Old 08-06-2007, 01:54 AM   #1
rickeolis
Member#: 72134
2005 WRX Wagon
3" TB\UP-HT Springs-Rotas
Subaru Stars Car won't start after engine replacement...
2005 WRX wagon, Cobb A/P, catless exhaust, otherwise stock engine setup.
I have gas, a good battery, it even wants to start by spraying a bit of starting fluid in.
I'm confident the problem is fuel supply.
Additionally, my AccessPort seems to be an issue too. I have the green ends under the dash hooked together, the white adapter plugged in, but when I turn the key from accesory to on, the accessport goes out (turns off.)
I'm stumped, but don't want to deal with my local dealer anymore after poor service in the recent past.
rickeolis is offline   Reply With Quote
Old 08-06-2007, 11:13 AM   #2
rickeolis
Member#: 72134
2005 WRX Wagon
What would cause the A\P to turn off as soon as I hit the 'on' position of the ignition???
Old 08-06-2007, 03:06 PM   #3
Member#: 155531
This seems like a wiring issue. Have you check the ground wires from the chassis to the engine block? It sounds like a short when you turn the key to the on position.
David@Cobb is offline   Reply With Quote
Old 08-06-2007, 04:24 PM   #4
rickeolis
Member#: 72134
2005 WRX Wagon
Thanks so much David, since posting this thread this morning, I did call your shop and (I don't recall who spoke to me) he did suggest the same, which sounds reasonable.
I'll look into that this evening. The engine cranks strong, and I can listen to my stereo, but I still might have a bad ground going to the ECU or fuel pump system somehow for sure.
-Rick-
Old 08-07-2007, 11:47 PM   #5
rickeolis
Member#: 72134
2005 WRX Wagon
Good news, it's running!
I did find a bad ground point and fixed it, and it runs quite well now, anyone looking to buy a nice car?!?!?
2005 WRX wagon $18k obo.
Car won't start after flashing until power removed/replaced silentt Open Source Reflashes 9 04-17-2009 11:11 PM
Car won't start after first start plaines Service & Maintenance 0 01-17-2007 06:55 PM
Car won't start after FMIC install wrspssshhhh Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 03-27-2006 12:49 PM
HELP - Car won't start after turbo install Needles Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 29 06-30-2005 09:23 PM
My car won't start after clutch install! Please help!!! baldcherub Transmission (AT/MT) & Driveline 7 12-12-2001 12:35 AM
