Old 01-06-2002, 01:15 AM   #1
yuletak
Member#: 3602
2002 wrx silver
1992 kawasaki ex500
Default trouble starting car
my wrx seems to have trouble starting. here's an example: i start the car fine. drive for a bit, say 10~15 minutes, stop the car for another 15 minutes or so, then start it up again, but the engine won't turn. i have to try at least another 1 to 2 times before it starts. the other time when it started, it just stalled again. i've got about 11k miles on my car. anyone else have this problem?
apologies in advance if this topic has been discussed b4. i've checked the wrx archive, went through this entire forum, and searched using "start* or ignition" in titles but have found nothing.
yuletak is offline   Reply With Quote
Old 01-23-2006, 04:34 PM   #2
BlakeOutlaw
Member#: 105798
Default Trouble starting
I have the same problem. In my case, I also get the "check engine" light. Temprorary solutions I've read so far are: 1) disconnect/reconnect the battery 2) turn the heater on Full for a bit before attempting to start. Good luck!
BlakeOutlaw is offline   Reply With Quote
Trouble Starting car!!!! Zondacl2 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 12 11-01-2008 05:23 PM
Trouble starting car... SubieRX Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 06-06-2007 08:04 PM
Having trouble starting car scoobyimprza Subaru Conversions 16 02-04-2006 07:46 PM
Trouble starting car crazy_sherm Newbies & FAQs 11 08-12-2003 03:26 PM
TecII Installed. Trouble starting Car Revision Normally Aspirated with bolt-on Forced Induction Powertrain 21 04-10-2003 08:51 AM
