Old 08-09-2007, 05:57 PM   #1
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
Default Boring out a 2.0 to a 2.2?
I just got another 2.0 shortblock in and was measuring the cylinder wall and it is about 10.5 mm where I measured and when compared it to a 2.2 block, that wall was about 8.5 mm, a 2mm difference in thickness.
So theoretically, you could bore the 2.0 block to 2.2 and still have "factory" thickness cylinder walls.....
Anyone done it?
Old 08-09-2007, 06:09 PM   #2
Kosmic
Member#: 99140
GD Racing chassis
Slowly in construction
A standard size 2.2 piston is at 97mm I believe.
A standard 2.0 piston is at 92mm. Wiseco has the .020" and 0.040" oversize in bore. So max would be 93mm oversized 0.040". You are quite far from the 97mm form the 2.2 bore size.
Kosmic is offline   Reply With Quote
Old 08-09-2007, 06:26 PM   #3
ai42
Member#: 71348
1999 EJ207 RS.TI
VW Golf TDI 40mpg baby!
You would need to sleeve it in order to get that displacement. You wouldn't want to run aluminum walls there are all kinds of issues with that. I thought most people stroke the EJ20 to get the 2.2L?
ai42 is offline   Reply With Quote
Old 08-09-2007, 07:25 PM   #4
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
haha, yeah, forgot about the actual factory sleeve.
There would be .1 of an inch left though.....
2.0 to 2.5L with blown 2.0 ecu????? AUTO DjKlown UTEC 1 11-20-2008 08:58 PM
2.0 to 2.2 storker? JDMSUBAROO Subaru Conversions 4 02-19-2006 11:53 PM
Want to switch from a blown stock 2.0 to an 2.5 sti short block jaltman Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 34 02-01-2006 07:40 PM
Compression difference from usdm wrx 2.0 to JDM V7 2.0? Davenow Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 11-16-2004 11:57 AM
More worthwhile: 2.0 re-honing or 2.2 bore-out? sick1.8t Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 07-12-2004 02:48 AM
