Alaskan Impreza Club
Old 08-06-2007, 02:45 PM   #1
spike589
Member#: 122837
2008 speed3
red
Unhappy weird overheating issues
I have 04 sti
about a week ago i noticed while seating at a light that my car temp started to rise, I turned on my heater to try to drop the temp but it blew cold air at first then to warm then hot. So i pulled over as soon as i could to see if i blew a hose or a radiator cap, no leak noticed. My overflow reservoir was full to the top, when i got back in the car to see if the temp kept rising but the temp somehow dropped to normal operating temp,i let cool down and popped the radiator cap off to refill with fluid.After that i drove around and then home and i didnt have a problem, almost like a fluck.
the next day i was driving normal and notice the temp come up again and i was on the highway this time , but before i can move over to pull over the temp just dropped back to normal like the gauge was going or somethign. but i pulled over anyways and my reservouir was overserviced again
it just been consistently doing that for the next few days it will rise then drop to normal
I spoke to bunch of subbie owners and they all aggred that the thermostat is the cause of the problem. so i replaced it yesterday burpped the system for 6 minutes at 3500rpm's all bubble are out ( i forgot to mention i tested the old thermostat and it checked good-open properlly and at right temp) took it for a test drive and same thing happen , temp got high then cam back down. got home let cool check oil levels -good- check for milkiness or traces of coolant for blown head gasket-good- psi check both radiator caps -good- ( on radiator and reservoir for turbo) so im up s%^t creek with no answers. Fans do come on but dont know what the duty cycle is or if their coming on properlly or at the right time but they do come on both of them. help!!!!!
thanks for any help in advance
907-350-5783-omar
spike589 is offline   Reply With Quote
Old 08-06-2007, 03:05 PM   #2
Getagrip
Member#: 2045
BRZ
Sounds like you checked most obvious things. Maybe a Conti tech could have a look at the vehicle.
Call me for a reservation
Jake 261-0632
Getagrip is offline   Reply With Quote
Old 08-06-2007, 06:39 PM   #3
spike589
Member#: 122837
2008 speed3
red
how would fan relays make a difference in cooling
Engine Overheating Issues... MrWicked Service & Maintenance 1 06-04-2010 01:23 AM
Thermostat / overheating issues Sort of odd issue psychoskip Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 12-15-2009 09:18 PM
Weird fueling issue. Not enough fuel, add a pump now insanely rich???A/F weirdness. Defiant Autospeed Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 21 11-19-2007 05:30 AM
weird overheating issue spike589 Service & Maintenance 3 08-08-2007 02:52 AM
weird overheating issue spike589 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 08-06-2007 06:47 PM
