Old 08-06-2007, 04:39 PM   #1
sciroccokid
Member#: 122356
2002 Impreza WRX
World Rally Blue
Default Going open source, saftey periperals?
I am going open source today with the purchase of a tactrix cable.
Few questions:
1. Is it a necessity to have a wide band 02/other peripherals?
2. How much power am I losing by not having an uppipe (I have a intake/downpipe)?
can't wait to tune . . .
sciroccokid is offline   Reply With Quote
Old 08-06-2007, 06:37 PM   #2
Zumble
Member#: 34860
2005 Forester CGM
If you're going to be doing any meaningful tuning at least get a wideband sensor and a knocklite.
The uppipe is worth a few HP but the big advantage of a catless uppie is better turbo spool.
Zumble is offline   Reply With Quote
Old 08-06-2007, 07:13 PM   #3
quazimoto
Member#: 70395
Not to mention a cated up-pipe has taken out a few turbos once it's kicked the bucket...
quazimoto is offline   Reply With Quote
Old 08-06-2007, 07:23 PM   #4
sciroccokid
Member#: 122356
2002 Impreza WRX
World Rally Blue
What is the cheapest wideband available? they seem fairly expensive.
I thought that the up pipe was a big part of a stage 2 tune? It is encouraging to hear it is mostly spool.
Old 08-06-2007, 07:29 PM   #5
WeldingHank
Member#: 98645
2002 WRX Wagon
and you don't have to worry about the cat breaking up and jumping into the turbine. I recomend the Innovate LC-1. I got mine for $200.
WeldingHank is offline   Reply With Quote
Old 08-06-2007, 11:04 PM   #6
Zumble
Member#: 34860
2005 Forester CGM
I think one of the cheapest would be the AEM UEGO gauge. It's a good wideband gauge. The LC-1 is a nice unit but you have to buy the gauge separately.
Old 08-06-2007, 11:08 PM   #7
Freon
Member#: 88322
2009 BMW 135i
I recommend the LC-1. It's pretty cheap, good unit, feature rich. You can log it with Ecuedit (pay version) or Enguinity. The basic gauge is only $60 and is good enough as an idiot light. For actual tuning you need to have the log threaded anyway.
Freon is offline   Reply With Quote
Old 08-07-2007, 08:13 AM   #8
blkscooby
Member#: 44422
2009 G8 GT
Cammed, sprayed, stalled
I second what Freon said. I use the LC-1 for all the tuning that I do and it works great with Enginuity as a logger.
blkscooby is offline   Reply With Quote
Old 08-07-2007, 10:02 AM   #9
sciroccokid
Member#: 122356
2002 Impreza WRX
World Rally Blue
Is the knock light necessary? From what i have read the open source tuning seems relatively safe. That being said if it is necessary, I want it, as a ruined engine is the last thing i need.
Someone should sell a Open Source kit will all the basic hardware. . .
If HP per dollar is my goal. And I need, a tactrix cable, knock sensor, wideband sensor, egt?, etc. How much are we now talking. Should I just get a cobb accessport, this may end up being cheaper (and safer).
Old 08-07-2007, 11:15 AM   #10
Freon
Member#: 88322
2009 BMW 135i
Several sites (including Innovate directly) sell a LC-1 + Tactrix cable combo. I don't think you really need anything else. EGT might be good if you really want to push it, but you can live without. I don't use a knock light. I don't think it is required. Can't hurt, I suppose, but I'd still count more on careful logging.
I do, however, have my stock knock sensor hook up to my car stereo. That only takes $5 in parts from Radioshack.
Old 08-07-2007, 11:55 AM   #11
t4nk
Member#: 129905
2005 WRB WRX
2003 F-350SD, 7.3PSD
i beg to differ, my cat broke up and grenaded my turbo
t4nk is offline   Reply With Quote
Old 08-07-2007, 11:56 AM   #12
rkramer
Member#: 118209
2015 WRX Limitec
there really is no comparison. they both will provide a good base map without tuning at all. If you have a stage 2 car, there are plenty of good open source stage 2 maps out there that you can burn onto the ecu and forget about it.
if you want to jump into tuning, you will need this equipment either route you take.
