Old 08-05-2007, 09:15 AM   #1
sjl1614
Member#: 56791
06 OBS
Default AVCS block off plates?
Does any body sell block off plates for AVCS? Have a set of cosworth heads going in a wrx. I know that gruppe-s had a cam sensor adaptor to run a wrx ecu, but still need to block all the avcs oil passages on the heads. Also, any "dummy" plugs for the 2 cam sensor holes in the heads?
sjl1614 is offline   Reply With Quote
Old 08-05-2007, 05:02 PM   #2
WJM
Guest
Member#:
You really need to get all the AVCS peices and lines. Otherwise...bad things will most likely happen.
Old 08-05-2007, 09:04 PM   #3
sjl1614
Member#: 56791
06 OBS
I know it a large oil leak, was kinda hoping someone made some kit of kit to use on a non-avcs car
Old 08-05-2007, 09:09 PM   #4
ejh25
Member#: 65267
I have two alternatives if you want to use the AVCS:
(1) IA Performance wiring harness
(2) A Hydra or other stand alone
ejh25 is offline   Reply With Quote
Old 08-06-2007, 06:30 AM   #5
sjl1614
Member#: 56791
06 OBS
It's not going to be used, that's the problem. I need to block off all the avcs oil passages, hopefully without buying all the avcs parts
Old 08-06-2007, 09:04 AM   #6
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
I'd be interested in seeing what you come up with as I'm blocking off my avcs...I guess I'll see what I can do for is short of modding the cams.
Old 08-06-2007, 01:18 PM   #7
Peeblesmx445
Member#: 92202
Even though you are NOT using AVCS you STILL need to retain the factory oiling system of an avcs head because it will still act as a oil source for the cams. You will also need to use the proper banjo bolts with the screen filter inside them. The oiling system through there is very sentitive to debre.As far as sealing off the cam avcs sensor hole....I just used the sensor itself, but it wasnt pluged into anything.
Peeblesmx445 is offline   Reply With Quote
Old 08-06-2007, 02:34 PM   #8
SloRice
Member#: 44351
2004 Mitsubishi Evo
701whp [email protected]
Tap the AVCS holes on the front of the cam.
Insert set screws with locktite.
Install WRX cam seals and WRX cam gears.
No AVCS.
Profit??
SloRice is offline   Reply With Quote
Old 08-06-2007, 03:41 PM   #9
Peeblesmx445
Member#: 92202
No AVCS.
Profit??
Hes asking how to use AVCS heads as non-avcs heads on a non-avcs set-up. Not how to covert avcs cams to be used as non-avcs cams...
Old 08-06-2007, 03:56 PM   #10
bboy
Member#: 56468
04 Improved STI
Dirty White
That's a tough one, the AVCS solenoid is the oiling for that part of the cam. You can't simply block it off, you need to create a path for the oil too. I think I'd wire the solenoids up to the battery via an ignition relay, and just run with them in place and open all the time.
Old 08-06-2007, 08:22 PM   #11
Peeblesmx445
Member#: 92202
? I believe the avcs soleniods are actually oil pressure activated. The only thing electrical on my avcs heads are the avcs pick up sensors located on the rear of the head, by the back of the cam.... I have non-avcs cams in my avcs heads and I retained the avcs oiling but have zero avcs wiring.....
Old 08-06-2007, 08:26 PM   #12
sjl1614
Member#: 56791
06 OBS
I was hoping that will work. Looks like i will have to get all the stock parts anyways
Old 08-06-2007, 08:51 PM   #13
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Oil Dry Sump Goodness
You don't need to hook the AVCS solenoids to power but they must have oil as stated many times above. They feed the cam bearing.
mick_the_ginge is offline   Reply With Quote
Old 12-29-2007, 04:39 PM   #14
Rizzo314
Member#: 42215
2002 WRX being built
and going for 10s :evil:
Your PM box is full. I have some questions for you.
Rizzo314 is offline   Reply With Quote
Old 12-31-2007, 01:03 AM   #15
kaos200
Member#: 2692
It's quite simple really, if you are running NON avcs cams in AVCS heads, you still run the avcs lines, and leave the solenoid plugged in, these are absolutely necessary or bad joojoo. As for the rear cam sensors, you either leave them bolted in or make some aluminum covers to seal the holes shut like I did.
Obviously as mentioned the regular WRX cam gears and cam seals must be utilized.
If you want to run AVCS cams but not utilize AVCS it's the same as above but you must tap and plug the holes in the top cams.
edit: reading comp ftw. looking over the posts it seems most have got the idea.
kaos200 is offline   Reply With Quote
Today's events while attempting to fab block-off plates Prod Off-Topic 13 07-23-2007 12:04 AM
JDM amber side repeaters (new) and 03 fender block off plate PARANOID56 Private 'For Sale' Classifieds 8 04-22-2006 03:08 PM
04 Hood Sccop block off plate 2cati Interior & Exterior Modification 0 01-30-2004 06:02 AM
FREE: Hood scoop block-off plate 98-01 RS Strepto Rocky Mountains Impreza Club Forum -- RMIC 7 01-21-2004 02:12 PM
radio block off plate ellisnc Car Audio, Video & Security 16 11-08-2002 02:51 AM
