Welcome to the North American Subaru Impreza Owners Club Tuesday July 28, 2015
Old 08-06-2007, 01:02 PM   #1
BroomHandler
Member#: 129855
2007 Impreza 2.5i
Grey
Default Funky smell from the air condition
Hello Guys and Gals,
I'm beginning to notice a bad smell coming from my air vents whenever I use my air conditioning. It smells really acrid and musky, almost like a bum. This happens only after I use the air conditioning, not before or during. The first time this happened, I was with my wife and I said "Dang, did a bum crawl under the hood or something"? My wife didn't really notice it but it kinda bothered me. It's happened every time since; the acrid smell always comes after I turn off the AC.
Has anyone else had this problem? Is this something that is covered by the warranty or is this just one of those "lovable quirks" that I should get used to?
Any input would be appreciated!
BroomHandler is offline   Reply With Quote
Old 08-06-2007, 01:21 PM   #2
bugeye829
Member#: 81995
2005 Scion xB
02 WRX 247k RIP
maybe a dead mouse in the evap? anyway try spraying some frigi fresh in there to make the smell go away
bugeye829 is offline   Reply With Quote
Old 08-06-2007, 01:44 PM   #3
joecerv
Member#: 110459
2006 Impreza 2.5i
Steel gray metallic
If there was anything dead on your system you will smell it all the time.
The smell you are describing can happen.
In my case, after turning off the AC and letting the fan stay on will provide a muggy, but, not acrid smell on my vents for a couple of seconds.
I just leave the fan on for a minute or so before turning off the car to dry off any moisture left in the system.
joecerv is offline   Reply With Quote
Old 08-06-2007, 02:00 PM   #4
105wrx
Member#: 75931
2005 hmmm STI?
Clark Tuned!
check your cabin air filter and see if it is causing the smells...
105wrx is offline   Reply With Quote
Old 08-06-2007, 02:08 PM   #5
joecerv
Member#: 110459
2006 Impreza 2.5i
Steel gray metallic
According to the OP:
"the acrid smell always comes after I turn off the AC."
If the cabin filter was at fault, the smell will always be there.
Old 08-06-2007, 02:42 PM   #6
zellner_88.subaru
Member#: 155790
so the smell is bactiria in the air box. ya the smell is gross but you can fix the problem by taking your car to the dealer and they will spay a chemical in there to kill the smelly bugs!
zellner_88.subaru is offline   Reply With Quote
Old 08-06-2007, 02:46 PM   #7
MASTERMIND65
Member#: 124539
2005 Hybrid, PPGs
I am job
I would pull on the cabin filter and see if water is sitting some where it souldn't be.
MASTERMIND65 is online now   Reply With Quote
Old 08-06-2007, 02:52 PM   #8
BroomHandler
Member#: 129855
2007 Impreza 2.5i
Grey
Hey, thanks for all of the advice you guys! Much appreciated!
Old 08-06-2007, 02:55 PM   #9
MASTERMIND65
Member#: 124539
2005 Hybrid, PPGs
I am job
hopefully something works out, let us know.
Old 08-06-2007, 05:27 PM   #10
sadsack
Member#: 102327
2003 Legacy - RIP
I just changed my cabin filter this past weekend, along with nukage of the vent system. So far (2 days out), no funk.
Wurth makes an aerosol cleaner for A/C systems - it's ammonium chloride + "febreeze" type odor eliminators - $20-30 a can.
To use, first nuke the vents (Dash, exterior intake under the hood), and the evaporator itself for good measure (leave the cabin filter out for this process). Let sit for 15 min, then start up the car with A/C on recirculate and fan speed maxed. Spray the cleaner into the cabin air return (turn recirculation on & off to see the door on the blower housing open and close - this is the return). Make sure that you put the filter cover panel back on and have the blower motor resistor pack connected before starting up the A/C.
The Wurth can is big enough to do 2 rounds of this treatment.
Make sure to clean the inside of your windows - the cleaner leaves a very slight haze. Alternately, roll down all windows and open all doors to minimize "loading" of the vehicle interior.
sadsack is online now   Reply With Quote
Old 08-06-2007, 09:05 PM   #11
scoobydoo33
Member#: 152860
2007 WRX Wagon
Oh.........
My Moms car had that smell when I was younger.........
Blehhhhhhhhh!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!
scoobydoo33 is offline   Reply With Quote
Old 08-06-2007, 09:27 PM   #12
jeraljay
Member#: 151189
05 Saab 92x aero
Desert Silver-STG 2
put some limes down the vents like you do for your garbage dispose while its running. works everytime
jeraljay is offline   Reply With Quote
Old 08-06-2007, 09:42 PM   #13
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
To prevent mold/mildew from building up in the evaporator and stinking, it's a good idea to turn off the AC a short distance before reaching your destination and parking, while leaving the vent fan running. This will allow some time for the evaporator to dry out, so there is less standing water where the stuff can grow.
Also do not use the recirculate mode unless absolutely necessary.
Old 08-08-2007, 06:56 PM   #14
AbACUZ
Member#: 101898
1905 NINETWO EX AIRO
Prodriv.Hotchkis.Stromng.
all of the above , plus something they have not mentioned
Park the car, leave it on , close your windows almost all the way and on a hot day , turn the heater on, leave it like that for a few minutes
AbACUZ is offline   Reply With Quote
Funky noise from the front of my bugeye Fireguy615 Brakes, Steering & Suspension 0 12-15-2009 09:17 PM
weird smell coming through air condition vents JustAnotherSubie Newbies & FAQs 30 04-09-2009 12:54 PM
How hard is it to recharge the air conditioning system wrxlvr Off-Topic 4 05-20-2005 04:54 PM
How's the air conditioning? ebr0t General Community 24 08-28-2002 12:16 AM
