Old 01-05-2002, 02:53 PM   #1
bobo
Member#: 13050
02 WRX
Default need help installing the Subaru Alarm system!!
Hi everyone:
I need help for the alarm system! After I finished the installation and tried to test the alarm but it didn't work. Car starts fine and keyless lock/unlock works fine. Tried lock all the doors and use the key to open a door the alarm should chirp but didn't.
What I think is that I followed step 10 and 11 wrong. The rest seems straight forward.
For that black box installed behind the steering wheel how can I tell which one is the relay and which one is the starter interrupt?
Also, there is an insert on step 10 and 11 that shows a small rectangular thing that says install it what is that?
Here is what I've done. After I screwed the blackbox in, I connected the open connector to the left plug and the other from the recycle to the right plug.
If this is right what else have I done wrong?
Thank you very much for you help!
bobo is offline   Reply With Quote
Old 01-06-2002, 12:10 AM   #2
bobo
Member#: 13050
02 WRX
found the problem, never mind.
Need help installing the SPT Turbo Heat Shield...I am stuck! joserpm Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 03-27-2008 06:10 PM
Need help installing the SPT short throw shift lever joserpm Transmission (AT/MT) & Driveline 15 07-26-2007 11:42 PM
Need help installing the exhaust (East Lansing) Mwahaworld Mid West Subaru Owners Club Forum -- MWSOC 3 09-20-2002 08:33 PM
Need help install Alladin 2000 Alarm WRX hman Car Audio, Video & Security 2 04-11-2001 10:55 AM
