Welcome to the North American Subaru Impreza Owners Club Monday May 25, 2015
Old 08-06-2007, 06:06 PM   #1
OCrex
Member#: 78696
2005 Wingless STI
Default 05 STI, FP Red on dyno log
hey guys after working all weekend on this install i finally finished it. had to grind the block for the lower coolant line, loosen the intake manifold to muscle on the inlet pipe, which may i say does not fit correctly no matter what perrin or FP say.
Got everything done about 2 hours before i was scheduled to get tuned.
Mods:
FP Red 7cm housing internally gated
perring 3" inlet
cobb 70mm intake
invidia divorced wastegate dp
stock up
aps 3" single tip exhaust
pe 800s with pump
ssac fmic core with aps pipes and aps fmic bov
OH, and the TGV's are still installed!! had to remove the rear sensor on the passenger side though for the turbo to clear.
DYNO: Dynolog (low reading)
Numbers before the turbo swap with everything the same but the fmic, inlet and turbo:
228whp, 264wtq
Numbers now:
341whp, 303wtq 19psi
i gained over 100hp from the stock turbo and it pulls to redline. Problem is with the IWG, i'm having boost creep up to 22-23 psi at redline. my tuner tried to add fuel up there the best he could but the wastegate was 100% open and still building boost.
I'll post all the graphs when i get home so you guys can take a look. I'm very impressed with how responsive the car is and i think those are pretty good numbers on this dyno. I believe a stock sti dynos below 200 on this.
graphs coming.
CJ
OCrex is offline   Reply With Quote
Old 08-06-2007, 06:10 PM   #2
xdrian
Member#: 104200
828 WHP BUGEYE
Street Proven Performance
CJ
that could be a problem ! they not opening !
xdrian is offline   Reply With Quote
Old 08-06-2007, 06:17 PM   #3
BillMac
Member#: 124593
2007 Sti fp red
346whp 366wtq
may have been a lil easier to get the inlet on if the intake manifold off
BillMac is offline   Reply With Quote
Old 08-06-2007, 06:18 PM   #4
OCrex
Member#: 78696
2005 Wingless STI
what problem would that be? if one of those plates isn't open, you'll know it!
Old 08-06-2007, 06:19 PM   #5
OCrex
Member#: 78696
2005 Wingless STI
yes it would have been, but with the diameter being what it is and the dogleg left at the end not being aggressive enough, it still got crimped like a motha on the manifold right before the turbo. either way, we got it in.
Old 08-06-2007, 07:26 PM   #6
blkscooby
Member#: 44422
2009 G8 GT
Cammed, sprayed, stalled
Sounds like an 8cm hotside might have helped with the creep issue.
blkscooby is offline   Reply With Quote
Old 08-06-2007, 07:29 PM   #7
AspenWhite_STi
Member#: 97616
2005 AW STi - GONE
2009 Black 135i
Why didn't you go with the 8cm exhaust housing to begin with? Are you planning on running an external wastegate later on?
AspenWhite_STi is offline   Reply With Quote
Old 08-06-2007, 07:42 PM   #8
BOXERVIK
Member#: 114285
2006 sti
aspen white
nice, especially since u were able to keep the tgv, post a dyno graph and where did you get tunned at
BOXERVIK is offline   Reply With Quote
Old 08-07-2007, 12:11 AM   #9
STIred05
Member#: 115223
2005 Subaru STI
I would look for a vac pre turbo I had the same thing w/ my 7cm red... it turned out to just be a vac leak pre turbo.
STIred05 is offline   Reply With Quote
Old 08-07-2007, 01:11 AM   #10
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
EWG will help tremendously.
wcbjr is offline   Reply With Quote
Old 08-07-2007, 10:47 AM   #11
OCrex
Member#: 78696
2005 Wingless STI
well, i didn't go with the 8cm because i bought this turbo from a guy here on nasioc, although it was brand new. i do plan on going EWG in the future.
don't think i have a leak, we watched the wastegate open up 100% and the turbo was still building boost. can't hurt to check this out though.
