Old 08-09-2007, 11:03 AM   #1
rpm_nick
Member#: 117406
1999 2.5rs/wrx
Default Hybrid gasket questions
Have a 2.2 N/A block and installing my 02 WRX heads with the Wiseco 22t pistons. Will the Wrx bottom end kit work with the 2.2 block? I doubt that it will but just checking. Also does anyone know the correct HG to use in this applications, no decking or milling to the heads, they were clean.
rpm_nick is offline   Reply With Quote
Old 08-09-2007, 01:19 PM   #2
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
what do you mean by "wrx bottom end kit"?
what year or phase is the 2.2 N/A block?
Old 08-09-2007, 02:55 PM   #3
rpm_nick
Member#: 117406
1999 2.5rs/wrx
91' phase 1 block. I'm pretty new to the Subaru engines and not sure about everything. If I buy the EJ205 gasket kit will I be ok with all the gaskets that are related to the case halves? I'm pretty sure I will need a different thickness for HG's but have not gotten that far yet.
Old 08-09-2007, 03:20 PM   #4
Homemade WRX
Member#: 33782
96 bastard child
get the gasket kit and baerings for the for the block (still using the phase 1 crank right?)...
as for the difference in headgaskets...I dunno...kind of a toss up as to coolant flow.
Old 08-09-2007, 03:58 PM   #5
rpm_nick
Member#: 117406
1999 2.5rs/wrx
still using the phase 1 crank, and ordered ACL bearings. Did you mean to say buy the 2.2 gasket kit for the block?
Hybrid Gasket Set hobbesnapoli Built Motor Discussion 12 02-25-2010 04:07 PM
hybrid gasket kit 123mara Engine/Power/Exhaust 5 11-26-2008 10:34 AM
Hybrid engine questions markk26 Subaru Conversions 0 10-05-2004 08:28 PM
WRX/RS Hybrid-Crossmember Question SCOOBER Normally Aspirated with bolt-on Forced Induction Powertrain 4 04-27-2003 02:19 AM
