Welcome to the North American Subaru Impreza Owners Club Friday September 4, 2015
Old 08-07-2007, 11:47 AM   #1
fishheadback
Member#: 68120
1998 RS 2.0 vf23 STi
& MK6 GTI
Default Head torque specs
Ok, first off, Its a 05STi block, with STi MLS headgaskets, and 98rs heads.
I heard that you should go by the torque specs according to what gasket you use. With that being said, I still cant find crap on this.
Anyone know where I can find these specs or know what they are?
fishheadback is offline   Reply With Quote
Old 08-07-2007, 01:49 PM   #2
Acostafan
Member#: 67398
2002 Now with 100%
RDA of 2.5l Goodness!!!
IF I can find my factory service manual, I'll pm you. There is a very specific set of specs to do it right.
Acostafan is offline   Reply With Quote
Old 08-07-2007, 07:39 PM   #3
fishheadback
Member#: 68120
& MK6 GTI
Thanks!
Old 08-10-2007, 05:08 PM   #4
curly2k3
Member#: 87614
9698 GC8 & GF4
Black and White
mind sharing? I have a 2005 EJ205 WRX motor with EJ22e SOHC heads and i need specs too
curly2k3 is offline   Reply With Quote
Old 08-10-2007, 09:25 PM   #5
Acostafan
Member#: 67398
2002 Now with 100%
Trying to find my hard copy, I can't find my disc with the FSM on it.
Old 08-10-2007, 11:50 PM   #6
Kosmic
Member#: 99140
GD Racing chassis
Slowly in construction
That is what I have in the WRX STI 2004 service manual. Hope it can help.
Kosmic is offline   Reply With Quote
Old 08-11-2007, 11:15 AM   #7
Acostafan
Member#: 67398
2002 Now with 100%
While that may work, it's not the instructions for the WRX heads. They are different. I'd post them but I can't find my FSM disc or my hard copy. But I am certain they are not the same
Old 08-13-2007, 03:40 PM   #8
MRF582
Member#: 48219
. Always drive
the race line .
I have used that exact procedure on an ej205 and an ej257 block. Same headbolts even. As in the headbolts currently holding the heads on have been torqued 3 times. Once when the engine was assembled from the factory, once with an ej205, and once with an ej257.
MRF582 is offline   Reply With Quote
Old 08-13-2007, 03:56 PM   #9
fishheadback
Member#: 68120
& MK6 GTI
Well I happened to find the specs on it, and wow is it different.
But if thats how they want you to do it, thats how Ill do it.
Old 08-16-2007, 08:33 PM   #10
BoostorLose
Member#: 57502
05/4 STi/FXT
Aspen White x2
If and when you end up studding the motor, I went with ARP studs and torqued to 90ft-lbs. So far several thousand miles at 26psi and no problems at all.
-Mike
BoostorLose is offline   Reply With Quote
Old 08-16-2007, 10:11 PM   #11
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
seems they changed the sequence on tightening down the head. interesting.
**Right Click Save As**
Thanks!
Fuji
FuJi K is offline   Reply With Quote
Old 08-17-2007, 01:21 PM   #12
fishheadback
Member#: 68120
& MK6 GTI
You torqued all the bolts to 90ft-lbs?
The specs through subaru show the inner and outer being diff and they arent really "torqued". The final specs are degree's.
Is that what ARP said to do?
-Mike
Old 08-17-2007, 07:51 PM   #13
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
arp bolts arent meant to stretch like the factory bolts, so you torque them down to an actual torque figure. instead of that mess of a torquing procedure the factory uses. you do, however, use the factory tightening sequence, IIRC.
~Josh~
Old 08-17-2007, 09:07 PM   #14
Acostafan
Member#: 67398
2002 Now with 100%
~Josh~
The factory bolts ARE NOT stretch bolts....many(except for me) have reused their factory bolts with zero issues.
