Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 08-09-2007, 04:18 PM   #1
Fongers
Member#: 118239
2002 Built Wagon
Wife- 2004 Outback SE
Default Enguinty or OPENECU Map for Hybrid - HELP?
OK, just got my block internals back from the machine shop and am getting ready to get my hybrid back together. My one question is if there is a base ECU map that any of you have that will work with this setup below as a starting point? Please help as I blew up my last engine going too aggressive and don't want to repeat the experience.
Aftermarket:
  • Wiseco pistons 95mm standard bore
  • Cosworth hi-flow oil pump
  • Cosworth Main and Rod bearings
  • Performance Engineering Timing Belt
  • Crower 264 Cams
  • Crower Valvetrain kit
  • ACT Street Performance Clutch
  • Garrett GT30R Turbo - 3in
  • Helix DP and UP
  • TGV deletes
  • APS 3in inlet
  • Modded OEM Injectors (816CC)
OEM Parts:
  • 2.5 RS Head Gasket (lowers compression to ~8.4)
  • STI block, rods and crank
  • 2.0 gasket overhaul set
  • OEM water pump & thermostat
Fongers is offline   Reply With Quote
Old 08-09-2007, 04:22 PM   #2
jays05
Member#: 78165
05 STI 35r + e85
Me, I would take a stock ECU map, rescale for the injectors, and set the rev limiter at 4k or so (set it low enough so theres no way you can spool the turbo). Work on part throttle during break-in and slowly raise the rev limiter while tuning for higher rpms. But that's just me.
Oh and how did you fit 95mm pistons in an STI block? talk about p/w clearence...
jays05 is offline   Reply With Quote
Old 08-09-2007, 04:29 PM   #3
Fongers
Member#: 118239
2002 Built Wagon
Rebore at the machine shop. They're the WISECO regular bores so it should be ok? Also, what about timing as I compleltely changes this with more compression, displacement and especially the cams?
Old 08-09-2007, 04:39 PM   #4
Freon
Member#: 88322
2009 BMW 135i
Dude, that's a heck of a lot of custom work to expect someone to have an acceptable map you can just slap on and go. You need to get it to a tuner who knows what the heck he's doing, and get it tuned in person ASAP. Reality check time.
Freon is offline   Reply With Quote
Old 08-09-2007, 08:05 PM   #5
Fongers
Member#: 118239
2002 Built Wagon
I know man, not looking for a perfect map but just a starting point. I'm doing ALL the mech work myself and want to learn the tuning myself as well. Just don't want another $4K "mistake" and have tried to bulletproof this block as much as possible. That said, anyone got any tips on the timing?
Old 08-10-2007, 08:50 PM   #6
wuuusaa
Member#: 92894
2015 Wrx
is it me or it a typo in parts list
but are you really using 2.5rs head gaskets?
Old 08-11-2007, 09:51 AM   #7
Fongers
Member#: 118239
2002 Built Wagon
Yup - 0.54 thickness to lower compression a little
Old 08-11-2007, 12:32 PM   #8
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
do you have the right tools for tuning?
EGT and a wideband o2 sensor?
mxpunk is offline   Reply With Quote
Old 08-11-2007, 01:05 PM   #9
Drink
Member#: 102682
... ripper's
sister.
I have a good enginuity base map for a 2.5 hybrid (OEM HG), Helix 850cc injectors, and Perrin 30r kit.
I ran utec over it for actual tuning, and it worked great. This map would be a good break-in map, assuming you have the same intake and can adjust for your injectors. PM me it you are interested.
Worst case scenario, I can rescale the MAF for your intake.
Drink is offline   Reply With Quote
Old 08-11-2007, 01:21 PM   #10
mxturboracer86
Member#: 82398
2008 STi
555 Motorsports
Considering the other mods, there will probably have to be a few major adj made to safely run the map, especially the idle w/ the cams he has there will be some different settings...but i wont argue it would def be a good starting point if you dont have any good local tuner
mxturboracer86 is offline   Reply With Quote
Old 08-11-2007, 03:07 PM   #11
sense of nature
Member#: 112759
2018 STi Mikey Tuned
SexyRP
Cool, any chance on DrinkAv8 being @ the next thurs meet?
We missed you last one
sense of nature is offline   Reply With Quote
Old 08-11-2007, 04:18 PM   #12
wuuusaa
Member#: 92894
2015 Wrx
aren't the head gaskets going to fail?
from to much compression? or something like that!
Old 08-11-2007, 05:42 PM   #13
Fongers
Member#: 118239
2002 Built Wagon
Drink, thx man and I definitely have your 2 build threads as a reference too so double thx man (your's and Jim's cars?). I'll email you in a sec about the map.
I think the oem head gaskets are all made from the same stuff as it is metal as well, just different thicknesses? At the very least, I've seen a few folks mention using the updated rs gasket for lower compression as I plan on running high boost eventually (25-32). Anyone else wanna chime in if this is safe or not as the heads have not gone on yet?
Oh yeah, I gotta egt and a WB02 as well on the car. I was just stupid and was running it ~1750 for more than ten seconds at a time.
Old 08-11-2007, 07:09 PM   #14
Drink
Member#: 102682
... ripper's
sister.
It will work just fine with a mild 264 setup, the idle is set @ 1000. The helix injectors were awfully slow and it was the only way I could keep fuel running when I came to a stop.
Sorry I was pretty tired on Thursday. I won't be going to the meets if they are at PnL from now on
Cool deal bro . I will shoot that map over to you in a few here, I have two you can try.
I believe the composite is the same as far as HG goes (vs. the STi), but the amount of layers are differnet IIRC. It's been a while since I took apart a RS. Most cometic enthusiats suggest a .58 thickness, so that can give you an idea of where you are going. I will take a micrometer to an OEM STi gasket later today if I get a chance.
From what I have seen, if you have a turbo that can flow 30 psi efficiently, headgaskets eventually blow. That's big power territory and you may want to look into O-ringing the block and fitting some oversized studs.
Enginuity or OPENECU map for my hybrid? - HELP!! Fongers Commercial ECU Reflashes 4 10-04-2007 03:26 AM
pdx or cobb map for 06 wrx w/20g pollawrx06 Newbies & FAQs 2 10-27-2006 10:54 PM
pdx or 20g map for 06 wrx with 20g pollawrx06 Engine Management & Tuning 0 10-27-2006 07:43 PM
help tunning in the louisiana area or a map for mods listed.. aftermathWRX South East Region Forum 4 01-26-2005 02:19 PM
any base maps or your maps for PE 650 injectors and PE 1820? M32WRXin3seconds Engine Management & Tuning 0 12-30-2003 02:12 AM
