Old 08-08-2007, 12:33 AM   #1
Dyno Flash
Vendor
Member#: 73568
'05 STI 11.1 @ 127
03 Evo 8 9.5 @ 149
Default '07 STI - SPT Cat Back only with Ecutek Tune vs stock
Here is another car which I really enjoed road tuning after the dyno session - what a real smooth and great running car the '07 STI is - hard to imagine that this is the last of the great WRX 4 doors
I put two arrows on the sheet to highlight here the car was having a delay switching to open loop operation with the stock map and you can see the coreponding roughness in the stock tune due to the ultra lean a/f which the delay period causes.
With my tune, I accelerate the transition to open loop and I also smooth out the timing map and work the avcs to get a lot more low end power.
Dyno Flash is offline   Reply With Quote
Old 08-08-2007, 01:24 AM   #2
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
That looks better than the previous car Al. Just curious, why do you start your pulls past 3k RPM? I understand doing this with a big turbo car but the stock turbo hits full boost right around 3k RPM so don't you want to showcase the spool characteristics of your tune as well? There's also still a bit of "roughness" as you call it present in your tune in the 3500-4k RPM region. I find this area to be a bit tricky to smooth out with the 07's as well. I believe this has to do with the higher compression and generally takes a some AVCS and ignition advance work to smooth out nicely and alleviate any knock.
BTW, how much boost are you running on this car?
Thanks
-- Ed
Equilibrium Tuning is offline   Reply With Quote
Old 08-08-2007, 09:18 AM   #3
akira02rex
Member#: 82612
2015 WRX STI
Ice Silver Metallic
Originally Posted by fast_lgt View Post
Another al tuned car with ANOTHER DIP.
-no comment-
While it is pretty funny, it also isn't very nice.
akira02rex is offline   Reply With Quote
Old 08-08-2007, 09:41 AM   #4
SubieFiesta
Member#: 149426
2002 Subaru WRX
2005 Subaru STi & 2000 RS
Originally Posted by UM-WRXer View Post
dude thats totally not nessesary...the peanut gallery has to stop.
Atleast Al is trying to change his ways and become a better community contributer. All youre doing is ruining what can be a good thread.
I look forward in seeing how Al and Ed can have a contructive conversation about tuning the 07 sti. To me thats what NASIOC is about.....
Peanut Gallery? People are commenting on the vehicle that he has tuned and the issue they see with it. What? No one can give there opinion on why the tune has an issue yet again?
It is pretty funny. Especially since again, only a day later and another car has the same dip. I dont think it has to do with anything to do with bashing or being very nice. It common sense.
SubieFiesta is offline   Reply With Quote
Old 08-08-2007, 10:02 AM   #5
ChrisSK
Member#: 117464
2008 Hayabusa 1300R
Thanks
-- Ed
The SPT catback sucks for starters, it's almost up there with the infamous fujitsobo junk. Tuning aggressively on the AVCS on the 07 doesn't work in the cars favor since the ignition advance is so dynamic, this car is just too damn smart. Not sure how other tuners are doing it, but I run about 5* less overall AVCS then in previous model years. I've read some guys are running a total af 45* in some areas, which I have not found to be optimal in my situations, and I've tried tuning AVCS on the 07's for over 8 hours. On race fuel, I've seen some significant improvements adding cam advance after peak torque to help the torque curve carry out, but that's about it.
Ed, got any other insight on this?
As for the closed loop delay, that's nothing new and is even more evident why the 07's need to be tuned when you start to throw after market parts on them.
- Chris
ChrisSK is offline   Reply With Quote
Old 08-08-2007, 10:11 AM   #6
GetSideways
Member#: 44665
03 wrx sedan
platinum
Is Al working at ICS now? What the hell goes on around here?
GetSideways is offline   Reply With Quote
Old 08-08-2007, 10:12 AM   #7
Dyno Flash
Vendor
Member#: 73568
'05 STI 11.1 @ 127
03 Evo 8 9.5 @ 149
- Chris
I appreciate your comments with regard to the '07 which is without a doubt one of the most difficult to master stock ecus I have ever had to wrap my head about.
