Old 08-02-2007, 04:53 PM   #1
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
Default afi is dead?
Is it me or is there a select few who choose to put themselves through hell and make their NA subarus Turbo?
This place is dead!!
mxpunk is offline   Reply With Quote
Old 08-02-2007, 05:20 PM   #2
BAMA RS
Member#: 877
1998 2.5RS
BDP
I'll always be too poor to afford a swap.
RS-T for life?!
BAMA RS is offline   Reply With Quote
Old 08-02-2007, 05:45 PM   #3
mikeythejew
Member#: 141672
I went and saw AFI in concert.
mikeythejew is offline   Reply With Quote
Old 08-02-2007, 08:41 PM   #4
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
I am building three right now.
My 2.5 with Mahle pistons and STI crank for the twin charged wagon.
My 2.2 with stock turbo pistons and T3/T4 turbo for the Sedan.
And a 2.5 with stock STI pistons and small turbo for the daily driver wagon.
reddevil is offline   Reply With Quote
Old 08-02-2007, 09:21 PM   #5
Migo
Member#: 81352
2003 '03 EJ257 wagon
Green
It's not quite dead. Change your settings to show all threads in this forum from like... 2 months ago. There just haven't been much updates in the last few days or so.
Migo is offline   Reply With Quote
Old 08-02-2007, 11:03 PM   #6
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Not a whole lot going on lately.
Oh, and swaps can be cheap... I have less than $1000 into mine and I've got very few things left that I need (other than a transmission & rear diff).
8Complex is offline   Reply With Quote
Old 08-03-2007, 12:44 AM   #7
PhilSine
Member#: 130489
02 WRX Wagon (WRB)
98 OBS-T, 91 Legacy SS
I think its just that in the spring there are a lot more planning discussions, in the early summer a lot of building and assembling discussions, and by mid to late summer the projects are either done, at an impass, or quietly being fine-tuned.
I'm at the quietly being fine-tuned stage and have nothing to report at the moment that I'm not otherwise too embarassed to admit to. Here's a hint though...
It took me 2 months of playing with my ultimate to understand the importance of running a data log to really see how everything works together.
Had I done this sooner, I would have realized that my injector acceleration map is quite likely the culprit behind many of my open loop fuel delivery problems. I would have also realized that I had my TPS voltage wrong in that WOT for me is 3.0V and not the 3.55V that I had it set at.
I also would have sooner understood why it is that even though my car is otherwise running, that I keep getting a CEL that says "Injector 1 voltage low" and for all 4 injectors.
See, now that's an interesting one that I'm not sure how to solve an here's why. My inputed injector duty cycle from the ECU is at 94% when I'm at about 125 mph or so because the ECU still thinks its trying to control a 220cc injector. In reality, there are 550cc injectors that I have inputed into the proper section of the emanage ultimate software so that the emanage knows what its dealing with. So, the ultimate is telling the bigger injectors to run a duty cycle of around 60% at WOT and 125mph. The result of the lower duty cycle and proportionately low durations is that the emanage is spitting out lower voltages to the injectors and the injectors are then sending their info back to the factory ECU so that the ECU can know that the injectors are working properly. As far as the ECU is concerned, the injectors are failing because they send back voltage readings that are too low and threfore a CEL is triggered to tell me that my car is not working right.
I don't know how to solve this. There is a chance that I have something wired wrong (or not at all) that will fix this but since its really not broke and I'm not done figuring other things out yet, I'm not gonna fix it.
So, tomorrow I load in and test my newest map to see if I fixed anything in the open loop area of my fuel map.
PhilSine is offline   Reply With Quote
Old 08-03-2007, 05:04 AM   #8
speed_freak27
Member#: 30798
2001 RS-T Hybrid
2.5>2.2T>257>2.35S
I've been building mine for about 8 months now. Just too lazy to post up any details. Here are a few pics for ya though. I got the rest of my exhaust fabbed up and welded. It's going back together this weekend. I'm just waiting on the hydra now.
speed_freak27 is offline   Reply With Quote
Old 08-03-2007, 06:35 AM   #9
Brydon
Member#: 107569
1998 Forester S
SRP
Bought a new one! Now in the planning stage while the L gets a cage/cams/prting/rods/dogbox.
Brydon is offline   Reply With Quote
Old 08-03-2007, 06:57 AM   #10
bugman1964
Member#: 57667
01 gm6 rs brp
SXS performance
hey if some one wants to donate all the bits for me to make my car AFI ill be happy to join the club.Other wise I'll be waiting till I can figure out how to explain the need to drop 2g's to the +1
bugman1964 is offline   Reply With Quote
Old 08-03-2007, 02:57 PM   #11
atech_rallyrs
Member#: 116638
00 impreza naSTi
el typico silver
Its not dead. I just got the final piece of my car. Taking it to the shop ~ my birthday to get it all bolted together and tuned.
atech_rallyrs is offline   Reply With Quote
Old 08-03-2007, 04:32 PM   #12
speed_freak27
Member#: 30798
2001 RS-T Hybrid
2.5>2.2T>257>2.35S
I've got some old stuff I'll get let go cheap.
