Old 08-06-2007, 11:20 PM   #1
Magnum626
Member#: 62856
MBP SQC#197
Stockpiling parts...
Default Where does this hose go?
So we had my friends intercooler off and found a hose. It was unplugged and couldn't figure out where it goes if it even is plugged into anything. It looks to be plugged in with the tgv unit thing. Obviously, I'm not that much of a wrencher.
It's not for the bpv or the rails that go in front of the ic.
Anyone know?
It's a crappy cell phone pic I know.
Magnum626 is offline   Reply With Quote
Old 08-07-2007, 12:12 AM   #2
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
that might be the hose that goes to the tgv unit. i would reccomend puttin stuff back on and see where it lines up.
Josh
www.grimmspeed.com
GrimmSpeed is offline   Reply With Quote
Old 08-07-2007, 05:24 AM   #3
karlknaupp
Member#: 60871
2004 WRB WRX
looks like the bpv hose
karlknaupp is offline   Reply With Quote
Old 08-07-2007, 08:31 AM   #4
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
That looks like the BPV hose. There is a hose that connects to the TGV's on that side of the motor that is found on pre 04 models that is commonly referred to as "the line to no where." On the 04+ models there is a cap on the TGV motor and no line.
Tony
Old 08-07-2007, 08:33 AM   #5
akira02rex
Member#: 82612
2015 WRX STI
Ice Silver Metallic
That indeed does look like the bpv hose.
You must have sourced a bpv hose somewhere else..or someone else did.
Better get that fixed/capped asap as you have a boost leak now.
akira02rex is offline   Reply With Quote
Old 08-07-2007, 09:48 AM   #6
Magnum626
Member#: 62856
MBP SQC#197
It's not the bpv hose for sure. I tucked the bpv hose in front of that so I could get a picture. That's what we were thinking but the other end goes to the TGV.
I think Tony got it right. I went through the impreza manuals searching under tgv and it made no mention of the hose that goes to nowhere. lol
I thought I heard about that line that goes nowhere. But why does it go no where? And if it definitely does go nowhere why is it shaped like that?
Old 08-07-2007, 11:47 AM   #7
Racer_X_X
Member#: 141804
'98 RSTi HTA86 AEM
'02 35R-Nürburgring Cert.
I do believe that goes to the TGV. I had the same issue a few weeks ago.
Here is the thread....
http://forums.nasioc.com/forums/show....php?t=1310888
Racer_X_X is offline   Reply With Quote
Old 08-07-2007, 07:37 PM   #8
Magnum626
Member#: 62856
MBP SQC#197
^Yup that's the one. Next time I take off my tmic I'll see if I have one. I never noticed it before on my car.
I guess I could tell my friend not to worry then.
Does anyone know where this info is in the impreza manuals? I can't seem to find them. It shows pics of the tgv and how to remove/install; but never anything about the damn hose.
Thanks everyone.
Old 08-07-2007, 09:01 PM   #9
Steve455
Member#: 128727
2005 WRX Sti
black
I found the same hose on my 02 that was not plugged into anything and going to the TGV.
Steve455 is offline   Reply With Quote
Old 08-08-2007, 12:50 AM   #10
capitalj4
Member#: 136309
2003 wrx
blue
so should we plug the hose? or just let it be?
capitalj4 is offline   Reply With Quote
Old 08-08-2007, 10:22 AM   #11
Racer_X_X
Member#: 141804
'98 RSTi HTA86 AEM
Supposedly its a vent for condensation that can build up inside.
I just left mine the way it was, unplugged.
Everything seems to work just like normal.
Where does this hose go? (engine bay) Tur1smoWRX Mid Atlantic Impreza Club -- MAIC 4 07-03-2006 03:54 PM
Where Does This Hose Go? Steel_Rain Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 02-01-2006 09:35 PM
Where does this hose go to? Inprogress Texas Impreza Club Forum -- TXIC 17 12-01-2005 11:22 AM
Where does this hose go? (IM) TypeC Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 11-19-2004 12:32 PM
where does this hose go ? suprasingle Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 10-24-2002 01:19 PM