Of course - aside from the obvious power delivery tuning the stock ROM has several rough spots and a significant hesitation between shifts all of which took me a lot of time to resolve.
I agree with you in that the key to a good result with an 07 is to work with the ultra senstive knock reaction of the stock ECU and map the ecu in a way to minimize any knock events. I have found that the best way to get a good result is with very conservative tuning.
I also agree on the SPT cat back - our ICS SHOP STI was making virtually the same power with a 100% stock exhuast. This customer's objective was to try and get some more power and stay as warranty friendly as possibel.
Al
Old 08-08-2007, 10:22 AM   #8
Dyno Flash
Vendor
Member#: 73568
'05 STI 11.1 @ 127
03 Evo 8 9.5 @ 149
Thanks
-- Ed
Ed - I look for and alieviate knock with my data logs and by watching what the ecu and sesnors are recording.
No car leaves my hands unless the data logs both on the dyno and also in a subsequent road test show a total absense of knock reponse in the ecu and also unless the car is mapped with zero knock what so ever.
The main thrust of the DYNO comparision (as specifically opposed to a dyno like simulation software) is to show a A - B comparision between the initial factory tune and the post tuning Ecutek tune which I did
I do the runs the same way before - RUN A and the same way at the end RUN B - then you can see how the car responded to the tuning and quantify any gains or losses which have occured as a direct result of the tuning.
I will point out that in most cases this kind of tuning gives a huge advantage to the stock tune for several reasons
1 - In most cases when the car come sin with the stock tune the advance multiplier is all the way as high as its going with the fuel in the car
2 - When the car comes in the tmic is usualy cool or at least not heat soaked.
3 - By the time I do 15 or so dyno pulls tuning the car the tmic is usually very heat soaked and also the engine itself is usually very hot.
Despite these factors it is clear that the tuning makes significant gains in power throught the power band.
In addition - the stock rom hesitation issues and inter shift hesitation are all totally resolved.
Al
Old 08-08-2007, 10:24 AM   #9
Dyno Flash
Vendor
Member#: 73568
'05 STI 11.1 @ 127
03 Evo 8 9.5 @ 149
Specifically, speaking from my own perspective, I got a chance to work in the regions largest and best equiped tuning center.
From my customer's perpective, I am working in a large facility that can handle everything from wheel and tire mounting, balancing, computer alignment and welding and fabrication all under one roof.
Old 08-08-2007, 10:42 AM   #10
TurboDXsti
Member#: 106671
2006 Sti
grey
lol heard you got fired
TurboDXsti is offline   Reply With Quote
Old 08-08-2007, 10:51 AM   #11
GetSideways
Member#: 44665
03 wrx sedan
platinum
I recently saw their new garage around the block. High HP turbo bimmers always put a big smile on my face.
Old 08-08-2007, 10:59 AM   #12
XX Tuning
Member#: 42695
2004 Subaru STI
You tuned at XX? Didn't know that.
XX Tuning is offline   Reply With Quote
Old 08-08-2007, 11:02 AM   #13
GetSideways
Member#: 44665
03 wrx sedan
platinum
Ha ha....
I always thought there was a bit of a friendly rivalry between Al and George.
Where is Junior now, I heard he opened a shop in NJ? Any truth to this?
Old 08-08-2007, 11:54 AM   #14
redobs
Member#: 1501
2009 WRX wagon
Dark grey
Please keep this thread on topic. If you have personal questions for Al, please PM him.
