Old 08-06-2007, 08:24 PM   #1
AxlxA
Member#: 121968
2007 WRX Wagon
Urban Grey Metallic
Default How to: Install HID Conversion kit into 2007 WRX
Okay, I would just like to write a tutorial on how to install these plug n play kits because when i was searching around the forums... i felt like i had to read about 10 different threads to figure out what I needed to do!
Tools: Your car!
10mm wrench
1 long flat screw driver(to push on the tabs for the grill)
1 very thin flat screw driver(to pop those snap on bolts)
2 Pairs of latex gloves
Patience!
1.
Above: I bought a Kaixen HID kit for $300 from autodoodad, he's a vendor here. Super fast shipping!!! Quality stuff!! The instruction manual is blah...
2.
Above: H7 6000k. YES I WANT THE COOLNESS, NOT THE FUNCTION!! Stop flamming me!!!
3.
Kit includes EVERYTHING you need. it even gives you 4 zip tides and 2 double-sided padded adhesive. Wires are all here for the 07wrx!
4.
Above: Original lights.
5.
Above: This is the passenger side after removing the air duct(2 bolts, easy to do no need for photo hopefully) Take off the cap by screwing it counter clock wise a little(if facing the car from hood to trunk) and it will come out easily. Then you need to disconnect the plug shown that supplies power to the bulb. Next is to squeeze the top of the two metal prongs(as shown in the Impreza Manual) and remove bulb. Insert new HID bulb into the slot. Be VERY VERY VERY VERY careful as not to touch any bulb with anything!! I used some latex gloves when I was handling both old and new bulbs. Just make sure it's absolutely uncontaminated with your greasy body oil coming out of your sebasious glands of your dermis.
DRILL HOLE ON THE CAPS!!!! 23mm but 1inch recommended. This hole is to allow the wires for the bulb to ballast to pass through.
6.
Above: Connect up the wires, it's very easy because only 1 fits another. I did this step here just to test out the ballast and see if the lights actually work.
7.
Above: I read on the forum here that subaru did the color wires wrong for positive and negative and what not.... but in MY CASE, in this 2007 wrx wagon, The colors of the wires are indeed correctly made. Red goes to Red, Black goes to Black.
8.
Above: One side works! SUCCESS!
9. Here comes the MOST ANNOYING PART of HID installs... finding a place for the huge bulky ballasts!!!! I basically spent maybe 2 hours trying to fit mine everywhere so that I don't have to take off the headlights. Sadly I ended up shifting my headlights slightly outward and putting the ballast underneath it on both passenger and driver's side. Thank goodness for the doublesided adhesive pad that was included in my kit! Other people have used industrial strength velcro or just zip tied their ballast to something(like the washer fluid container that I saw one guy do.
Since this part is actually quite painful to do, I will just refer you to Silver_04_WRX_SC's awesome thread.
This next section is thanks to Silver_04_WRX_SC's "HOW TO CLEAR 06 Headlight" thread.
I'm also stealing some photos
Undo all the snap on bolts by using a very flat screw driver and just pop these badboys out. Then remove the grills by reaching in between the very small space available from the hood latch and push on the pins to allow the center grill to come out first. then do the side grills.
AxlxA is offline   Reply With Quote
Old 08-06-2007, 08:25 PM   #2
AxlxA
Member#: 121968
2007 WRX Wagon
Urban Grey Metallic
Continued...
Next unbolt these 4 bad boys (10mm nut) so the headlight is no longer attached to this side. There's also 1 10mm bolt and 1 snap on - on top. Sorry my description here is flakey but I hope you would refer to the original post to figure out how to remove it.
10.
Above: Where I put my ballast! It fits fine with the box not completely sitting on the body because it's sorta wedged there with a small portion of the ballast sitting on air. This step I just loosen the headlights and slide it out enough (not completely taken out) so I have enough space for me to squeeze the ballast under the headlight and adhere it on to the body.
Hints: Passenger side - I moved the fluid container(power steering? i forgot now actually) so i have more space for my hand to work.
Driver side - Remove battery completely so you can have access to the projector cap. It's necessary!! I also moved the washer fluid container a little out of the way here.
11.