Old 08-03-2007, 05:54 PM   #13
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
I've got something cooking but until I finish my other project (which can be veiwed in pre-2002 factory turbo) I won't start it or talk about it...
Old 08-03-2007, 06:19 PM   #14
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
not fair!
RS-T for life?!
same!!
the lead singer is a ******!
ill try that
you must have the ability to find **** for cheap like me..
not fair!!!
i want to see this!!!
Old 08-03-2007, 06:43 PM   #15
Brydon
Member#: 107569
1998 Forester S
SRP
Well come on by! It might be a long drive for you.
Old 08-03-2007, 06:51 PM   #16
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
maybe i will..i might be moving to washington state in october or november!
too bad my 1.8T will be staying with my parents for quite some time..
heres her idling..shes getting another ej18 block cuz the one thats in there now is a bit hagged up!
http://youtube.com/watch?v=c4jHP40mbZg
Old 08-03-2007, 07:03 PM   #17
midnight2.5rs-t
Member#: 126217
04 Jetta GLI
it is not dead i am just running out of money. i need a stock mounting location turbo for a wrx, oil lines, injectors, a intercooler and some other various parts. so unless anyone wants to just give me that then i am at a halt for now, unless i sell some of the crap i wont be using.
midnight2.5rs-t is offline   Reply With Quote
Old 08-03-2007, 09:48 PM   #18
Brydon
Member#: 107569
1998 Forester S
SRP
Well if you move to Washington let me know. I can help you build another car if you want.
Old 08-03-2007, 09:50 PM   #19
PltsilvREX
Member#: 66406
I thought we were talking arc faults
PltsilvREX is offline   Reply With Quote
Old 08-03-2007, 10:25 PM   #20
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
thanks dude, i would but part of the reason i might be moving out is so i can focus on getting my life on track and my future..which means the fun stuff is gonna be put on hold for a awhile. but..if you give me a ride in your car ill be happy ..you know..since your slowest daily driver car still runs a damn 12 in the 1/4..haha
Old 08-03-2007, 10:26 PM   #21
freeride
Member#: 49783
2000 2.5rsti&98wagon
SRP/white
I just troll for info So I have a good start when winter time comes and I can get into my shop and start to fab and put all this stuff in my garage into my car!!
Killer looking at it and not using it yet!
freeride is offline   Reply With Quote
Old 08-03-2007, 10:29 PM   #22
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
^dude i know. i spent months looking at my engine with the turbo on it and making noises pretending it was running...LOl
Old 08-03-2007, 10:54 PM   #23
Solace
Member#: 96158
2000 Impreza RS
come to think of it I have almost everything I need, just missing, or rather not wanting to bite the bullet for eManage Ultimate, and some misc plumbing.
Change your User settings so you see old threads- I remember seeing not a single topic here before I changed it.
Solace is offline   Reply With Quote
Old 08-03-2007, 11:22 PM   #24
PhilSine
Member#: 130489
02 WRX Wagon (WRB)
My eyes water just watching that. Of course its not tears of joy, happiness, or envy; its from imagining how it must sting my eyes from being around such a rich exhaust
Not criticizing, just empathizing. I was there a few months ago and am still there every time I start up my non-cat'd 77 Jeep Cherokee with a 360 in it that runs a bit rich.
Old 08-03-2007, 11:45 PM   #25
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
yea i know it idles rich as hel..my driveway was coated!
i think its a vac. leak cause i have the emanage set to scale back the injectors (370s) and it still idles lumpy..
i also set up the injectors to run pretty rich just so i could drive it safely around my house just to test it out..thats why the black smoke billows out of the exhaust once the BOV opens..screws with the MAF.
My clutch is dead at 42K is this normal? Ripper Normally Aspirated Powertrain 9 06-07-2012 07:46 PM
NW Forum is dead Ethan North West Impreza Club Forum -- NWIC 8 06-09-2001 01:19 AM
How to tell is O2 sensor is dead? ImprezaRS dot com Normally Aspirated Powertrain 7 03-12-2001 09:53 AM
The Intimidator is Dead................. Fred Zaplitny Motorsports 32 02-20-2001 06:43 AM
texasubaru.com is dead !? JayP Texas Impreza Club Forum -- TXIC 13 01-05-2001 12:18 AM
