#1 |
Member#: 68120
Vehicle:1998 RS 2.0 vf23 STi & MK6 GTI |
Well, just lost a piston in my RSTi hybrid.
Been doin a lot of research but Im still up in the air. They say the 2618 alloy (i.e. JE, Wiseco) pistons are better for boosted and higher hp applications, but they are more prone to scorring piston walls and piston slap. On the other hand the 4032 alloy (i.e. Mahle) pistons have a lower thermal expansion rate, thus resulting in tighter tolerances lowering the chances of cylinder scorring and piston slap. But are not quite as strong. So basically I just want to hear from other people about what they have done. P.S.- I want to order these things asap so I can get this beast done this weekend. Any help would be greatly appreciated. Thanks!
#2 |
Member#: 78165
South East
Vehicle:05 STI 35r + e85 |
2618 cp pistons... .0030 p/w clearence... they are not as loud as I expected.
I have seen a couple cracked mahle pistons on here, but have never seen somebody who had problems with a 2618 alloy piston tearing up their cylinder bores. |
#3 |
Member#: 148043
If they score the piston walls, they were spec'ed too tight to begin with.
Yes, they expand a lot. On the other hand, I've bent them into banana shapes while trying to remove scrap pistons from scrap rods "the easy way". They don't shatter. |
#4 |
Member#: 60142
Vehicle:2011 WRX Grey |
It's not so much that the 2618 alloy slugs are "stronger" as they are "less brittle." Properly toleranced, the 2618 alloy pistons are almost bombproof. In high power and boost motors, they are definitely the way to go. OTOH, if you're not going for big power or a really aggressive tune, the 4032 slugs, such as Mahle, are arguably the better choice since they will probably last longer - the harder the piston, the slower the wear rate.
Either way, the expansion rate for both is very high. Proper warm-up is critical with any forged piston. |
#5 |
Member#: 68120
Good things to know. Since Im keeping it a daily driver with moderate power levels I went with the Mahle's.
Thanks for the input! |
#6 |
Member#: 60142
Sounds like you made the right choice. Just stay out of knock, and make sure to warm it up thoroughly before you put the hammer down. Enjoy.
#7 |
Member#: 56468
NWIC
Vehicle:04 Improved STI Dirty White |
I've used both and here is the bottom line for me. You have more choice and the ability to make custom pistons in 2618.
My custom CPs don't slap at all. They are a little more dough, but I have higher compression (more responsive, more power, less lag, careful tuning), and they are quiet. |
#8 |
Member#: 89752
SCIC
Vehicle:08 STI SWP |
I'm running Supertech pistons which are 4032. They are shockingly quiet. The fully built motor in my LGT is actually more quiet than the completely stock N/A 2.5 in my 07 Outback company car. Don't know about strength quite yet since I've only got about 200 miles on it and I'm still breaking it in but I plan on getting around 500-520whp out of it, so we'll see. My personal feeling is that if the tune is good, the "weaker" 4032 pistons are fine and will wear better and run smoother/quieter.
#9 | |
Member#: 68120
HOLY SMOKES! Thats gonna be one mean Legacy. I looked at Supertech pistons but I had never heard anything about them. They were very reasonably priced too. Well my pistons should be here today. Then surgery begins this weekend. Wish me luck!! ![]() |
#10 |
Member#: 39149
Vehicle:11 elantra yea i said elantra |
2618 Je's
#11 | |
Member#: 89752
SCIC
#12 | |
Member#: 67608
Also, Mahle's 124 alloy has a Brinell Hardness of only 100, whilst 2618 has one of 115 ... and the elongation before break of the 2618 is 5 times more than the 124 Alloy. Bear in mind, Mahle 124 is NOT 4032. Standard 4032 T6 has a Brinell Hardness of 120, Elongation At Break of 9%, thermal expansion at room temp of 19.4 um/M-*C, Young's Modulus of 78.6 GPa, and Yield Strength of 317 MPa. However, some proprietary (non-melt-spun) grades make those figures to 120, 4%, 19.4 um/M-*C, 79 GPa, and, more importantly, 331 MPa. 2618 T6 has the same measurements figured at 115, 10%, 22.3 um/M-*C, 74.5 GPa, and 372 MPa .... making 2618 only marginally stronger/tougher, significantly higher expanding, a little less rigid, and slightly softer and quicker to wear. Coatings tend to fix the latter. To each his/her own ... 4026 T651 is actually stronger than 2618 T6, though it's argued that almost all aluminum pistons, due to combustion temperatures, revert to about a T5 temper after any significant use. -Adrian |
#13 |
Member#: 64673
NWIC
Vehicle:1990 Legacy wagon goes 12.387 @ 116.5 |
Having held both Wisecos and Mahles in my hand side by side, I would "say" the Wiscos would be tougher simply because they look, feel and appear "tougher". The Mahles look like 100% OEM STI pistons, wheas the Wisecos were obviously aftermarket. But....... Thats just the look and feel they have...... No proof coming from me yet.
