Welcome to the North American Subaru Impreza Owners Club Monday April 27, 2015
Old 08-04-2007, 09:09 PM   #1
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
Default Im poor..
OK not really, but my parents cut the chord quite sometime so all the fun stuff to waste money on comes out of my pocket..lol (im 19, money is tiight!)
OK so..i turbo'd the 1.8 motor in my impreza and the engine is **** (woodruff key slot is oblonged, timing belt tensioner threads are stripped) so i put it in anyways and hoped it would last. i didnt blow it up but i got another ej18 block with lower miles on it and its in good condition so i want to put that one in the car.
the previous motor has like 30 miles on it with the ej22t heads and wrx headgaskets..
Can I re-use the HG's?? Im gonna be using ARP head studs with this motor also...
Thanks guys.
mxpunk is offline   Reply With Quote
Old 08-04-2007, 10:43 PM   #2
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
no, you can't reuse the headgaskets.
Old 08-04-2007, 11:17 PM   #3
WJM
Guest
Member#:
DONT use ARP head studs. Use the stock bolts. Use factory head gaskets. NO you cannot reuse ones that have already been used.
Old 08-05-2007, 12:16 AM   #4
modaddict
Member#: 95840
sold to a good bud
awaiting next car
reddevil reuses head gaskets......his engines last atleast 200 miles
I wonder if they have lasted over 1k?
j/k dood......kinda....
modaddict is offline   Reply With Quote
Old 08-05-2007, 12:45 AM   #5
Homemade WRX
Member#: 33782
96 bastard child
I would save your money as well and not run the arp studs...overkill for your biuld...put the money into new gaskets and a used 2.5rs motor or wrx heads...
Old 08-05-2007, 01:31 AM   #6
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
blaa the 1.8 is gonna stay boosted for some time until i get rs heads and a 2.2 block so i can do a big hp motor..the 1.8 is just to learn on and go fast
im gonna be running like 18-20 psi through this thing once its up and running again (td04 turbo w/ fmic)
u sure arp's arent worth it?
Old 08-05-2007, 02:17 AM   #7
Brydon
Member#: 107569
1998 Forester S
SRP
Yeah don't worry about ARPs. Stock bolts will go over 500whp with no problems.
Brydon is offline   Reply With Quote
Old 08-05-2007, 08:55 PM   #8
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
HMm.
How much WHP will require ARP studs?
Or is that a boost related type of thing?
Old 08-05-2007, 10:27 PM   #9
Homemade WRX
Member#: 33782
96 bastard child
it is in cylinder pressure...bmep...basically your hp level...not boost pressure as boost pressure doens't mean hp...
your EJ18 will not be capable of lifting the head with the factory studs...you are perfectly safe.
Old 08-05-2007, 11:21 PM   #10
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
haha, yeah, don't resuse the head gaskets. Even though I HAVE had success, it sure as hell isnt worth it when it fails!
Old 08-05-2007, 11:54 PM   #11
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
i think the block could support 300 whp for altitle bit..would that be enough? im not shooting for that # though but i would think that might be enough power to lift the head..lol
ok since you said so i wont..i know you're the sage of using old parts
now..
ej18e block w/ ej22t heads
im using usdm wrx hg's on there now..should I get them again or get the 2001 ej22 headgaskets?
Old 08-06-2007, 12:16 AM   #12
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
You can get metal 3 ply 2.0 gaskets...... I know cause I have a pair that was sold to me accidentally when I ordered 2.2t gaskets....
Old 08-06-2007, 12:33 AM   #13
Homemade WRX
Member#: 33782
96 bastard child
nope 300 isn't enough...maybe wipe off the 3 and put a 5
which at that point you wouldn't be on an EJ18 block and EJ22t heads either as the heads can't make that power and the EJ18 block would have to be built and would have some high rpms and high pressures
Old 08-06-2007, 04:36 PM   #14
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
did you use them..if not, wanan' sell them to me? pm me ..
Old 08-06-2007, 05:31 PM   #15
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
I am holding onto them for now.
Call Discount Import Parts at 503) 626-7036 and ask for Gerald. Tell him you need the 3 ply metal headgaskets for the 2.0 and he will know what you are talking about. Tell him Doug sent you to him. They ship UPS.
Thank you for visiting Discountimportparts.com. We are currently working on a online catalog. You are more than welcome to click the link below to request an email quote. We will respond within 24 hours during the week, or on Monday if you email us over the weekend. Thank You!
Quote form
Or contact us at
Toll free @ 1-877-659-7444
Old 08-06-2007, 09:51 PM   #16
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
thanks doug.
wish me luck with my 1.8T!!!
Old 08-07-2007, 09:21 PM   #17
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
hey doug..are these the ones that are $32 a piece?
gerald wasnt in the store i called..will try that tomororw.
Old 08-07-2007, 10:16 PM   #18
ai42
Member#: 71348
1999 EJ207 RS.TI
VW Golf TDI 40mpg baby!
Wow EJ18 turbo... Heh I ran 14 psi on my EJ18 turbo with stock heads, and 100k miles on the motor. I really don't think a TD04 can push 20 psi without dumping heat out.
ai42 is offline   Reply With Quote
Old 08-08-2007, 04:07 PM   #19
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
Yeah..I agree. Sort of. Some people are running 20-22 and I even read 25 PSI DAILY on their wrx's..so I dont see why I couldnt run atleast 20 with the big front mount I have.
17 psi seems to be the magic number of the td04's efficieny.
maybe im on my period, but this made me tear up Indocti Discant Off-Topic 31 06-03-2010 09:44 PM
Im poor, buy my stuff.. overtheover SCIC Private Classifieds 23 07-21-2008 01:57 PM
so i laid down the cash...im poor.. sweetsuby Mid West Subaru Owners Club Forum -- MWSOC 27 05-13-2002 12:57 PM
my poor, poor car burr101 New England Impreza Club Forum -- NESIC 6 11-15-2001 01:53 PM
You poor, poor Americans! WRXRob WRX Forum Archive 21 02-19-2001 09:15 AM
