Old 08-07-2007, 01:40 PM   #1
masky43
Member#: 80352
1999 Imreza2.2LCoupe
Black Diamond Pearl
Default Which head gasket?
Im building up my hybrid and I dont know which head gasket to go with. Im using an EJ22t bottom end with JDM EJ20 heads. Im not doing anything with the bottom end im putting in probly crower cams and springs. What gasket should I use?
Justin
masky43 is offline   Reply With Quote
Which Head Gaskets ej257 to 2001 sohc Joncas Normally Aspirated with bolt-on Forced Induction Powertrain 4 02-25-2005 01:28 AM
Which head gasket for EJ257 swap SPESHAL Subaru Conversions 6 06-02-2004 12:34 PM
Which head gaskets? Tattoo Collector Normally Aspirated Powertrain 1 11-15-2002 04:24 PM
Which head gaskets on EJ22T with EJ25 SOHC heads? Eric SS Normally Aspirated with bolt-on Forced Induction Powertrain 22 05-11-2002 11:08 AM
EJ22T with 2.5 SOHc heads. which head gasket? Eric SS Normally Aspirated with bolt-on Forced Induction Powertrain 10 10-03-2001 11:40 AM
Message Board Statistics All times are GMT -4. The time now is 09:03 AM.
