Welcome to the North American Subaru Impreza Owners Club Tuesday August 23, 2016
Old 08-07-2007, 02:10 AM   #1
PDXTuning
Member#: 49831
2008 Get Tuned Now
Knowledge is Power
Default PDXTuning 2008WRX Baseline and Tuned Results
I started a new thread so I have room to post a bit more data. As mentioned in the other thread we have acquired a new 2008 WRB WRX. A quick look in the engine bay makes you think you are looking at a Legacy.
After strapping it to the dyno, we installed a wideband and looked for something to tune it with. Fortunately the fine folks at TurboXS overnighted a beta UTEC Delta to test out on the new 08. It worked perfectly and we were on our way to seeing what the car can do. This car is completly stock in everyway sans UTEC. Stock exhaust, stock cats, etc.
Tim Bailey took over the tuning and tweaked our starter map to 15psi and got a good smooth 267 lb-ft of torque and 218whp. (up from 239 lb-ft and 205whp stock).
Just to see what the upper end of torque could look like, we ramped the boost up to 17psi and added a can of Torco to about 5 gallons of pump 92. It netted a stump pulling 300 lb-ft of torque!
Here is a look at the three tunes:
Stock ECU
If we look at the stock ECU map, you can see the low boost and VERY rich AFRs the stock car runs.
Here is a look at the stock ECU timing. Multiple runs had the timing dips in the midrange, although knock was not audible.[/color]
As you can see, that small Mitsu turbo can spool up pretty quick.
Tim is going to add some comments about the tune, and I'll dig up some more datalogs to post. I was surpised at the peak hp with the stock car, so much that I was wondering if Subaru sent us a ringer. I would love to see results from some other 08s. Perrin has a couple of new 08s, so we may be able to get one of those over here to test out.
Cheers,
Jeff Sponaugle
PDXTuning is offline   Reply With Quote
Old 08-07-2007, 02:11 AM   #2
PDXTuning
Member#: 49831
2008 Get Tuned Now
Knowledge is Power
Jeff Sponaugle
Old 08-07-2007, 02:18 AM   #3
scrwrx
Member#: 101523
I can't wait to see a tuned Stage 2 set up if you guys are pushing that much out on a stock WRX
scrwrx is offline   Reply With Quote
Old 08-07-2007, 02:23 AM   #4
Bishop
Member#: 59993
Ass, grass or cash
no one rides for free!!
wow lookin good.
Bishop is offline   Reply With Quote
Old 08-07-2007, 02:31 AM   #5
Blackpantherwrx
Member#: 70855
Air Spencer... Squash.
Sweet Keep up the good work guys.
Blackpantherwrx is offline   Reply With Quote
Old 08-07-2007, 02:32 AM   #6
sponaugle
Member#: 4498
WRX H6-3.0 Turbo
www.surgelinetuning.com
Yes, a stage 2 setup looks to be very nice. The downpipe looks like it might be compatible with the legacy downpipes, but the muffer part is different. I know Jeff (Perrin) is working on a stage 2 setup so hopefully we can get that tested soon.
Cheers,
Jeff Sponaugle
sponaugle is offline   Reply With Quote
Old 08-07-2007, 02:42 AM   #7
remowgn
Member#: 41149
09 FXT
SSM
Awesome stuff. As always you guys are on the bleeding edge. Can't wait to see more.
remowgn is offline   Reply With Quote
Old 08-07-2007, 03:29 AM   #8
spooln407
Member#: 97054
MY05 WRX
i guess the performance will back up the uglyness of the car lol
spooln407 is offline   Reply With Quote
Old 08-07-2007, 04:54 AM   #9
dodiox
Visiting NASIOC Timeout
Member#: 85718
06 WRX
Cobb Stage 2
that is one torquey mother effer!
even more than the 06!
stage 2 will be amazing!
dodiox is offline   Reply With Quote
Old 08-07-2007, 06:18 AM   #10
matt30
Member#: 97330
2003 WRX
Whats the verdict on that turbo?
matt30 is offline   Reply With Quote
Old 08-07-2007, 06:32 AM   #11
ScoobyNubieToo!
Member#: 75234
2004 WRX Wagon with
07 STI 6-Speed Goodness!
^Yeah, what he said^
ScoobyNubieToo! is offline   Reply With Quote
Old 08-07-2007, 06:41 AM   #12
cucamelsmd15
Member#: 122980
2010 F150, 2013 CX-5
92 Miata 15 TTF/PTF/E3
So, basically, the stock map still runs a long OL/CL delay, which means its lean during the entire time of peak boost. And apparently, the timing tables still suck.
