Old 08-07-2007, 05:12 AM   #1
Starkiller
Member#: 82741
2007 350Z Silver
Default Micro Polishing crankshaft
I'm rebuilding a block and would like to micropolish the crank before putting it back in.
What should I use for a solvent and grit?
Starkiller is offline   Reply With Quote
Old 08-07-2007, 04:37 PM   #2
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
machine shop..
Old 08-07-2007, 06:45 PM   #3
SaabTuner
Member#: 67608
Stock crank is already nitrided isn't it? I'm not sure how micropolishing would affect that.
SaabTuner is offline   Reply With Quote
Old 08-08-2007, 12:21 AM   #4
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
I thought only the spec c's were...or the ver 9's...basically only motors we don't get
Old 08-08-2007, 01:31 AM   #5
SaabTuner
Member#: 67608
Huh ... that sucks then. Almost every other performance engine has either nitrided, or induction-hardened, journals. Seems odd that the WRX wouldn't. But I guess I shouldn't be TOO surprised.
Old 08-08-2007, 04:04 AM   #6
hotrod
Member#: 14141
2002 Impreza WRX
The proper way to micropolish the crank requires a large lathe and a crank polishing accessory that uses a narrow continuous belt of very fine grit emery.
The proper grit and technique depends on what you want done. The smart way is take the crank to a shop that does this as a service and get it done with the proper equipment. It is really not terribly expensive (at least when I used to do it). They can also custom size the crank journals to give you specific bearing clearances as well.
Special hard coatings and antifriction coatings are also available and that would be a good time to do it.
Trying to micro polish by hand can result in flat spots or taper in the crank journals or other odd problems. On cranks that have been nitrided the coating is very very thin (10µm - 15µm) and can easily be taken off by polishing by an uninformed mechanic. The direction of motion of the abrasive relative to the normal direction of rotation of the crank also matters so a low tech polishing by hand with a back and forth motion could cause more problems than good.
Larry
hotrod is offline   Reply With Quote
Old 08-08-2007, 02:51 PM   #7
Homemade WRX
Member#: 33782
96 bastard child
well, couldn't one micropolish the "counter weights" by hand and then have the crank balanced...certainly won't remove too much weight that way...I wouldn't touch and bearing journal by hand though.
Old 08-08-2007, 04:07 PM   #8
hotrod
Member#: 14141
2002 Impreza WRX
Not much point in polishing the counter weights, except to remove flash and roughness to help it shed oil and improve aerodynamics of the leading edge of the counterweights. Sure you can do that by hand (actually it has to be done by hand) but you would want to get it coated with an oil shedding coating if you did that.
Micropolishing usually refers to putting a very good rms finish on the bearing surface, and in some cases slightly changing the nominal journal size. In stead of buying special odd sized bearings to increase oil clearence you can have the journals polished to .0005 under or what ever additional clearance you like and get both improved surface finish, but special clearences while using standard bearing inserts.
Larry
Old 08-08-2007, 07:43 PM   #9
modaddict
Member#: 95840
sold to a good bud
awaiting next car
micropolishing by hand is asking for trouble
modaddict is offline   Reply With Quote
Old 08-09-2007, 01:56 AM   #10
Homemade WRX
Member#: 33782
96 bastard child
Originally Posted by hotrod View Post
Not much point in polishing the counter waits, except to remove flash and roughness to help it shed oil and improve aerodynamics of the leading edge of the counterweights. Sure you can do that by hand (actually it has to be done by hand) but you would want to get it coated with an oil shedding coating if you did that.
Larry
yes, I know micropolsihing reffers to the journals but I was talking of just polishing for the same reasons you listed above...
and to think of it to polish the weights by machine would require at least 4-axis
Old 08-09-2007, 11:18 PM   #11
bboy
Member#: 56468
04 Improved STI
Dirty White
I've had cranks polished. They rotate the crank and use this thing with a gritty tape on it that looks like a fishing pole or a bow (like bow and arrow). It's a very simple process and removes maybe a couple tenths at most. Sorry I don't know the grit they have always been done by a machine shop.
bboy is offline   Reply With Quote
Polish or not to polish Guerice Normally Aspirated Powertrain 1 02-26-2007 02:09 PM
FS NY: 1 silver w/t polished lip & 2 black w/t polished lip Subzeros & 4 Tarmacs garface Private 'For Sale' Classifieds 4 01-28-2005 12:55 PM
Who speaks Polish or can translate English into Polish? WR^2X Off-Topic 15 12-27-2004 08:03 PM
polished throtle body,polished manifold, & polished jdm tumbler valves, bbk, & more! baserlove Private 'For Sale' Classifieds 35 09-04-2004 08:28 PM
Anyone use Mother's Clear Coat Wheel Polish or other wheel polish? Patrick Olsen Interior & Exterior Modification 6 03-04-2002 03:06 PM