#14 |
Member#: 64673
NWIC
OK, I have now installed stock, wisecos, and Mahle pistons......
The Mahles rings SUCK for ease of installation. ESPECIALLY the 3layer oil rings. They can be installed, but Jesus on a Cracker, what a bitch. You know how OEM rings have the little metal wire that keeps the center piece together once you install it? Mahle decide it wasnt neccesarry... Well it IS!!!!! PITA!!!! But anyway, they are installed now..... Lets hope nothing jumped out. |
#15 | |
Member#: 60142
And you're right, they are a complete bitch to install. |
#16 |
Member#: 64673
NWIC
And I spoke too soon.
I retracted the damn ring compressor too far, and it whacked out, so I need to buy another ring compressor..... FLYCASTER.... you make me paranoid.... great.... |
#17 |
Member#: 68120
Hmmm. Well the morons at the place I bought my pistons from dont know how to read.
I paid to have them shipped overnight, and they shipped them ground. I paid for them weds morning and they still arent here. So now the project is pushed back till next weekend. |
#18 |
Member#: 60142
#19 | |
Member#: 68120
Question, on the oil rings, the upper and lower rings of the oil set are diff. One set is flat all the way around, the other set on one end has part bent slightly up. Which goes on top and on bottom? Also, what about the placement of the rings on the pistons? I heard just place the gaps 180 degrees from each other. Any opinions? |
#20 |
Member#: 64673
NWIC
Oil rings......
The one with the tab goes on the bottom, and the tab fits into the SINGLE hole that is drill out but DOES NOT GO THROUGH. But you have to place the separator first, because it has a back piece that the upper and lower ring go OVER. Here is the damn trick I learned though with the middle piece. As far as I could tell, it was TOO BIG. Everytime I tried to get it to compress, it would pop out and try to overlap itself. So I cut off one section of it. How much is a section you ask? Press the ends together. Its like they butt up, out of sequence, right? I remove enough material via a grinder so that they once again butt up out of sequence. Should you do this? I really cannot see it making a difference. MY OPINION! And at least they fit now. What happens if you try to fit the piston, and the lower oil rings pop out is they get bent. Then you get bent and start swearing..... The middle ring has a notch in it. It goes down (with the piston facing you.) The top ring, as far as I could tell, had no markings, so I just installed them. The rings are SO FREAKING LOOSE, that I installed them, then did the 180% thing, and hoped for the best as I bet they move around a tad before they settle in. |
#21 | |
Member#: 68120
Thanks for the info reddevil. Good stuff to know.
I also came to the conclusion that the middle section of the oil rings is to big. Any other opinions on this approach? Quote:
#22 | |
Member#: 60142
#23 | ||
Member#: 9794
TXIC
Vehicle:02 2.5LWRX-Retired 335i w/twins |
And yes I tried cutting out a section, but then the folks@godspeed talked me out of it and I bought a new set of rings (I have a ring set for 3 pistons taking up space if anyone wants them). When I pushed the pistons in the cylinder with the cut ring and the uncut ring, the compression/suction/resistance difference was big. IMO, if you cut the ring, you will have oil burning issues. Mine had none even from day 1. hth, -C |
#24 |
Member#: 42215
Vehicle:2002 WRX being built and going for 10s :evil: |
FYI, Mahle now makes 2618 pistons.
| Thread Tools | |
| Display Modes | |
| Which DCCD controller are you running for you 6 speed trans for your WRX? | jonpark | Transmission (AT/MT) & Driveline | 2 | 11-04-2008 04:53 PM |
| Which synthetic blend are you running? | eurospek | Service & Maintenance | 24 | 12-30-2006 02:05 PM |
| Which kit are you running and your thoughts? | jetfan8178 | Water/Methanol Injection, Nitrous & Intercooler Cooling | 6 | 09-03-2006 01:27 PM |
| RS-T owners, which turbo are you running? | projectrally | Normally Aspirated with bolt-on Forced Induction Powertrain | 30 | 05-30-2005 07:35 PM |
| 4EAT people... which DP are you running? | Sisqocqk | Factory 2.0L Turbo Powertrain | 12 | 12-24-2003 01:59 AM |