What do the AFR's look like on the stock map? Can you post the stock boost map?
cucamelsmd15 is offline   Reply With Quote
Old 08-07-2007, 06:56 AM   #13
Speed
Member#: 67371
05 BUILT 2.4L STI
That is the stock A/F ratios with stock boost map.
Lean at full boost FTL. I guess every single car is going to be like this from now on 07+ (new rules?).
Hopefully down the line when people keep breaking ring lands they actually put some decent pistons on future models.
Speed is offline   Reply With Quote
Old 08-07-2007, 07:00 AM   #14
cucamelsmd15
Member#: 122980
Bah, I meant tuned map, not stock map. Its early here Oh, and I meant the actual target boost map thats in the ECU. Not sure if you can pull that with a UTEC or not.
Old 08-07-2007, 07:43 AM   #15
rjrutzky
Member#: 30367
2005 Legacy GT
NASA SE PTB Champ
Looks about the same as an 06-07 wrx, no?
rjrutzky is offline   Reply With Quote
Old 08-07-2007, 08:18 AM   #16
boostdog
Member#: 149752
2017 wrx
ICE ICE BABY SILVER!
Looks good Jeff! Atleast it may provide some insite on what the sti is going to be able to produce. Hopefully the aftermarket can help with the looks too.
boostdog is offline   Reply With Quote
Old 08-07-2007, 08:43 AM   #17
UltimateLurker
Member#: 82488
06 Lotus Exige
Excellent work.
However, I really wish you guys would have got yourselves an '07 car to run through the same paces at the same time so we could see the difference between the two.
UltimateLurker is offline   Reply With Quote
Old 08-07-2007, 09:08 AM   #18
UM-WRXer
Member#: 44623
Thanks for sharing this information to the general subaru community
You guys at PDX are always keeping it tight.
UM-WRXer is offline   Reply With Quote
Old 08-07-2007, 09:49 AM   #19
dodiox
Member#: 85718
06 WRX
Cobb Stage 2
is it possible for you guys to compair the stock 08 results to the stock 06+?
Old 08-07-2007, 09:56 AM   #20
boostdog
Member#: 149752
2017 wrx
why not just compare this to what dave Burschur dynoed? ( i know they are diff dyno's, but it will give you something to go by.)
http://forums.nasioc.com/forums/show....php?t=1184801
looks like 228tq/191tq to me so i would say the 08 is a little more powerful, but comparing on the same dyno would be nice.
Old 08-07-2007, 10:08 AM   #21
dodiox
Member#: 85718
06 WRX
Cobb Stage 2
there is no point to comparing 2 different dynos. to many variables.
Old 08-07-2007, 10:11 AM   #22
wizzman
Member#: 84405
2007 V8 4Runner
1994 flaming red Miata
It still look like a Corolla
wizzman is offline   Reply With Quote
Old 08-07-2007, 10:15 AM   #23
z
Member#: 41762
04 STi
CT-DE-FL rinse+repeat
Nice bump in torque with just a tune!
z is offline   Reply With Quote
Old 08-07-2007, 10:51 AM   #24
karl750
Member#: 100977
2004 VF30 WRX
[email protected] 1.84 60'
I'm impressed! After these numbers, why would anyone spend more for the sti?
karl750 is offline   Reply With Quote
Old 08-07-2007, 11:04 AM   #25
Chiketkd
Member#: 71634
In hibernation...
So does the 2008 WRX have the same TD04 as previous '02-'07 WRXs?
Chiketkd is offline   Reply With Quote
FS : 2004 STI with new motor and tuned for E85 $20,000 NAZSTI SWIC Private Classifieds 3 06-15-2010 06:54 PM
Baseline and a future tune. cireturbo Proven Power Bragging 3 03-06-2008 03:52 AM
Ennis test and tune results JCooper702 Texas Impreza Club Forum -- TXIC 46 02-27-2008 12:16 AM
PERRIN PWI-1 Test and Tune Results........ PERRINJeff Proven Power Bragging 6 11-15-2007 02:32 PM
AMS 2005 STi Baseline and tuning numbers AMS Proven Power Bragging 39 04-18-2007 05:07 PM