Old 08-07-2007, 12:07 PM   #13
sciroccokid
Member#: 122356
2002 Impreza WRX
World Rally Blue
Can i do an open source tune with a trusted stage 2 map, safely, with out a wide band o2?
I have a DP/intake, but no up pipe/cat back. . . yet.
Old 08-07-2007, 12:21 PM   #14
t4nk
Member#: 129905
2005 WRB WRX
yeah, id recommend an up pipe tho.. way better spooling!
Old 08-07-2007, 12:22 PM   #15
Jon [in CT]
Member#: 2992
02 WRX Sedan
I don't think you need a knock light. Follow this link for an Open Source kit:
http://tunertools.com/proddetail.asp?prod=IN-3791
In the past, if you entered enginuity as the discount code there, you'd get a 5% discount.
Jon [in CT] is offline   Reply With Quote
Old 08-07-2007, 01:15 PM   #16
sciroccokid
Member#: 122356
2002 Impreza WRX
World Rally Blue
Thanks for the link. I want to do that up pipe, just looks sounds like such a bi*$#. Need to find a stock one to gut, prior to install.
Thanks for everyones help, Stage 2 is going to be fun.
Old 08-07-2007, 01:38 PM   #17
rkramer
Member#: 118209
2015 WRX Limitec
I'll have one for sale cheap soon! (just have to get some ambition to box it up...)
anyway, yes you safely can run a stage 2 map from osecuroms without tuning on it. and although it is morally and legally questionable, you can also get your hands on a cobb stage 2 map fairly easily if you want to try that.
Old 08-07-2007, 02:06 PM   #18
Freon
Member#: 88322
2009 BMW 135i
Old 08-07-2007, 02:08 PM   #19
t4nk
Member#: 129905
2005 WRB WRX
ive got a catless sitting in my garage. 40 bux plus shipping and its urs.
Old 08-07-2007, 03:16 PM   #20
sciroccokid
Member#: 122356
2002 Impreza WRX
World Rally Blue
So, do you load the cobb map via open source? Feel free to PM. Thanks, interested in this concept.
Old 08-07-2007, 03:17 PM   #21
sciroccokid
Member#: 122356
2002 Impreza WRX
World Rally Blue
sold, pming.
Old 08-07-2007, 04:02 PM   #22
t4nk
Member#: 129905
2005 WRB WRX
its an interesting concept, yes. But its stealing! i have very high respect for cobb, they are one of the pioneer's in subaru tuning! I think stealing their maps is very wrong.. If you are going to go open ecu, use open ecu maps, dont take a map from cobb.
Old 08-07-2007, 04:14 PM   #23
sciroccokid
Member#: 122356
2002 Impreza WRX
World Rally Blue
Fair enough, I can appreciate that. i dont see why they would be better anyways.
Old 08-07-2007, 04:54 PM   #24
Jon [in CT]
Member#: 2992
02 WRX Sedan
Stealing free maps - interesting concept.
Old 08-07-2007, 05:43 PM   #25
t4nk
Member#: 129905
2005 WRB WRX
cobb maps = extremely safe, the power output it not at its highest point due to the safety measures.
xpt maps = noticeable amounts of extra power, but need to be datalogged to make sure you are not causing your motor any harm. I've flashed a few people that i had to modify the map slightly to make it run right.
SCIC...HELP! Need Open Source tuner generalganja Southern California Impreza Club Forum -- SCIC 31 06-07-2010 04:42 AM
Question about open source tuning Chasey Newbies & FAQs 8 06-05-2010 09:02 AM
Help figure what's the best way too go open source or cobb????????? rdiaz206 Open Source Reflashes 3 03-14-2009 02:33 AM
Keep AP or go Open Source Gray Ghost North West Impreza Club Forum -- NWIC 31 12-16-2008 06:53 PM
Open-Source ECU Tuning sajohnson Engine Management & Tuning 1 02-12-2003 12:28 AM
