Old 08-06-2007, 12:56 PM   #1
Suberman
Member#: 82487
2007 WRX STI Spec C
Default Can Ecutek be tune 'live'?
Can it be tuned on the go? I've gotten an Ecutek reflash but am still not happy with the results. Car bucks and chokes when moving off probably due to the PE650 injectos i'm running.
I got the tuner "fine tune" it alittle and it did improve, but i noticed that he pulled over, made adjustments, restarted and tested it out, when asked, he said, Ecutek cannot be tuned on the move?
Suberman is offline   Reply With Quote
Old 08-06-2007, 01:15 PM   #2
cellobro
RIP 3/18/1965 to 1/10/2008
Member#: 91500
hmmm sr-30+640cc=?
I has teh Endless BBK.
nope, it can't.
see their site, they are offering a new product for that, I forget the name.
my question is, can other software tune the Ecutek-flashed ecu...
www.ecutek.com I think...
cellobro is offline   Reply With Quote
Old 08-06-2007, 08:51 PM   #3
Suberman
Member#: 82487
2007 WRX STI Spec C
Originally Posted by cellobro View Post
nope, it can't.
so basically, the tuner can only make adjustments such as timing, fuelling before and/or after a dyno run, then run it and if it knocks, stop the run, retune it and run it again??
If so, i can see how some tuners end up blowing engines.
Old 08-06-2007, 09:26 PM   #4
cellobro
Member#: 91500
hmmm sr-30+640cc=?
no, no, that's not what I meant... our local Ecutek tuner does not, to my knowledge (afaik) use the ecutek software that requires reflashes.
I don't know for certain WHAT he uses, but I've seen/heard the dyno, it's live.
what I thought you were asking about was Delta Dash & if it live-tuned or not. it does not 'tune' fuel/load/boost et cetera (timing, idle, mebbe) but it does log.
I have NO CLUE what your tuner is using, for all I know it's the openecu/enginuity combo
I was speaking of the new (well, kinda new ) software that allows owners to tune live.
oops, I guess
Old 08-06-2007, 09:35 PM   #5
dingobite
Member#: 82391
08 OBP Sti
dom 2.5xt-r 384hp 412tq
nope, it can't.
$12k is the lowest ive heard the software would go for, i think the wrx software cost more.
dingobite is offline   Reply With Quote
Old 08-06-2007, 10:57 PM   #6
Suberman
Member#: 82487
2007 WRX STI Spec C
What about map switching feature of the Ecutek? Is this only a boost map (from my understanding) or can it switch between ignition maps as well?
Old 08-14-2007, 09:17 PM   #7
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
just the boost map..
but the factory ecu will run as much as possible
thats allowed in the ignition base / advance maps..
until it senses knock. then starts to pull timing.
Can UTEC be used along with ECUtek? cribbie UTEC 4 02-12-2010 01:03 PM
JDM Ver 7 ecu......can it be EcuTek reflashed? VtecGSR95 Commercial ECU Reflashes 6 09-15-2006 05:10 PM
Can a BOV be tuned safely? WrxRick General Community 16 04-24-2006 10:15 AM
Can ecutek be flashed back to stock?? MachinesWRX Engine Management & Tuning 1 11-30-2005 08:20 AM
Can an off-the-shelf ECUTek reflash for vf34 with STi injectors be tuned with... The Modaholic Engine Management & Tuning 2 12-26-2004 11:13 PM