Above: I made a quick tutorial on how to unplug the DRL in 07 wrx(only works for 07. If you're 06, go in the glove and find the relay for it. This method works for HID conversion kits if it's using the factory wiring for power. It worked for me!
12. Put everything back into its place!
Above: Finished Product
13.
Above: My cut off is a little messed up at the moment, I'm gonna fix it hopefully by screwing the leveler screw.
14.
Above: I have some glare and uneven cut off.... sigh.
15.
16.
17.
Above: looks awesome!!!!
18.
Above: shoot the light onto grass under one of those street lamps.
Old 08-06-2007, 09:24 PM   #3
LightWerkz
Member#: 125432
2004 E46 M3
http://lightwerkz.net
Nice job on the write up, im sure a lot of members will appreciate it.
One thing to note, you seem to be upset with the glare, and yes thats normal for that projector, you didnt install anything wrong. Your current looks perfect as far as alignment...
Also, spending only a few extra bucks I could of gave you the OEM STi setup. Your right you wouldnt get those cool 6000k bulbs, but OEM>Kaixen all day long buddy
The width on those projectors is a joke though, no offense. And you can see hot spots, which is just that fact that your still using halogen projectors, atleast thats what I think.
LightWerkz is offline   Reply With Quote
Old 08-06-2007, 09:35 PM   #4
AxlxA
Member#: 121968
2007 WRX Wagon
Urban Grey Metallic
thanks lightwerkz. I know it would've been much better to get the kit from you. I have no idea now why I haven't done so, only to say now that it's too late =)
Old 08-07-2007, 12:11 AM   #5
autodoodad.com
Member#: 105563
Awesome writeup and pictures! Car looks great. I think it will be useful for a lot of other members when they are installing their lights. Can't believe you went to all that extra effort. Good Job!
autodoodad.com is offline   Reply With Quote
Old 08-07-2007, 01:17 AM   #6
Paranoid Fabrications
Member#: 140712
2008 WRX STI
now just change out those parking lights to these
Paranoid Fabrications is online now   Reply With Quote
Old 08-07-2007, 01:36 AM   #7
AxlxA
Member#: 121968
2007 WRX Wagon
Urban Grey Metallic
lol how? is it even worth it? hahaha it's so insignificant
Old 08-07-2007, 08:03 AM   #8
cucamelsmd15
Member#: 122980
2010 F150, 2013 CX-5
92 Miata 15 TTF/PTF/E3
12345
At least retro and do it right, the difference is amazing.
cucamelsmd15 is offline   Reply With Quote
Old 08-07-2007, 09:39 AM   #9
AxlxA
Member#: 121968
2007 WRX Wagon
Urban Grey Metallic
btw if you guys are judging the width by the last picture... then it's unjust because it's actually a 10mm shot and everything is warped =) It's as wide/wider than my halogen projectors.
Old 08-07-2007, 09:44 AM   #10
cucamelsmd15
Member#: 122980
Compared to a true HID projector, they are a joke though. They have absolutely no width to speak of.
Old 08-07-2007, 12:14 PM   #11
Member#: 140712
2008 WRX STI
yes, it is very insignificant, but oh so worth it its just a simple bulb change to some LEDs.
Shane
Old 08-07-2007, 01:21 PM   #12
paulmofyourhand
Member#: 116355
2004 Impreza STI
bassboat JBP
if ya went with the sti stuff, the 2hrs would have been saved !
paulmofyourhand is offline   Reply With Quote
Old 09-17-2007, 01:20 PM   #13
JoeSUBARU
Member#: 159177
'07 WRX Wagon Ltd.
Hey Awesome write up man, The plus with aftermarket kits is the choice of different kelvin (or HID bulb color) I think the glare isnt so bad and the cut off line look preety much perfect. Im kinda new to the projector lens but i like the them ! Im in the middle of buying a 07 wrx wagon and gotta ask how you like it, also how hard was the DRL disconecting? Any Issues?
JoeSUBARU is offline   Reply With Quote
Old 09-24-2007, 02:45 AM   #14
AxlxA
Member#: 121968
2007 WRX Wagon
Urban Grey Metallic
Hey Joe,
HID unplug as shown. Everything has been working since the day i installed them in. Although I am realizing how I need more intensity to truly enjoy these lights. But then again, I wanted the bluish tint look when you're looking at my car.
