Old 01-05-2002, 12:08 PM   #1
aschnell
Member#: 1068
2008 STI
Default WRX Oil Leak
I had a slow leak in my WRX after 8k. I brought it to the dealer twice. The second time they found oil coming out of one of the bolts that holds the block together. I think they just squirted some silicone in there to stop the leak. Should I pursue this further and have then replace the seal. The way I understand it is that the block is two pieces. I would assume it has a one piece gasket between. Does anybody know what it looks like down there. I am not too impressed with their fix.
Should I pursue this further??? Dont want this to come back and bite me after the warranty is out.
Thanks
Andrew
aschnell is offline   Reply With Quote
Old 11-05-2004, 03:35 PM   #2
mywrx2004
Member#: 73902
Default oil leak
Thanks
Andrew
I just found your post on-line. i just posted similar problem with my 2004 WRX wagon. I know this has been a while but how did you resolve this problem? My dealer has not been able to fix my oil leak problem after 3 tries.
Thanks
Chris
mywrx2004 is offline   Reply With Quote
06 WRX oil leak iboost808 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 9 04-27-2016 08:52 PM
Little Oil Leak Near Oil Pan 09 WRX BigSteiner5 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 02-19-2010 11:16 AM
06 wrx. oil leaking from block above oil pan. seventhsign Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 07-24-2009 05:19 PM
02 wrx oil leak think0rz Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 07-09-2008 01:14 PM
02 WRX oil leak trouble brubaru Service & Maintenance 4 05-14-2007 06:41 PM