I got it tuned at Mavrik Motorsports by Ed (formerly of ESX, Brainstorm...) He hadn't tuned in a while. took him 8 hours and he didn't start till 8pm sunday night. i was there till 4am!! he never gave up though.
Here are the graphs. The third shows my old dyno vs. the new. my AFR's go a bit lean at redline due to the boost creep. Ed tried to add fuel up top but wasn't noticing any increase in fuel past 85% duty cycle. He couldn't figure out why.
The car feels very responsive and is an animal when it comes onto boost. i love the high pitch whistle the turbo makes as well.
Old 08-07-2007, 01:50 PM   #12
benw
Member#: 103320
2005 wingless
aspen white
nice! Your car is a great candidate for alcohol injection... you could safely run that 22-23 psi number I'd bet.
benw is offline   Reply With Quote
Old 08-07-2007, 02:07 PM   #13
TopEndPull
Member#: 126112
93.5 Toyota Supra
Red
thats nice since your able to still keep the tgv's
TopEndPull is offline   Reply With Quote
Old 08-07-2007, 02:38 PM   #14
OCrex
Member#: 78696
2005 Wingless STI
thanks guys. i thought it was a good number on that dyno, especially with the tgvs still in. i plan on removing them, installing an EWG and adding meth hopefully early next year. i'd love to break 400 on that dyno.
got to learn to drive my car before i do that. i have 140 more hp and 100 more tq at redline now so it's a handful for me right now. fun as hell though.
Old 08-07-2007, 02:57 PM   #15
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
graphs look nice, although its hard to see much definition with those thick lines in that chart. did Ed purposly lean it out up top, looks like it worked well the power just keep climbing.
edit: read your comment nevermind ^
PaulRex is offline   Reply With Quote
Old 08-08-2007, 12:31 AM   #16
benw
Member#: 103320
2005 wingless
aspen white
he says earlier why
Old 08-08-2007, 04:18 AM   #17
STimo
Member#: 110273
450 whp 30R STI
11.3@123, 10's a commin'
Nice, did ed open a shop up in fullerton now or is he just tuning there?? He tuned my buddies 350Z with APS TT kit and he did a great job, that car was alot of fun.. Also did one of my buddies sti's that came out really well..
STimo is offline   Reply With Quote
Old 08-08-2007, 04:54 AM   #18
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Is this on 91 Octane and do you have an EGT gauge?
-- Ed
Equilibrium Tuning is offline   Reply With Quote
Old 08-08-2007, 07:47 AM   #19
crazymikie
Member#: 56321
2006 Honda El Camino
Green
Post up a log if you can, specifically with AFR and MAF g/sec. If the MAF limit wasn't upped or if the intake wasn't scaled correctly, this could account for what you are seeing.
crazymikie is offline   Reply With Quote
Old 08-08-2007, 10:31 AM   #20
OCrex
Member#: 78696
2005 Wingless STI
Ed is currently working at South Coast Subaru, but will be moving to Irvine Subaru as the shop forman. He is tuning part time at Mavrik.
yes this is on 91, unfortunately i don't have a egt gauge yet.
crazymike, these are all the printouts i got. Ed almost finished the tune when he realized he was on the small map for the maf. He bumped it up for the bigger maf and it through off a lot. He had to go back in and take out a lot of fuel in the midrange.
Old 08-08-2007, 01:25 PM   #21
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
'07 Honda FIT sport (5MT)
Now my question is this.
Is he lifting early? Or is the dyno not reading right? By 6600 RPM your power levels are absolutely tanking, as is boost.
Now, is the 3.93 correction a percentage? If so sounds like you're making around 250AWHP on an uncorrected dyno. Might be a touch low, but on 91 octane it certainly isn't unthinkable.
Other then that, looks good!
If he's dialing in fuel up top, and it's not enrichening consider the pump, regulator, or pump controller.
Yes, I know you have an aftermarket pump, but believe me, it wouldn't be the first time I've had a similar situation with a "walbro", to swap it, and all of the sudden flood the fuel mixture because I had been over compensating it in vain.
Looks great!