When these breaks, I'd go tsx retrofit because then I know it should last longer than a few years.
Or then again, I could have sold my car by then and got something better.
Old 09-26-2007, 11:29 PM   #15
xen0exe
Member#: 157938
very nice write up,.
xen0exe is offline   Reply With Quote
Old 10-19-2007, 05:37 PM   #16
Jinsuk
Member#: 162245
2007 Impreza 2.5i
Obsidian Black Pearl
i know it looks cool but, can you see well with 6k HIDs?
Jinsuk is offline   Reply With Quote
Old 10-19-2007, 05:39 PM   #17
LightWerkz
Member#: 125432
2004 E46 M3
visibility with 6000k isnt bad at all, certainly an improvement over halogen by far, but any higher...its pretty poor.
Old 10-19-2007, 06:00 PM   #18
xfactor58
Member#: 148951
2006 Perry Tuned WRX
CGM
i have 6k in my car i think and visibility is good, however i can tell you from driving my wrx at night and an sti at night....there is a huge difference in quality ...still worth upgrading to the plug and play, they look cool lol
xfactor58 is offline   Reply With Quote
Old 10-19-2007, 06:33 PM   #19
EJ20i
Member#: 151060
2007 Impreza
Obsidian Black
Thank you for the write up...have been looking for it!!
EJ20i is offline   Reply With Quote
Old 10-20-2007, 10:56 PM   #20
AxlxA
Member#: 121968
2007 WRX Wagon
Urban Grey Metallic
You're very welcome. Wrote it because when i installed mine, i had not much directions on how to do it although it turned out to be extremely easy.
My input on the effective lighting genre:
It lights things up sure.. especially things that are reflective. But I don't know if i am just used to my car or haven't sat in another HID car in a while... but I feel like night time when it rains, I could barely see much. But then again I don't remember how it looked when I had my halogens in. Definitely in pitch black areas(much of wisconsin here) it lights things up perfectly!
Old 10-22-2007, 11:56 PM   #21
PoochMastaFlex
Member#: 162479
Nice tutorial! Thanks for the detailed instructions.
PoochMastaFlex is offline   Reply With Quote
Old 10-26-2007, 03:27 AM   #22
AxlxA
Member#: 121968
2007 WRX Wagon
Urban Grey Metallic
As someone suggested, I added the parking light mod:
Old 10-26-2007, 02:27 PM   #23
unreal2979
Member#: 151621
2007 WRX
Urban Gray
hey man, who did you buy the parking light mod from and how much was it....btw i love your car it looks sick man..i wanna do an HID conversion too i just cant decide on color
unreal2979 is offline   Reply With Quote
Old 10-26-2007, 04:07 PM   #24
AxlxA
Member#: 121968
2007 WRX Wagon
Urban Grey Metallic
Those are LEDs from superbright LEDS
I dont see the exam same ones on that site any more but you can get these which are cheaper and better:
http://www.superbrightleds.com/mini-wedge.html
WLED-x6 LED Wedge Base Bulbs
Old 12-01-2007, 11:13 PM   #25
phoenix_wrx
Member#: 98532
na B-Wing
rebel red
Any issues with heat with these? I just saw the warning on their page about putting these in headlamp housings.
phoenix_wrx is offline   Reply With Quote
iBrite HID Conversion Kits - 10% OFF ANY HID KIT - Sonic Motor April Sale Sonic Motor Exterior/Styling 12 04-30-2010 08:58 PM
WTB bi xenon projectors and hid conversion kit for 02 wrx doopah Private 'Wanted' Classifieds 2 10-04-2009 02:33 AM
Installation on HID Conversion KIT sti-bullet Vancouver Impreza Club Forum -- VIC 16 10-01-2007 10:59 AM
HID conversion kit. 02-03 WRX danniel Private 'Wanted' Classifieds 1 11-08-2006 10:34 PM
Phillips HID conversion kit on '06 WRX alpinev12 Electrical & Lighting 44 02-01-2006 02:40 AM
