Old 01-05-2002, 10:53 PM   #1
SilverSubi
Member#: 9856
2011 STI
PBP
Default Whiteline front strut tower bar
Just installed a Whiteline front strut tower brace. Most posts I've read indicate that there is no real noticable difference, but I did notice an added stiffness while cornering. Nothing huge, but not insignificant.
Anyway, I learned that the best method for installing this piece is to first unscrew the nut holding the AC line to the bracket on the driver's side firewall. Then start feeding the bar behind the AC line from the passenger side with the driver side strut ring on the bar removed. Once it's fed into place, bolt down both strut rings to the towers. Then see if you need to adjust the bar in order to reattach the end to the ring. I only needed 1/2 to 1 full turn. Once the holes are aligned, slide the bolt back through the ring bracket and bar and tighten. Then tighten the adjustment bolts on the bar; no heavy torquing required. The trickiest part was bolting the AC line back onto the bracket on the firewall. A little bending was required to make it fit again. The AC line will definitely remain touching the bar. I placed a piece of foam between the AC line and bar to prevent scratching of the bar and wearing of the AC line.
If nothing else, it looks pretty.
SilverSubi is offline   Reply With Quote
Old 02-10-2002, 04:23 AM   #2
WsleepeRX
Member#: 15036
2004 STI
WR blue
Thanks a lot for posting this. I thought i was the biggest retard in the world having trouble putting a strut bar on
WsleepeRX is offline   Reply With Quote
Old 02-10-2002, 12:57 PM   #3
NotoriousWRX
Member#: 9026
The easiest way to deal with the AC line is to move the bracket down and just attach the upper hole on the bracket to the lower hole on the firewall.
NotoriousWRX is offline   Reply With Quote
Old 02-11-2002, 01:48 AM   #4
rkkwan
Member#: 5596
2010 Honda Fit Sport
He he... I did the same as Notorious... Real simple.
-Ray
rkkwan is offline   Reply With Quote
STL:IN: Whiteline Front Strut Tower Bar T3/T4 WRX Mid West Subaru Owners Club Forum -- MWSOC 0 09-28-2003 12:46 AM
STL: IN: Gauging interest Whiteline Front Strut tower bar T3/T4 WRX Private 'For Sale' Classifieds 0 09-03-2003 05:32 PM
FS local Whiteline front strut tower bar Davenow New England Impreza Club Forum -- NESIC 6 06-02-2003 07:06 AM
Installing Whiteline Front Strut Tower Bar in a 2002 2.5rs skyhon Brakes, Steering & Suspension 2 03-26-2003 10:59 AM
Best place to buy the Whiteline front strut tower bar? HIHO Legacy Forum 8 02-06-2002 01:38 AM
