Old 08-04-2007, 03:45 PM   #1
Caballero_STi
Member#: 122711
05 STi
Default Ecutek with blow thru maf?
Can I get tune with Ecutek if I running with blow thru maf?
I know that I gonna need the speed density to run with that. And I really don't want to push the limit of the stock Ecu.
Caballero_STi is offline   Reply With Quote
Old 08-04-2007, 04:09 PM   #2
JDM-STI
Member#: 101256
2005 STI
CGM
No need for speed density. It is all MAF calibration and it can be done with a Ecutek tune. You just need to make sure that your blow-thru tube is sized correctly for the turbo that you plan to use. The bigger the turbo the bigger pipe diameter you need.
JDM-STI is offline   Reply With Quote
Blow Thru MAF location with Rotated Manifold Hayaboosted Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 15 04-04-2010 11:40 AM
Top Speed Blow-thru MAF Adapter Plate( Pics) Peeblesmx445 Engine/Power/Exhaust 16 11-30-2006 03:24 PM
blow thru MAF flanges??? PerformanceAutoSolutions Engine Management & Tuning 5 08-24-2006 08:51 AM
Blow thru maf intake BLUE STINGER Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 07-18-2006 11:55 PM
Blow thru MAF, there is HOPE! Division By Zero Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 44 02-20-2006 09:26 PM
