Old 08-06-2007, 09:20 PM   #1
blowbyu24
Member#: 84482
2005 STI.UR gt4088r
E85 pro comp sti
Default another burning oil question/disappearing oil..haha
getting it fixed!!!
blowbyu24 is offline   Reply With Quote
Old 08-06-2007, 10:14 PM   #2
jays05
Member#: 78165
05 STI 35r + e85
Are you using a catch can or an air/oil separator?
I am also at 1700 miles on a built motor... oil changed at 0 (after initial cam break-in and some idle tuning), 300, 600, 900, 1200, 1500... no oil loss at all... but I am using an air/oil separator.
jays05 is offline   Reply With Quote
Old 08-06-2007, 11:21 PM   #3
flycaster
Member#: 60142
2011 WRX
Grey
I don't know if this is your problem or not, but you have to check the oil under exactly the same conditons, otherwise all bets are off. IMO, you get the most accurate reads when it's stone cold, first thing before you fire up for the day. With 1.7K already on the motor, it should be sealing up pretty good by now - my block settled right down to a qt/2000 for street use right about your mileage. I do use more in the winter though (all cold start burn).
flycaster is offline   Reply With Quote
Old 08-07-2007, 06:31 PM   #4
blowbyu24
Member#: 84482
2005 STI.UR gt4088r
E85 pro comp sti
yeah im using a catch can, but no blow by yet so thats not the problem there, thanks for the idea though!
yeah i checked it in the morning when it was cold, im switching to mobil 1 20w 50 a much thicker oil which will be able to handle the temps and keep oil pressure higher....i still am stumped though, im blaiming the oil consumption on the turbo as of now, b/c i don't see why it dropped, its buging me out
burning oil question scoobman Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 10-18-2008 10:05 PM
white smoke and burning oil question .. joe_black Normally Aspirated Powertrain 7 12-15-2006 09:20 AM
The mistery disappearing oil... powerlabs Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 10-04-2005 05:25 PM
Loss of power and the oil is disappearing without a trace.... RS25Tuner Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 39 05-12-2005 07:20 AM
Disappearing Oil? jackassery Newbies & FAQs 18 05-06-2004 10:43 PM
