherwise
Starkiller is online now   Reply With Quote
Old 08-05-2007, 12:19 AM   #4
modaddict
Member#: 95840
sold to a good bud
awaiting next car
you have a post turbo intake leak. It's most likely your intercooler tubing is either popped off, or a REALLY bad manifold leak.
check all your connections, specifically look behind the bumper....don't say it's "all ok". pressure test the damn system.
p.s. I hope you have a fmic.
ppssps... plug in your fuel pump....then unplug your maf sensor....if it starts and runs just fine.....guess what...you have a post turbo intake leak
other than that, I can't help you
modaddict is offline   Reply With Quote
Old 08-05-2007, 12:52 AM   #5
railguy
Member#: 53756
How bad is really bad? I remember back in the day, I had a leak from where the injector seats the intake manifold. But it still ran just idled a little bit high and I pretty sure I fixed it. I will unplug the maf and see what happens.
Old 08-05-2007, 01:08 AM   #6
modaddict
Member#: 95840
sold to a good bud
awaiting next car
idled high? you must have been running a speed density system instead of maf based?
bad meaning......pretty bad. I had the exact same issue as you with flooding of the engine. My wife was driving my car and she said she didn't hear a thing...but my intercooler tube popped off behind the bumper. It took me awhile to find it, but unplugging the fuel pump, the car would start and run for ATLEAST 30 seconds, because it was sooooo flooded. I eventually found that when you unplug the maf, and pump plugged in, the car ran great! just no boost!
MAKE SURE TO CHANGE YOUR OIL!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
this is what happens when and intercooler tube pop's off going down the highway and your wife hears nothing:
Old 08-05-2007, 09:05 AM   #7
railguy
Member#: 53756
well, sir I unplugged maf and tried to start, the car wont run with the fuel pump enguaged..........unplug the pump and it runs great......I even tried to start it with the maf unplugged and the fuel pump unplugged, got it to idle then plugged fuel pump back in. Killed the motor instantly.................and I almost 99% sure that I have no hose to intercooler coming off.
Old 08-05-2007, 11:58 AM   #8
modaddict
Member#: 95840
sold to a good bud
awaiting next car
when unplugging the pump and then running the vehicle, will it die after 30 seconds or so? If it does, THEN plug in the pump and unplug the maf.
Are you blowing smoke out the tailpipe when the pump plugged in? is the vehicle basically misfiring and then dying because it runs soo rich?
Old 08-05-2007, 06:46 PM   #9
railguy
Member#: 53756
The car does not die, it will idle forever....... it is smoking but you can tell its from the fuel. I do not have any cel for misfires.......
Old 08-05-2007, 09:17 PM   #10
railguy
Member#: 53756
well, i believe now that it is because the car is not tuned and my 1000cc injector map for my fpred is not enough......... I think its a tuning issue.
Can you run without the fuel pump controller?? eightballrj Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 10-13-2003 03:20 AM
What RPM does your car idle on? KAuss Bay Area Impreza Club Forum -- BAIC 16 09-12-2002 02:39 AM
What RPM does your car idle at? sbsnyder Normally Aspirated Powertrain 13 05-29-2001 12:50 AM
('93-'01) how does a high idle (900-950) affect the RS? popnGEAR Impreza Forum 0 04-16-2001 08:38 PM
Higher Idle with larger fuel pump? yebokmj Normally Aspirated Powertrain 1 03-08-2001 03:57 PM