Jorge (RiftsWRX)
www.ProjectWRX.com
RiftsWRX is offline   Reply With Quote
Old 08-08-2007, 02:16 PM   #22
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
That a/f combined with the boost creep is very scary on 91 octane. If you had an EGT gauge you'd see what I'm talking about. If the reported IDC's are increasing but fuel delivery is not, its most likely not a tuning issue but rather a mechanical one. Check your fuel pressure as its likely dropping at higher flow rates.
-- Ed
Old 08-08-2007, 03:48 PM   #23
OCrex
Member#: 78696
2005 Wingless STI
those are some good points guys, thanks. i've emailed Ed and we'll see what he says. i was also concerned about the boost and a/f. he said it's close so i shouldn't do any hard pulls up a hill but since the car is under less load on the road, it should be ok, just be careful.
Old 08-10-2007, 03:26 AM   #24
luspeed
Member#: 65120
2005 EJ257 Hybrid
Nice numbers! I was wondering how they would turn out? You were like the 3rd car Ed was tuning that day and you had yet to get on the dyno when I left around 5:30pm. I knew you were in for a long night, but damn, 4:00am! You're lucky that Ed could still keep his eyes open to tune right I gotta say, this is a very low reading dyno guys. I was tuned earlier the same day as OCrex by Ed, but instead my set up is an 05 WRX with:
fp 18g 7cm
aps cold air intake (65mm)
spec c sti intake manifold
fujistubo equal length header
acpt carbon fiber drive shaft
exedy light weight flywheel
cobb 3" downpipe
aps uppipe
3" greddy evo 2 catback
pe 650cc injectors
jdm sti top mount
v6 sti ra gear set
My numbers on the dyno that day were 260whp/240wtq @ 20psi on 91 (piss poor) pump. I got tuned on the same dyno back in January and put down 237whp/208tq with an fp16g, stock intake manifold, stock exhaust header, and the rest of the mod list above. What's interesting is when I came in on Sunday Teddy at Mavrik explained that since my January tune, the dyno was recalibrated and now all whp numbers, including previous runs, would be showing a little lower. Sure enough when he pulled up my run from January, it was now only showed 224whp/199tq. So bascially I ended up with +36whp/41wtq. For reference when I got tuned back in January, a guy with a stage 2 06 sti w/perrin equal length header put down 241whp on that dyno.
For arguments sake we can say that a typical stage 2 sti on this dyno would be somewhere in the 230whp range right now. With OCrex putting down 340whp he's about a 110whp over a stage 2 sti. With the typical stage 2 sti showing about 280-290whp w/91 pump on an acurate reading dyno, I'd say OCrex is legitmately at 400whp right now. Not bad for Ed operating in red-eyed sleep deprived mode. Congrats again on the numbers dude, and be sure to get tgv deletes and a header. You will make more power for sure! Imagine what that set up would do on 100 octane?
Lu-
Btw, I noticed the numbers for rpm were slightly off on my graph. They were about 200rpm higher than they should have been which means the rpm settings on the dyno were slightly off. That might explain your power curve issue....
luspeed is offline   Reply With Quote
Old 08-10-2007, 07:34 AM   #25
DJSuperSoul
Member#: 120004
2xx8 STI
grey
good numbers, i run a fpgreen 3" 8cm turbo / 800cc injectors, turboxs frontmount, and big maf on my sti, and put down 350/390 with this combo. this is at 19psi tapering as we near redline.
DJSuperSoul is offline   Reply With Quote
Dyno Tune: COBB Tuning makes 350whp/403wtq! 05 STi, Stock turbo on E85! Cobb Tuning Proven Power Bragging 12 02-19-2010 02:54 AM
Agile Tuned 04 Sti - FP Red/Q16 1/4 mile run 04fpgreensti Proven Power Bragging 19 07-24-2009 04:23 PM
For Sale (AZ): 2004 Blue STi/FP Red 500+whp ride_the_pony69 Private Vehicle 'For Sale' Classifieds 4 07-10-2007 08:51 PM
FP Red on a 2.5 wukindada Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 25 09-27-2006 09:23 AM
FP RED on Stock 2.0, Questions??? Peeblesmx445 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 10-30-2005 01:15 AM
