Alaskan Impreza Club
Old 08-07-2007, 03:49 AM   #1
SaxMan9801
Member#: 128034
2004 SVT Cobra
11' BMW X3 12' Tundra
Default Cobb short throw install help needed
I ran into a snag today trying to get the Cobb shifter installed onto my STI....I cannot get the reverse lockout cable to seat it's self inside the shifter housing high enough.....is there something I could be doing wrong that I should look at before I call Cobb, or has anyone ran into a issue with the inside not being drilled out enough?
Thanks
Dan
SaxMan9801 is offline   Reply With Quote
Old 08-07-2007, 05:56 PM   #2
asianhulk
Member#: 77529
05 Beat up Jeep
Alaska Black
with my kartboy install, if you go underneath have a friend pull on the reverse lockout cable from up top, you can see where you need to apply something to relieve the tension, i used a screwdriver head, but that will give you the necessary few inches to allow you to put that pin back in..hope this helps
John
asianhulk is offline   Reply With Quote
Old 08-07-2007, 06:24 PM   #3
Arctic Assassian
Member#: 91875
91 legacy TD04
04 WRB/carbon fibre STI
just like early brake cables...
Arctic Assassian is offline   Reply With Quote
Old 08-09-2007, 03:38 AM   #4
SaxMan9801
Member#: 128034
2004 SVT Cobra
The issue i ran into is that the brass piece on the top of the lockout cable would not sit up into the shaft far enough...Cobb is sending me a new upper shaft hopefully this corrects the problem....Thanks for the ideas though
Dan
Old 08-10-2007, 04:51 AM   #5
ScoobyTec
Member#: 138546
04 HD2500
Green....Loud
i ran in to that problem on 2 cobb shifters and had to drill both of them out
ScoobyTec is offline   Reply With Quote
Old 08-10-2007, 04:53 AM   #6
SaxMan9801
Member#: 128034
2004 SVT Cobra
That sucks...cant really say I feel like drilling that out....Can you remember what size you had to drill it out to? Anyone know a machine shop I can take it to or someone with a press so I can get it drilled straight?
Thanks for helpin the FNG....
Dan
Old 08-10-2007, 01:28 PM   #7
SQUAD_907
Totally Biased
Member#: 10104
WOW! JUST WOW!
I make posts disappear
Dan
ak dragbike!
SQUAD_907 is offline   Reply With Quote
Old 08-10-2007, 03:32 PM   #8
SaxMan9801
Member#: 128034
2004 SVT Cobra
Is that a shop in town I take it....
Old 08-10-2007, 04:20 PM   #9
SQUAD_907
Totally Biased
Member#: 10104
WOW! JUST WOW!
278-8655
Old 08-10-2007, 09:06 PM   #10
ScoobyTec
Member#: 138546
04 HD2500
Green....Loud
i held it in my left hand and drilled it with my cordless in my right. got it straight to. i think i used a 11/32 bit ....i think.
Old 08-10-2007, 09:09 PM   #11
SQUAD_907
Totally Biased
Member#: 10104
WOW! JUST WOW!
dale is teh man!
Old 08-11-2007, 02:40 AM   #12
SaxMan9801
Member#: 128034
2004 SVT Cobra
Which hand holds the refereshing beverage then? I take it it does not have to be a super tight fit then since the stock one has some play in it? I should have just drilled the damm thing out from the begining...
2008 Cobb Short throw install tphskab Transmission (AT/MT) & Driveline 5 09-27-2008 04:01 PM
Cobb Short Throw Install help SaxMan9801 Transmission (AT/MT) & Driveline 1 08-07-2007 10:33 PM
short throw install help for 05 scoobydrew06 Transmission (AT/MT) & Driveline 3 09-13-2005 12:17 AM
I Need Help On My Short Throw Install jacket03WRX Newbies & FAQs 5 10-14-2004 08:17 PM
COBB Short Throw Shifter installed... TFW Transmission (AT/MT) & Driveline 12 12-04-2001 11:18 PM