Old 08-18-2007, 09:36 AM   #15
BoostorLose
Member#: 57502
05/4 STi/FXT
Aspen White x2
Yeah man, ARP has two separate specs for different installed greases and loc-tite. Both involve torquing the heads to one spec. I haven't had one issue and this car sees 25psi daily.
I also was fairly sure the stock bolts are a torque-to-yeild bolt, meaning they stretch. I'm not saying you can't reuse them, because I have in the hundreds of headgasket jobs I've done, all without return problems.
For me, it's added security for cheap when you already have the motor apart.
-Mike
Old 08-18-2007, 09:40 AM   #16
BoostorLose
Member#: 57502
05/4 STi/FXT
Aspen White x2
As far as the torque specs above go, I believe the WRX is: of course all done in the same sequence.
All bolts 22ft-lbs
All bolts 51ft-lbs
Back of 180
Back of 180 again
All bolts to 11ft-lbs
Center two bolts to 25ft-lbs
Then all bolts between 80-90 degrees.
I may be a little off, but that's what the old brain is remembering. Good luck.
-Mike
Come to think of it, I don't think this is the spec for the WRX, let me dig up the manual....
Old 08-18-2007, 10:39 AM   #17
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
All bolts 22ft-lbs
All bolts 51ft-lbs
Back of 180
Back of 180 again
-Mike
That's what I was using back then, thus why I was like "they have a NEW sequence?"
Old 03-06-2012, 12:15 PM   #18
Frankly
Member#: 296447
(8) further tighten all bolts, A and B, by 45 deg
this does mean the center TWO bolts, A and B,right!
Not all the bolts as it easily could be misunderstood as saying.
Did I read it right or am I about to wreck my motor?
Frankly is offline   Reply With Quote
Old 03-06-2012, 12:58 PM   #19
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
I thought it was tighten them as tight as you can with the biggest brearer bar you can find. When you feel it give quickly back it off a 1/2 turn and you are good?
medamullet is offline   Reply With Quote
Old 03-06-2012, 01:16 PM   #20
Bamofo
Member#: 159743
07 STI Limited
TurboMike Tuned 2.35
Torque down the heads according to which block your running. if your running an EJ205 short block then use those specs. If you have an STI block, like you are, use the manual that was posted a couple threads in. done. if you have ARP then do it to w/e ARP does now. If it was a built block you would torque it however you told your builder to do it for his/her torque plate while they bored/honed it. Hope this was helpful.
Bamofo is offline   Reply With Quote
Old 03-11-2012, 08:52 AM   #21
djjoel197
Member#: 313180
Default subaru head bolt torque specs
torque specs from my subaru dealer
torque all bolts to 22ft/lbs in order 316
524
then torque all bolts to 51 ft/lbs in order 316
524
loosen all bolts 180 degrees
again loosen all bolts another 180 degrees
tighten bolts 1 and 2 too 25 ft/lbs
tighten bolts 3 4 5 6 to 11 ft/lbs
then tighten all bolts 90 degrees in order
again tighten all bolts 90 degrees in order
then place velcover on and do the other side
djjoel197 is offline   Reply With Quote
Old 03-11-2012, 01:03 PM   #22
Pacobeagle
Member#: 8775
2010 "Zed" 1000
Orange/White
524
524
This is what my manual for my 2002 WRX says
Pacobeagle is offline   Reply With Quote
help!need torque specs for manifold to head bolts twinz Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 09-01-2010 04:55 PM
2.0L cylinder head torque spec pattywomp Newbies & FAQs 1 02-04-2010 02:11 PM
05 sti head torque specs sexyrex02 Built Motor Discussion 3 10-07-2008 06:48 PM
Torque specs on ej25 heads FatCatTurbo Normally Aspirated Powertrain 5 03-14-2004 01:49 PM
Head Bolts & Cams Bolts Torque Specs Imprezd Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 03-20-2003 07:30 AM
