Old 08-09-2007, 01:56 AM   #1
pulser9
Member#: 143202
2003 wrx
black
Default my goals for a hybrid. what would i need
In the next year i would like to do a 6mt swap first. But then i want to do a hybrid swap also. My goal is to get into the 400hp area on 93. WHat would it take for a hybrid to be reliable and to make that much power. Or do you think i should just try and get ahold of a whole long block.
Any input will be great. I have been doing a lot of research on the hybrids and seeking out my options but i figure maybe some people would like give some input.
Thanks
Kevin
pulser9 is offline   Reply With Quote
Old 08-09-2007, 10:06 AM   #2
Acostafan
Member#: 67398
2002 Now with 100%
RDA of 2.5l Goodness!!!
You can make that kind of power on a hybrid, but you're going to have to upgrade your cams at a minimum. That and a bigger turbo for sure if you are talking 400 WHEEL hp. If you have the cash, get the whole longblock.
Acostafan is offline   Reply With Quote
Old 08-16-2007, 11:44 PM   #3
pulser9
Member#: 143202
2003 wrx
black
what type of head work and cams would be needed do you think? id also like to run a gt30 or somthing of that size i think. Also how would ECU work i have utech right now would i be able to keep that? I havnt been able to find much info of that subject
Old 08-17-2007, 12:11 AM   #4
Drink
Member#: 102682
... ripper's
sister.
I ran a 3071 .63 on an OEM hybrid w/ wrx cams. I made well over 400whp with enginuity as a base flash, and then UTEC for tuning.
SPEND THE MONEY ON LARGER CAMS. 264 or bigger if you are staying with non-AVCS heads.
Head work isn't a neccessity, just use the proper springs to support your desired rev limit. Also, fork over the $300 for shimless buckets if your '03 doesn't have them.
Don't bother running 2.0 cams and a 2.5 engine if you hope to make more than 350whp by redline. "Peak horsepower" will never be a a gauge on how "fast" a car is.
Drink is offline   Reply With Quote
Need info: What are my goals for tuning boost / afr / timing Sausage Open Source Reflashes 52 01-24-2008 01:26 PM
Future plans for EJ257 hybrid...what needs to be changed. CoolRex Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 03-05-2007 01:03 PM
My goals for this car Audi-TT Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 10-11-2005 12:27 AM
What would I need to make my 42" plasma my computer monitor? STR8OUT Off-Topic 36 09-10-2005 06:28 PM
My goals for March Chris N New England Impreza Club Forum -- NESIC 39 03-23-2002 12:04 PM