redobs is offline   Reply With Quote
Old 08-08-2007, 12:24 PM   #15
Dyno Flash
Vendor
Member#: 73568
'05 STI 11.1 @ 127
03 Evo 8 9.5 @ 149
XX is over 80 miles from my facility at ICS
By Region, I mean Fairfield County and the NY metro area
with over 13,000 square feet - 13 lifts - two alignment racks and a seperate dyno cell with its own lift - I think ICS Performance has more than enough resources to tackle any service needs that my customers may have
AL
Old 08-08-2007, 12:26 PM   #16
Dyno Flash
Vendor
Member#: 73568
'05 STI 11.1 @ 127
03 Evo 8 9.5 @ 149
When you work for yorself as I do its hard to fire yourself - although I may get mad enough one day to do that
Actually, I left my old facility on good terms - I have nothing bad to say abot them what so ever - I just found a facility closer to my home (within a mile) which better suited my needs so I decided to take my dyno leasing needs there
There is no need for all this drama and nonsense
Thanks
Old 08-08-2007, 12:41 PM   #17
ChrisSK
Member#: 117464
2008 Hayabusa 1300R
AL
Understood, but your not the biggest in the region.
Old 08-08-2007, 12:49 PM   #18
foxboroxt
Member#: 73104
2003 WRX wagon stg2
2011 Outback
Al
I didn't think catbacks had all that much potential as power mod. How much power would a car (lets say stock STI) be giving up by going with an SPT over another, better catback (which would be....)? I'm guessing the problem is a restricive muffler?
foxboroxt is offline   Reply With Quote
Old 08-08-2007, 01:14 PM   #19
Dyno Flash
Vendor
Member#: 73568
'05 STI 11.1 @ 127
03 Evo 8 9.5 @ 149
I sincerely hope that we do not need to get into a my penis is bigger than yours type contest
If need be we can get out a tape measure and calculate the size of every shop you wish to compare
Honestly, I have more important ways to spend my time than arguing
Old 08-08-2007, 01:18 PM   #20
GetSideways
Member#: 44665
03 wrx sedan
platinum
So much for being 100% less gay
Old 08-08-2007, 01:25 PM   #21
smokey07
Member#: 151683
What about the spt intake? is it difficult to tune around that and a catback? my car runs like **** with the intake, but after the factory flash, the car runs fine with the stock box and 3" catback.. ap or al??
smokey07 is offline   Reply With Quote
Old 08-08-2007, 01:25 PM   #22
XX Tuning
Member#: 42695
2004 Subaru STI
Absolutely no need to get into an argument with you, you made a statement, I corrected you, that's it. If you did get a tape measure out though, you would realize that XX is nearly 30,000 sq/ft.. Who provides the better service is up to the customer, not us.
Thanks,
Chris
Old 08-08-2007, 01:27 PM   #23
Dyno Flash
Vendor
Member#: 73568
'05 STI 11.1 @ 127
03 Evo 8 9.5 @ 149
Please - all this OFF TOPIC bickering MUST STOP
If you are not discusing a technical aspect related to ecutek - tuning - the dyno sheet or car please just refrain from posting it and stay out
This is a tech section not a soap opera forum
AL
Old 08-08-2007, 01:28 PM   #24
Dyno Flash
Vendor
Member#: 73568
'05 STI 11.1 @ 127
03 Evo 8 9.5 @ 149
Thanks,
Chris
And again as I suggested you guys are over 80 miles from us and not what I consider in my region
AL
Old 08-08-2007, 01:30 PM   #25
bren wrx
Member#: 59454
'10 E92 M3 M-DCT
brentuning.com/blog
al, how much boost on the stock dp'd car? i hate 2L, mine made 290 ft lbs on that dyno =(
bren wrx is offline   Reply With Quote
02-07 WRX/STi SPT Cat-Back Exhaust $300 ohhrichardd Engine/Power/Exhaust 4 12-06-2009 12:07 AM
2008 & 2009 Impreza STI SPT Cat-Back Exhaust System Scooby43055 News & Rumors 8 06-03-2009 04:04 PM
2008 SPT Cat-Back Hatch (5 dr) Exhausts in stock! $305!! SubaruGenuineParts NWIC Vendor Classifieds 6 09-26-2008 11:55 AM
2008 WRX SPT Cat-Back Exhaust's now In Stock only $333.00! FlatironsTuning.com Engine/Power/Exhaust 7 07-26-2008 06:50 PM
spt cat-back/SPT intake/sti intercooler/perrin radiator hoses partingwrex88 Engine/Power/Exhaust 38 04-12-2008 01:00 PM
