Old 08-08-2007, 08:06 PM   #1
wrxphantom
Member#: 128643
2013 STI Sedan
Default Clutch Problem???? any suggestions
I have a 2005 WRX wagon with 296.6 WHP
I have an exedy stage 2 clutch with an exedy flywheel. I have had a problem for a while with this clutch. When shifting into 1st gear sometimes i get a whining sound. My clutch pedal gets unadjusted by itself giving me an empty clutch pedal feeling.
Exedy told me that most likely the slave cylinder is bad and i would have to change it.
Has anyone had a similar problem? and what did you do?
I also purchased Lucas transmission fix. Should i use that?
wrxphantom is offline   Reply With Quote
ECU problems, any suggestion?? ezaldere Electrical & Lighting 0 07-08-2004 07:47 PM
ECU problems, any suggestion ezaldere Service & Maintenance 8 06-30-2004 10:08 PM
O2 senser problem...any suggestions? Subi01 Service & Maintenance 1 01-26-2004 07:55 AM
Door light problem.. any suggestions? Herojin Electrical & Lighting 3 05-23-2003 05:19 PM
Need new clutch badly any suggestions? BlueScooby New England Impreza Club Forum -- NESIC 7 02-23-2001 12:44 AM
