08-06-2007, 02:23 AM | #1 |
Member#: 128985
Vehicle:2002 bugeye STi-ish MBP |
fuel smell @ WOT
sup guys, heres a little prob i got, hope you all can help me once again.
when i go WOT my car reeks of fuel. not that fuel smells that bad but the scent is really strong. FWIW im currently running hydra V2.17 i datalogged and my car seems to run rich in between shifts but the smell starts somewhere around 4k RPM's. heres a link to DL my datalog. http://www.speedyshare.com/290651608.html anyone else experience this at some point? thanx in advance.
08-06-2007, 09:38 AM | #2 |
Member#: 44351
Vehicle:2004 Mitsubishi Evo 701whp 9.91@146 |
linky no worky.
08-06-2007, 11:28 AM | #3 |
Member#: 54918
Vehicle:673 WHP Element Tuning Pro Comp Engine |
I don't think that's a tuning issue but more likely when your fuel pressure ramps up due to peak boost around 4k rpm you have a fuel leak. Check your fuel pressure regulator, your lines, and most importantly your fuel injector seals. You can loose a cylinder if you have a fuel leak at the fuel rail.
Phil www.elementtuning.com |
08-06-2007, 01:13 PM | #4 |
RIP 3/18/1965 to 1/10/2008
Scooby Specialist Member#: 91500
Vehicle:hmmm sr-30+640cc=? I has teh Endless BBK. |
^^^ even this noOb has seen engines/pistons from this circumstance.
isn't it amazing how many issues can be at least partially attributed to mechanical stuff...??? no wonder you protuners tell us to double-check our engines/vacuum lines... learning my lesson... |
08-06-2007, 01:26 PM | #5 | |
Member#: 128985
good advice. i only thought it was something regarding to the ecu because it started happening as soon as i got my ecu back from hydra. i sent it there to get reflashed to 2.17 and as soon as i got it back it started making the smell so i figured it was because of the box. but i will look at those items you listed. thanx phil. |
08-06-2007, 05:25 PM | #6 |
Member#: 56468
NWIC
Vehicle:04 Improved STI Dirty White |
Many people damage the rubber fuel injector seals when they do the swap.
