Old 08-08-2007, 03:32 AM   #1
TMessick
Member#: 882
2004 WRX Wagon
very blue
Default Poor A/C performance/cutouts due to missing turbo heat shield?
Finally got around to installing my Stage2 parts and ended up killing a few of the heat shield bolts in the turbo heat shield bracket. For now, I'm running without the turbo heat shield (new bracket on order), but I do have turbo wrap and the Crucial ceramic coated DP.
Since going Stage2, I've been having noticeably decreased A/C performance and I can feel the compressor cutting out when it doesn't feel like it should. Enginuity logs confirm that the A/C switch is toggling, so I'm either getting A/C cutouts due to the high/low pressure switch or the evap thermistor (or an intermittent wiring issue?). Tried adding a bit of A/C charge and things got worse, so I'm pretty sure I'm hitting the high pressure cutout, which would make sense due to the added heat soak of no heat shield.
Curious if anyone else has seen A/C cutouts or noticeably reduced A/C performance after pulling off the heat shields. Search yielded plenty of complaints about A/C performance due to the evap thermistor and heat soak due to no heat shields, but I didn't see anything directly relating A/C performance and heat shields. It's possible that it's just a coincidence that the A/C has gotten worse after going stage2, but I think it's unlikely. Either way, I'll find out when I get the heat shield back on...
TMessick is offline   Reply With Quote
Old 08-08-2007, 08:16 AM   #2
blkscooby
Member#: 44422
2009 G8 GT
Cammed, sprayed, stalled
Well you could pick up some pipe insulation from HD and put it on the AC pipe between the firewall and TMIC to see if that helps.
blkscooby is offline   Reply With Quote
Old 08-08-2007, 01:41 PM   #3
bluescoobywagon
Member#: 14911
Not A Wagon!
2011 WRX - 285s on 18x9.5
+1. I did that years ago and it's worked great. It still looks like new, too.
bluescoobywagon is offline   Reply With Quote
Old 08-08-2007, 05:56 PM   #4
jradams38
Member#: 92318
2006 IS350
hmm, I don't know if there's a difference in the A/C stuff for between the STi and the WRX, but I know that I don't have anything retaining the heat from my 20g and the A/C is so cold it'll numb my fingers if I don't crank it up to 80-85 degrees. This is just after an A/C service for an unrelated issue.
J
jradams38 is offline   Reply With Quote
FS : 06 Wrx Stock Axle Back And Turbo Heat Shield SubiRS05 Engine/Power/Exhaust 6 06-18-2010 09:04 AM
necessary to have turbo heat shield? hotsauce61488 Newbies & FAQs 24 01-10-2009 10:43 AM
Missing bolt on turbo heat shield? phillyc Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 11-10-2005 11:00 AM
Missing turbo heat shield... TheShadow Alaskan Impreza Club Forum -- AKIC 6 06-14-2004 11:08 AM
Know were to get turbo heat shield? david2z4 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 03-22-2001 12:13 AM
