Old 08-05-2007, 04:19 AM   #1
kdogae86
Member#: 99139
02 wrx
bluey
Default crower stage 2 cam in stock motor ?
is it required to replace the buckets if running stage 2 cams at stock red line.is there much power gain on a stock motor with stage 2 cams?sorry if this has been covered before
kdogae86 is offline   Reply With Quote
Old 08-05-2007, 07:28 PM   #2
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
what were the recommendations from crower?
but if the motor has low miles and the valve lash is acceptable
then it should be doable.
STAGE 2: Best cam choice for daily driver. Delivers excellent top end
without loosing low end torque. Recommend spring kit #84185.
RPM Range: 1000 to 7500+
Advertised Duration (Seat): Int: 264o / Exh: 264o
Duration @ .50": Int: 220o / Exh: 220o
Gross Lift: Int: .400" / Exh: .400" (10.16mm)
as for power gains, well that depends on turbo, head work, intercooler..etc..
Old 08-05-2007, 09:37 PM   #3
kdogae86
Member#: 99139
02 wrx
bluey
i asked for results on a completely stock motor.and i know it needs a spring
kit but it does not say anything about changing buckets.im assuming they will only need to be changed if revs are over 8k.i dont really have money for a bucket replacement.i guess the only answers would come from crower themselves.
Crower stage 2 cams, including springs/retainers $350 240sxguy MWSOC Private Classifieds 2 08-29-2010 09:18 AM
I have a set of brand new Brian Crower Stage 2 cams $570 El Crucial Engine/Power/Exhaust 7 11-09-2009 02:45 PM
Crower Stage 2 cams Poweredbysnail Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 06-20-2006 07:56 PM
Crower Stage 2 Cams ?? lazzy8oy Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 02-21-2006 10:06 PM
Crower Stage 2 Cams for WRX/EJ205 Heads - $600 shipped InfamousDX Private 'For Sale' Classifieds 4 08-13-2005 12:41 PM
