Closed Thread
Old 08-06-2007, 08:42 PM   #1
AxlxA
Member#: 121968
2007 WRX Wagon
Urban Grey Metallic
Default HID Beam cut off/pattern - Need Help!! 07 WRX
hey guys, I just put in some HID conversion kit into my 2007 wrx wagon.
Now i think i might've done it wrong... the cut off pattern is so strange... it's like the passenger side is higher than the driver's side... is this normal?
When i was putting the headlight units back into the body... the passenger side gave me some problem... the screws on top didn't quite align with the holes... normally it sohuld align perfectly. It was off by about 5mm. I just basically push the headlight up a little more and screw it in.
If the leveler can fix this, where is the leveling screw?
I did a quick search and nothing popped up to me that suggest the correct beam pattern...
When it's darker here, I'll do another photo in the dark.
AxlxA is offline
Old 08-06-2007, 09:11 PM   #2
Paranoid Fabrications
Member#: 140712
2008 WRX STI
there is a little 8mm screw on the back of the headlight you need to turn to move the light down.
also see some glare on the top of the beam. thats one of the reasons i don't like hids in these stock housings (i have them too, but am retrofitting to something else)
Shane
Paranoid Fabrications is online now
Old 08-06-2007, 09:47 PM   #3
AxlxA
Member#: 121968
2007 WRX Wagon
Urban Grey Metallic
oh glare is i guess unavoidable =(
As for this 8mm screw thing... I looked, can't figure out which it is. Any photos or more specific explanations?
Picture is worth a thousand words:
Is this the right screw???
Oh ya there's also this halogen colored pattern on the wall... right smack in the middle of each projections. Any idea what's causing that?
AxlxA is offline
Old 08-06-2007, 10:21 PM   #4
LightWerkz
Member#: 125432
2004 E46 M3
http://lightwerkz.net
yes thats the screw to adjust height.
Whats causing that is rebased HID bulbs in a mediocare h7 projector. Just part of the installing HID conversion kits....
LightWerkz is offline
Old 08-06-2007, 10:30 PM   #5
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Yup probably would have gotten better results with OEM-grade D2S bulbs with centering adapters. Still wouldn't be as good as true HID projectors but better than an aftermarket kit, and the best you can do without the full retrofit.
Mulder is offline
Old 08-07-2007, 12:27 AM   #6
AxlxA
Member#: 121968
2007 WRX Wagon
Urban Grey Metallic
Another question for you gurus.....
I am having this patter on the roads... is this normal or do i have to do something to fix this? I had already forgotten how far my halogens reach but I feel like the reach on these HIDs are not sufficient... I want to level them up higher and make them equal?
You see how the driver's side is lower than the passenger side?
AxlxA is offline
Old 08-07-2007, 01:33 AM   #7
LightWerkz
Member#: 125432
2004 E46 M3
yes thats perfectly normal, you can raise both your lights up a tad if you want.
Old 08-07-2007, 01:37 AM   #8
2slofouru
Member#: 90539
95 L with ej257k
powa, Raven R6
You definately need to raise them a bit.
2slofouru is offline
Old 08-07-2007, 12:15 PM   #9
Drowner
Member#: 49297
14 Focus ST3
The driver side should be lower, so you dont blind oncoming traffic.
Drowner is offline
Old 04-23-2009, 03:35 PM   #10
Acrdys
Member#: 152261
2007 WRX 2.5
Crystal Gray Metallic
is this 5k or 6k?
Acrdys is offline
Old 04-23-2009, 03:48 PM   #11
DC16A2
Member#: 174357
2002 OBS
+1. It looks like most cars have the driver side light aimed a tad downwards. My bugeye headlights are completely stock with new halogens (GE Nighthawk 9007) in it and that's pretty much the same beam pattern I get. Also the same pattern I see on my friend's 2005 CRV (halogen) and my other friend's 2007 Acura TL (HIDs).
DC16A2 is offline
Old 04-23-2009, 05:55 PM   #12
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Originally Posted by Acrdys View Post
is this 5k or 6k?
Dunno but it's a two-year-old thread.
Mulder is offline
Closed Thread
05 STi intake manifold on 07 WRX: I know it fits, need help w/WRX harness onto STi IM adjasont Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 02-01-2010 03:25 PM
FS: SE MI Tintkits Pre-Cut Tint Kit for 02-07 WRX/STi BlueSTI4Me MWSOC Private Classifieds 7 09-01-2008 11:52 PM
Need help 07 wrx bog issue blacktrail Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 06-25-2008 02:57 AM
Need Help!! 07 Sti cluster into 07 WRX JEFFZZ Vancouver Impreza Club Forum -- VIC 0 08-21-2007 02:24 PM
Cutting Bumper Support need help w/pics brandonbeeb Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 02-05-2007 01:15 PM
