Old 08-09-2007, 03:20 PM   #1
Fongers
Member#: 118239
2002 Built Wagon
Wife- 2004 Outback SE
Default Enginuity or OPENECU map for my hybrid? - HELP!!
Enguinty or OPENECU Map for Hybrid - HELP? OK, just got my block internals back from the machine shop and am getting ready to get my hybrid back together. My one question is if there is a base ECU map that any of you have that will work with this setup below as a starting point? Please help as I blew up my last engine going too aggressive and don't want to repeat the experience.
Aftermarket:
  • Wiseco pistons 95mm standard bore
  • Cosworth hi-flow oil pump
  • Cosworth Main and Rod bearings
  • Performance Engineering Timing Belt
  • Crower 264 Cams
  • Crower Valvetrain kit
  • ACT Street Performance Clutch
  • Garrett 30R Turbo
  • Helix DP and UP
  • Modded OEM Injectors (816CC)
OEM Parts:
  • 2.5 RS Head Gasket (lowers compression to ~8.4)
  • STI block, rods and crank
  • 2.0 gasket overhaul set
  • OEM water pump & thermostat
Fongers is offline   Reply With Quote
Old 08-09-2007, 03:46 PM   #2
06rexwagon
Member#: 114730
2006 WRX Limited Wag
[email protected]
What ecu do you have in the car?
06rexwagon is offline   Reply With Quote
Old 08-09-2007, 07:02 PM   #3
Fongers
Member#: 118239
2002 Built Wagon
2002 WRX USDM ECU - pretty plain jane.
Old 08-09-2007, 08:42 PM   #4
06rexwagon
Member#: 114730
[email protected]
I can probably make a map that will get it up and running.
Old 10-04-2007, 02:26 AM   #5
shutupnshift04
Member#: 101710
BOSS
You need to get it to a profesional tuner though your better off just flatbedding it...
shutupnshift04 is offline   Reply With Quote
Which headgasket for my hybrid build, thick or thin? sick1.8t Built Motor Discussion 16 01-29-2009 07:10 AM
Cams for my Hybrid ok?? or too big?? Twiztidunreal Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 10-08-2007 01:49 AM
Enguinty or OPENECU Map for Hybrid - HELP? Fongers Built Motor Discussion 13 08-11-2007 06:09 PM
where i can get a map for my 06 wrx, using enginuity jonnies Engine Management & Tuning 6 07-12-2007 04:16 PM
where i can get a map for my 06 wrx, using enginuity jonnies Newbies & FAQs 13 07-12-2007 01:34 PM
